Antec Earthwatts EA-500 500w PSU
I picked up a used one of these units recently for my 24/7 Broadcastify streaming computer, voltages checked as well within spec and were stable so in it went only to find it failed within 2 months corrupting the Motherboard Bios as well, thankfully the the MSI Bios-USB trick saved the board and refitting the FSP PSU got the system back up and running.
Inspection on disassembly indicated no obvious points of interested except for the domed 400v 330uF mains capacitor (this PSU is designed to utilize a single input capacitor) which if you look closely at the uploaded images below appears to have a wrinkle like surface as well.
The filter capacitors all appear in good condition.
Once removed I attempted to do a voltage leak test and noted it wouldn't even hold a charge, I'm guessing I've found my smoking gun...
Any thoughts?
