Antec Earthwatts EA-500 500w PSU
  • tazwegion
    • Jun 2006
    • 444
    I picked up a used one of these units recently for my 24/7 Broadcastify streaming computer, voltages checked as well within spec and were stable so in it went only to find it failed within 2 months corrupting the Motherboard Bios as well, thankfully the the MSI Bios-USB trick saved the board and refitting the FSP PSU got the system back up and running.
    Inspection on disassembly indicated no obvious points of interested except for the domed 400v 330uF mains capacitor (this PSU is designed to utilize a single input capacitor) which if you look closely at the uploaded images below appears to have a wrinkle like surface as well.
    The filter capacitors all appear in good condition.
    Once removed I attempted to do a voltage leak test and noted it wouldn't even hold a charge, I'm guessing I've found my smoking gun...
    Any thoughts?
    Viva LA Retro!
    • 31283
    Re: Antec Earthwatts EA-500 500w PSU
    the wrinkles and unsmooth finish are a sign of heat - lots of heat.
    it must have totally boiled internally.
    open it for a look!
    what make & series are they using in earthwatts btw?
    • tazwegion
      • Jun 2006
      • 444
      The primary capacitor that has died was a Nippon Chemi-con SMQ series (rated to 85c), whilst the remainder look to be Ost's, this board appears older than I originally thought with "ATX400w revision 5" clearly marked on the PCB along with the date 25/09/2006.
      Viva LA Retro!
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Still a possibility it had too much voltage go through it? I have a hard time imagining that cap getting that hot without something else burning first. Is it 270uF?
        Beware of the conductive glue.
        As a good measure if you want to keep using it, at least replace the OST on +5VSB and 12V. It's a good design so those OST can actually last quite a while but I don't trust them on the two mentioned rails
        • tazwegion
          • Jun 2006
          • 444
          No the primary capacitor is actually rated for 330uF, as for the OST's they would be replaced as a matter of course, I should still have sufficient SamXon's on hand...
          Viva LA Retro!
          • mockingbird
            • Dec 2008
            • 5488
            I thought the EA-500 was a CWT design (Whereas the 500D was Delta)...
            • everell
              • Jan 2009
              • 1514
              Picked up this "dead" Antec EA-500 from a computer shop. Had two bulging OST capacitors.....3300 uF/16 volt pi input filter cap on the +12v rail, and 1000uF/16 volt pi input filter cap on the -12v rail. Also a burned area on the pc board where fan control circuit is located. The fan control transistor was not shorted. With pc board out of the case and bulging capacitors replaced, the output voltages came up as: 12.14v, 4.87v, 3.174v, 5.01vsb. Voltage on the main capacitor was 167v off and 377v on.I am still tinkering with it, perhaps more later. I am including a drawing of the fan circuit....which seems to be a new idea.
              Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
              • everell
                • Jan 2009
                • 1514
                a few more pictures........
                  • 31283
                  here is my prefered fan circuit.
                  +12v o-----------------------------------------o FAN
                  gnd o------------------------------------------o FAN
                  • c_hegge
                    • Sep 2009
                    • 5219
                    I had an EA-500 with exactly the same damage once before. My solution was to recap it, remove the transistor, and add the fan controller daughterboard from a dead FSP Power supply. And no, I never disable fan controllers. I do sometimes add them to PSUs that lack them, though.
                    • everell
                      • Jan 2009
                      • 1514
                      Looking at the schematic, the fan controller seems to be controlled by the amount of power delivered on the 12 volt rail. As more power is delivered on the +12 volt rail, the voltage will begin dropping a little under the load, and the fan will come on and deliver more cooling air. The problems on my power supply were......first, the capacitors that failed were NOT on the 12 volt rail (they were on the 3.3 volt rail and the -12 volt rail). Both were located next to each other.....does this indicate a hot spot location? Second.....the pc board under the fan controller transistor was burnt. Does this mean that the fan was on too much and too long........causing too much current for a small transistor like this? Since the transistor is still good, the burn must have occurred over a large period of time.
                      So what do you guys think of a fan controller that controls based on the loading of the +12 volt rail as opposed to controlling based on a heat sensor?
                        • 31283
                        you MUST use a heat sensor because it's got multiple heat sources and also you must remember that it doubles as an extractor for the hot air in the case.
                        • everell
                          • Jan 2009
                          • 1514
                          So where is the heat sensor on the EA-500???????????
                          Did I miss something in the schematic?
                            • 31283
                            it's a bad design probably - only about half the psu's i see use a temp-sensor.
                            and half of those mount it on the secondary heatsink instead of mounting it in the airflow.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              SMQ is only rated for 2000hrs at 85C, this one has a black sleeve so I don't suspect it is a fake, it looks like the vent is the proper shape also.
                              But, is it just me or do the PFC coils in some antec PSU models run really hot?!
                              It's possible that the capacitor failed because of normal wear, and then when the ESR increased, it made it heat up more and the plastic sleeve could have de-gassed and caused those bubbles. I guess the silly fan controlling scheme didn't help with the heating issue at all in both cases here...
                              Muh-soggy-knee
                                • 31283
                                they probably run hot given i'v seen a few with burned-out coils.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  I know Behemot (and probably some others here) will throw a rock at me for saying this, but... APFC is nothing but trouble IMO. If you live in a country with 220/230/240 V AC, just take out the APFC and run the bridge rectifier output straight to the cap leads. I bet you even a stinking CapXon will hold up fine as the primary cap after this mod (not that I would recommend you ever use CapXon as a replacement cap ).
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    ^ Mostly agree. If properly placed, I'd take a PPFC coil over APFC.
                                    • tazwegion
                                      • Jun 2006
                                      • 444
                                      Well the parts I needed arrived and I had some spare time so I got stuck in hoping to finish this little project off today however... life happens and an interruption lead me to experience a conundrum.
                                      I had 3 capacitors left to replace 2 2200uF and 1 3300uF 10v, using memory, old parts and the process of elimination I'm 99.9% sure I've got the correct locations sorted and using one of everell's pictures have illustrated their placement (the 3300uF appears larger than the 2200uF in the foreground).
                                      Could anyone confirm that these are indeed correct? TIA
                                      Viva LA Retro!
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        Everall says his 3300uf was 16v??
                                        • sirpsychol
                                          Antec Earthwatts EA-380 smd element type/value
                                          by sirpsychol
                                          While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                          09-03-2023, 07:58 PM
                                        • Robin21
                                          Ubiquiti US-48-500W – No LAN Port LEDs, Possible 12V Issue?
                                          by Robin21
                                          I’ve got a Ubiquiti switch (model US-48-500W, motherboard: USW48P_BCM) on my bench. The switch powers on, but none of the LEDs next to the LAN ports light up.
                                          I’ve measured voltages across the board and suspect a problem with the 12V rail. At the coils where I’d expect 12V, I’m seeing around 6.3V. One coil shows a stable 6.378V, while the other fluctuates between 6.270V and 6.310V.
                                          All other voltages seem fine — 1V, 3.3V, and 5V are present and match the expected values.
                                          I've replaces both buck regulators already (AOZ1212)...
                                          09-25-2025, 03:24 AM
                                        • ChanHa
                                          Help me Resistor on FSP Hexa ATX 500w
                                          by ChanHa
                                          My ATX FSP HEXA 500W was broken, lost 5vol stand by , ic TNY 277PN is broken, and R26, but i dont know what is R26. Help me...
                                          06-04-2025, 08:44 PM
                                        • ajdrenter
                                          Picking caps for Antec SU-380
                                          by ajdrenter
                                          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                          https://www.badcaps.net/forum/showthread.php?t=14159
                                          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                          05-13-2023, 10:40 AM
                                        • CWEastwood
                                          Antec Smart Power SL300S capacitor replacement.
                                          by CWEastwood
                                          I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                          The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                          I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                          Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                          03-25-2023, 12:18 PM
