Ubiquiti US-48-500W – No LAN Port LEDs, Possible 12V Issue?
  • Robin21
    • Feb 2021
    • 55
    • the Netherlands
    I’ve got a Ubiquiti switch (model US-48-500W, motherboard: USW48P_BCM) on my bench. The switch powers on, but none of the LEDs next to the LAN ports light up.
    I’ve measured voltages across the board and suspect a problem with the 12V rail. At the coils where I’d expect 12V, I’m seeing around 6.3V. One coil shows a stable 6.378V, while the other fluctuates between 6.270V and 6.310V.
    All other voltages seem fine — 1V, 3.3V, and 5V are present and match the expected values.
    I've replaces both buck regulators already (AOZ1212) and tested all MOSFET transistors.
    Has anyone worked with this model before and can confirm whether12V should be present immediately after powering on? Any insights would be appreciated!
    Thanks in advance.
    I couldn't try the firmware downloaded from ubiquity support. They are different in size and when I've compared them in HxD they are different as well.
    Click image for larger version  Name:	badcaps_Picture.jpg Views:	0 Size:	553.2 KB ID:	3732537
    Here's the original firmware dump:
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    Interesting. This is a POE+ managed switch. What’s the resistance on the 12V output to GND? I just find it strange that two 12V rails go bad and do the same thing at the same time. What is the voltage input at the buck converter? Check the PSU. I think it is a dual voltage PSU with a 24V and a 48V rail. The 48V is For POE, but maybe something is up with the 24V one?
    What is the status of the enable pin of the buck regulators?
    • Robin21
      • Feb 2021
      • 55
      • the Netherlands
      The resistance on those two coils is quite high. It starts at around 20kΩ when I begin the measurement and gradually increases to 140kΩ, after which the resistance continues to rise very slowly.
      Looking at the datasheet for the AOZ1212, on page 7 under Output Voltage Programming, the formula is:
      V = 0.8 × (1 + R1/R2)
      I removed both resistors from each buck regulator and measured them. The readings are consistent across both:
      R1 = 140kΩ and R2 = 20kΩ
      So:
      0.8 × (1 + 140/20) = 6.4V — which is what I have measured.
      It seems my 12V is coming from somewhere else. I haven’t found any coil showing 12V, although there are 12V labels on the board. Interestingly, every other voltage label matches the voltage on the coil next to it.
      I will have to look at 12V rail closer and trace where it comes from.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        I think it takes the 24VDC directly from the PSU. Measure the 24v from the PSU.
        • thetonywarren
          TCL 43S435 NO BACKLIGHT ISSUE, LEDS TEST OK
          by thetonywarren
          I have a TCL 43S435 with no backlights. I contacted ShopJimmy and they said power supply. I got replacement power supply, but still doesnt work. I have confirmed that there is an image with flashlight test. I have also verified that the led strips work when I probe them with LED tester. Any ideas would be helpful. I am also geting a double blink on the status led when trying to turn it on......Nothing on the power supply looks suspect, and caps look ok. Where should I start to test......Thanks!...
          04-23-2025, 10:48 AM
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
          🛠 Original Issue
          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ugamazing
          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
          by ugamazing
          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
          12-17-2024, 07:05 PM
        • shahnld
          Lenovo legion 5 pro startup issue
          by shahnld
          Good day Experts
          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
          08-24-2025, 12:31 PM
        • ahmarzo
          Acer laptop battery draining issue
          by ahmarzo
          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
          08-02-2025, 06:39 AM
