Curious - clock going ahead
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    I've encountered curious and strange issue with HP Probook 8470p - the clock is constantly going ahead without any reason at all.
    If I try to synchronize it, everything is fine, but after hour or two I notice that the clock is again 9-12 minutes ahead.
    That's extremely weird. Logically, I checked the time zone and DST - everything is fine there.
    That's only if the laptop was put in hibernation and then turned on again. If it was turned off and then on - everything is fine.
    Any suggestions?
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
  • petehall347
    • Jan 2015
    • 4448
    Re: Curious - clock going ahead
    off and back on maybe sets time in synch and hibernation keeps same setting .
    i guess its something to do with a crystal .
      • 31278
      swap out the 32.768MHz crystal.
      i'v not seen one that bad, but none are really good enough to build a bomb
      once you remove it, check the 2 caps are o.k. too
      incidentally, in the 80's and 90's one of the 2 capacitors on the legs was variable so you could tune it with a frequency counter.
      • shelby5041
        clock radio / radio lifespan?
        by shelby5041
        hi
        ive got a modern digital clock radio approx 15yrs old
        my question is how long can a clock radio or a simple radio last ss farcas operating hours?
        since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
        the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
        it uses very little power just a few watts i would imagine that may have something...
        09-14-2024, 03:30 AM
      • UserXP
        Vintage SONY Digital Clock Radio ICF-C12W no audio
        by UserXP
        Dear all,
        I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
        i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
        My question is, do you know of this brand of capacitors and how bad are...
        07-21-2025, 08:35 AM
      • TinkerTron
        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
        by TinkerTron
        Hey everyone,
        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
        Instead, here's what's been bugging me so far:
        The schematic...
        03-06-2025, 02:03 PM
      • Fontana
        71R-H14BW6-T830, clock stops when shutdown
        by Fontana
        Hi!
        Funny problem. I have a board, model 71r-h14bw6-t830, it's a shuttle board used commonly on a lot of cheap laptops/AIOs.
        The clock (RTC) is not working when the machine is turned off. Doesn't matter if it is connected to dc power or not. When the PC is powered on, the clock works fine.
        I tried replacing Y6 and Y7 (picture below), but it doesn't seem to be an oscillator problem.
        I don't have the exact schematic for this board, but I'll provide one that is similar (a variation of the same board).
        Any suggestions?
        OBS: when the pc is off,...
        09-28-2022, 09:57 AM
      • kjchatman
        no display on ps4 slim ddc i2c clock shorted
        by kjchatman
        i replaced the hdmi port first with no luck then i noticed that it wouldn't do the two beeps for safe mode unless the televison wasn't connected to the console. Turns out that the ddc data bus has an issue. the clock signal is shorted to ground whenever the display is connected. Even if the console isn't plugged into the outlet. i'm not sure why the clock signal goes to ground. i removed the safety zener diode to rule that out as a culprit.
        12-09-2024, 08:23 PM
