Picking caps for Antec SU-380
  • ajdrenter
    HamburgerHelper
    • Sep 2015
    In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
    https://www.badcaps.net/forum/showthread.php?t=14159
    It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:
    Low voltage side
    EC502 PCE TUR 3900uf 16v 105c 13x33 https://www.digikey.com/en/products/...2-5X30/6050005
    EC504 PCE TUR 2200uf 10v 105c 10x25 https://www.digikey.com/en/products/...10X23/15667956
    EC602 PCE TUR 2200uf 6.3v 105c 10x20 https://www.digikey.com/en/products/...10X20/15667812
    EC503 OST RLS 3300uf 10v 105c 13x25
    EC601 OST RLS 3300uf 6.3v 105c 13x20 https://www.mouser.com/ProductDetail...ZE6R3ELL332MK2
    EC400 OST RLS 1000uf 16v 105c 10x16 https://www.mouser.com/ProductDetail...ZE160ELL102MJ2
    EC402 OST RLS 220uf 16v 105c 6x11
    EC201 OST RLS 220uf 16v 105c 6x11
    EC200 OST RLS 2200uf 10v 105c 10x20 https://www.mouser.com/ProductDetail...ZE100E222MK20S
    High voltage side
    EC300 Hitachi HU4 220uf 400vdc 105c 30x30
    EC100 OST RLS 22uf 50v 105c 5x11 https://www.mouser.com/ProductDetail/232-50ZL22MEFC5X11
    EC101 OST RLS 47uf 25v 105c 5x11 https://www.mouser.com/ProductDetail/232-25ZL47MEFC5X11
    EC302 OST RLS 68uf 25v 105c 5x11
    EC303 OST RLS 4.7uf 50v 105c 5x11
    Fan board
    C1 OST RMH 22uf 35v 105c 5x7
    I've been following recommendations in this thread for replacing the OST RLS series:
    https://www.badcaps.net/forum/showthread.php?t=14433
    Some of the series mentioned there have had a limited selection or availability in regards to size and capacitance.
    I've linked the caps I've picked out so far, but I'm wondering if somebody with more knowledge can give me some advice on what to buy.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: Picking caps for Antec SU-380
    When it comes to power supplies, one of the most important things to consider is the ripple current. Look at the datasheets, make sure the ripple current matches or is bigger than the cap you're replacing it with (but not crazy too high). There is another factor called ESR but it usually does not apply to PSU's. The caps for them are sometimes listed as for power supplies.
    I did this for an antec basiq 380 some years ago it worked great
    I have pictures somewhere. Also usually if you don't see the mains (400v) bulging you usually don't need to replace it
    • ajdrenter
      HamburgerHelper
      • Sep 2015
      Thanks for the advice. I ended up ordering mostly Panasonic FR-A series to replace the OST RLS, and I ordered both general purpose and low ESR equivalents for the few general purpose PCE TUR caps. Is there any reason I shouldn't replace those with low ESR caps?
        • 31265
        i only use low-esr caps.
        for small ones i use whatever is cheapest - usually FR's
        large caps i'v used FC and FK in the past.
        • ajdrenter
          HamburgerHelper
          • Sep 2015
          I wasn't able to find a low-ESR cap for the primary, but I did buy a Nichicon LGU cap (LGU2G221MELB). I'm not sure it's a good replacement for the Hitachi HU4 that was in there already though, so I could just put that one back. I'm going to attach the datasheets here if anyone can give me an idea.
            • 31265
            the high voltage caps you want to try to get 105' temp rated with a long lifespan
            • andrewsawesomr
              • Jun 2022
              • 101
              • United States of America
              The Nichicon LGU should be just fine as a replacement for the Hitachi prinary capacitors.
              • AleXis6
                • Feb 2021
                • 69
                • Belarus
                ripple current :
                1,13A your Hitachi
                1,1A Nichicon LGU
                • sirpsychol
                  Antec Earthwatts EA-380 smd element type/value
                  by sirpsychol
                  While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                  09-03-2023, 07:58 PM
                • CWEastwood
                  Antec Smart Power SL300S capacitor replacement.
                  by CWEastwood
                  I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                  The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                  I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                  Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                  03-25-2023, 12:18 PM
                • s_henya
                  Antec VP-600P and NE550M dead
                  by s_henya
                  Got in these 2 nice PSUs, both died after power surge.
                  Both seems to be suffering from the same fault.
                  Blown main fuse
                  Shorted N mosfet 550v
                  VP-600P: 5R280CE short between GDS
                  NE550M: MDF18N50 short between GDS
                  In terns of board layout these seems pretty identical.
                  From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                  I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                  Is it worth to try and replace the mosfets? is there a chance that the...
                  12-03-2024, 10:00 PM
                • withalligators
                  Looking for best replacements for Capxons, but can't find data sheets
                  by withalligators
                  Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                  1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                  1 x Capxon 1000uf35v...
                  03-25-2022, 02:30 PM
                • slybunda
                  Picking long life capacitor replacements?
                  by slybunda
                  to pick some good quality capacitors for long lifetime do i just go to mouser, rs etc and select the capacitance and voltage then sort by the highest number of hours and pick the caps that have the highest number of lifetime hours?
                  02-08-2024, 03:56 AM
