Dead wall wart PSU... opening them
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Suppose you have a wall transformer/power supply that died. There are no screws to open it and you want to fix it. How do you open it?
    19
    Dremel, and cut it open
    0%
    7
    Xacto or other knife to cut it open
    0%
    4
    Hammer
    0%
    3
    I don't bother fixing these things, buy another one at any cost.
    0%
    0
    Other (describe?)
    0%
    5
    Re: Dead wall wall wart PSU... opening them
    Dremel, Exacto knife and flat blade screw driver, once it is open you do not put it back together and give it back to any body to use again. I have done many to verify built quality, safety, component and design quality, mechanical integrity, etc. to qualify the vendors.
    • mockingbird
      • Dec 2008
      • 5484
      Dremel and a flat blade screwdriver.
      Eh, why shouldn't you close it again?
      I've closed them many times and then sealed it with dollar store epoxy. Was as good as before.
      • SteveNielsen
        Retired Tech
        • 2327
        It depends on the wall wart. Some pop open nicely with a thin screwdriver and a rap with a small hammer in a couple of spots, others need to be cut open. Depends on how much glue was used. Generally speaking if I've got to cut it open it isn't really worth the effort for me but I don't have a rotary tool to cut with at this time. I'm not about to do as my idiot neighbor did and clumsily use a hacksaw. He cut cut into a filter cap doing that, but then he's a fumble-fingered dip-shit.
        • mariushm
          • May 2011
          • 3799
          Grab adjustable pliers (i mean this) , adjust it to fit the width, squeeze at the seam until you hear the plastic cracking.
          From there, you can widen the crack with regular screwdriver.
          Alternatively, you can cut a corner with some blade you heat up on the fire, or like this guy does in the video : https://www.youtube.com/watch?v=TiviXtlpiAw (at about 2:00) .. then of course, crack the case further.
          Other people suggest placing the blade of a knife at the seam, and using a hammer to hit the blade, but I'm against this as it can cause cracks in the pcb or pcb traces lifting up.
            I would not give it to the customer or any one else to use, if something goes wrong you can be in trouble, not worth dealing with the lawyers.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              • Romania
              Screwdriver if it has screws (had one with DC voltage selector 3v-12v IIRC) or hammer if it doesn't.
              Most crappy wallwarts aren't worth anything.
              Main rig:
              Gigabyte B75M-D3H
              Core i5-3470 3.60GHz
              16GB DDR3-1600
              Samsung SH-224AB DVD-RW
              Delux MG760 case
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                I use side cutters, small chisel and a hammer. Firstly use the side cutters and cut the corner but not all the way through the plastic then slot chisel into the engraved area then give it a light whack and boom case falls apart.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Yeah I was thinking about this. After trying different ways of opening, if it doesn't have screws, none of these really are conducive to putting Humpty back together again. Not even glue/epoxy. I haven't tried plastic welding but not sure how well that works either.
                  The first PSU I tried to open to attempt to fix I used a "Dremel clone" and cut it open. I decided against fixing it after I discovered what mess I made of the case and putting it back together again safely was not really possible. The hammer option was tempting but it did not crack the case in the right spot. Eventually as I work on cars I had a bench vise that I used, now that cracked the case in the right spot, and I'll have to try that on more PSUs in the future.
                  However I still don't think I could put it back together again as solidly as the original and not have to worry about it falling apart while it's on the wall, electrocuting the user...
                    Yep, not worth getting wiped out by the law suit, I just tell them to go get a new one.
                      • 31054
                      fr fuck's sake.
                      you put it in a vice with something metal and round against the join and the joint cracks without wrecking the case.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Originally posted by stj
                        fr fuck's sake.
                        Not everyone has a vise... So far, as mentioned, it seems to work. I just read about the hammer method which if done carefully, also could also result in an intact case unlike the cutting methods, alas it is still a bit risky as some stuff could be made into a pancake.
                        I have not tried slip joint pliers (which is what mariushm suggested) which might be a good option to try if a vise isn't available.
                          • 31054
                          go to a cheap tool place and by a G-clamp.
                          then you can apply controlled pressure and also use it to hold cases shut while glue dries or to hold heatsinks down while the bond hardens.
                          • redwire
                            • 3910
                            Re: Dead wall wart PSU... opening them
                            I open wallwarts with 0.3mm thick metal guitar picks from DX. These are awesome for prying apart stuff. Phones, laptops etc.
                            Really hard plastic I put it in a vise on the seam line, and tighten to "crack" the seams.
                            If it's ultrasonically welded, you can't open one without cutting it up and I abandon those - because you can't put them back together and expect it to be a safe box. Even with glue.
                            I don't like that you slip with the knife and cut yourself or the components inside.
                            • Behemot
                              • 4845
                              • CZ
                              I use flat screwdriver (one small and one big) plus hammer. Often you crack it open on just a few places (corners), than pry a little bit and it goes off completelly.
                              Good thing is that when you align everything back with long nose pliers, it goes more or less back together and you can just glue it using instant glue (or something similar).
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                I've never had much luck with those cyanoacrylate glues, they don't take well to shearing I think. If I had to glue one back together I'd probably use a ziptie around the whole thing as the main "prevent unintended disassembly" and then use epoxy to hold together.
                                Very ugly indeed...
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  With linear wall-warts/adapters, I usually have good luck opening those with a hammer. Just hit it at the right places on a hard surface.
                                  But laptop adapters are usually a bit tougher. I slightly bent the heatsink on one and made a dent in the main cap on another with the hammer method. So now, I just cut those open with a dremel tool instead.
                                  When it comes to putting it back together, I zip or wire-tie it and run hot melt glue around the whole adapter. Works great, and if I ever need to open it again, I just cut the hot glue with a sharp knife and remove the zip-tie. Then, I can put it back again even easier, since I just re-melt the hot glue and put the zip-tie back on (and yes, I re-use zip-ties - takes me no more than a few seconds to get one opened).
                                  Of course, I only fix those adapters for myself and close friends that I know will be responsible with them (i.e. not someone careless that could get the case opened and get shocked).
                                  Same here.
                                  Only thing I find super/crazy glue good for is fixing tire leaks on my bike and some specific plastics that it works on.
                                  Hot glue is pretty much my go-to glue. It sticks extremely well on wood and acrylic and is OK on PET/HDPE and ABS plastic. Only not so great on vynil and metal. And yes, it is ugly indeed.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Hot glue is not good for heavily loaded adapters - they are inefficient, go hot and it may not directly melt, but soft for sure. Than it also smells.
                                    When you use the hammer method and craxck it the way you can again tightly close it, than it is good to just pour instant glue into the capilars. It is more firm and also vaporizes at temperatures the adapter won't be able to operate anyway.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      The adapter would need to go above 50C-60C case temperature for the hot glue to start softening even a tiny bit. And if your adapter runs that hot, you have other issues then .
                                      • Behemot
                                        • 4845
                                        • CZ
                                        Some wall adapters do…often the transformers are specified for up to 135-175 °C so 60 is no problem at all.
                                        • jayjr1105
                                          9v super basic wall wart issue
                                          by jayjr1105
                                          This is one of those worthless and time wasting repairs but it's bugging me and I want to figure it out. Simple 9v 1a SMPS wall wart and it's bouncing between 8.2 and 9.4v without load. I've pulled out every single cap and all tested fine. I've replaced the opto and same exact issue. All diodes are testing fine. I'm not sure if the IC can cause this or if the IC had issues you wouldn't get anything at all on output....
                                          03-03-2022, 08:32 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • CapLeaker
                                          Poly VVX-250 VOIP POE problem not booting fix
                                          by CapLeaker
                                          I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                                          Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                                          11-25-2023, 10:46 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
