Antec Smart Power SL300S capacitor replacement.
  • CWEastwood
    • Mar 2023
    • United States of America
    I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
    The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
    I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
    Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1 Capxon. They are, aside from the large primary side caps, a mix of general purpose (TN series) and low ESR (TM series).
    Most of them I can replace with other brands near 1 for 1 but a few are a bit odd ball. For example the nearest I found to the Fuhjyyu TN 1650uf 16V are the Panasonic FS-A Low ESR 1800uf 16V and the Rubycon ZLJ of 1800uf 16V.
    Similarly there is one Low ESR 4700uf 10V cap with a 10mm diameter that no one else uses. I'm gonna grab the 12.5mm and test fit but would like suggestions on other possible replacements. Now I've read other posts which suggest going with the lower 6.3 voltage cap and I've seen others suggest the lower capacitance 3300uf cap. What would you all suggest is the best rating to adhere to.
    And 1 final question is if I should just replace every TN general purpose cap with a low ESR variant. So far I've been trying to keep everything relatively the same, trusting in Antecs engineering, but if there's no ill effects in going all low esr (and if there is a benefit) then should I just go that route
    What are your thoughts?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Antec Smart Power SL300S capacitor replacement.
    I think you have done good research, I would not change general purpose caps to low ESR caps, it is possible that would go ok but no point in taking the bet.
    Also for the unobtanium cap sizes it does not really matter, me myself would go with 6.3v caps, just because we know how a ATX PSU works and it will be for a 5v rail.
    That said downgrading from 4700uF to 3300uF would not be a problem too.
    • CWEastwood
      • Mar 2023
      Thank so much for the quick reply. I'll keep all that in mind.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • artvandalai
        Where can I get compatible capacitor for replacement?
        by artvandalai
        Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
        12-28-2024, 10:15 AM
      • r2digital
        klipsch kda-500 amplifier suitable power supply capacitor replacement ?
        by r2digital
        I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
        04-18-2024, 03:50 PM
      • rwkish
        Discontinued Capacitor looking for Replacement
        by rwkish
        Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
        08-18-2024, 06:54 PM
      • Hylax
        Replacement capacitor options please?
        by Hylax
        Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
        08-09-2024, 11:25 PM
