iMac A2438, destroyed capacitor and coil.
  • LaPCon_IT
    • Sep 2022
    • 82
    • Malta
    Hi people.
    iMac A2438, board 820-02009-06. Some insect has killed itself destroying capacitor and coil next to it. No chance for buying donor board, so I'm asking you for help about values of destroyed components.
  • LaPCon_IT
    • Sep 2022
    • 82
    • Malta
    So, using schematic and boardview for 820-02020_V1.0, I have replaced C7801, L7800 and APL1097 ic. iMac lives.
    • juliuscaesar10
      • Dec 2023
      • 5
      • Brasil
      820-02009 is an iMac. 820-02020 is a MacBook Pro. So, how you done that?
      Do you found the iMac boardview?
      • LaPCon_IT
        • Sep 2022
        • 82
        • Malta
        Both boards have APL1097, so passives around them should be the same or very similar (even if layout will be different). I've compared both mainboards first and then found values using MacBook Pro schematic and boardview.
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • thenoicer
          Imac capacitor help
          by thenoicer
          Help with capacitors
          Hey, im fixing a imac logic board that has a damaged capacitor. The original capacitor says: 947 Sepc 270 16. I have looked through board viewer and traced it to the correct values: 270uf, 16v. Just as the original capacitor says. I cant find a direct replacement online for this capacitor. I have 239 Sepc 270 16 capacitors laying around, and compared to the original it's smaller. But is also 16v, 270uf. Can i replace it with this one? I cant really find specifications for them. Thanks
          09-24-2023, 05:09 AM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
