HP ProBook 650 G8 BIOS Admin Password
  • mazi54
    • Sep 2023
    • 28
    • poland
    #101
    Originally posted by lapfix
    If you ask for
    On BIOS Section i cant find field,where can introduce MAC..
    • Kiki Cares
      • Feb 2022
      • 29
      • Nigeria
      #102
      HI GUYS
      I HAVE HP 650 G8 CONPOTRACE LOCK
      DA0X8QMB8E0
      SN;;;;5CD120VFLZ
      PLS HELP ME WITH THE CLEAR-ME FILE
    • AWENA
      • Sep 2020
      • 39
      • Polska
      #103
      I have a ProBook 650 G8 with a BIOS password, and I used this script:
      https://www.badcaps.net/forum/troubl...y-bios-patcher
      Everything went without errors, and the BIOS dump is "patched" (I compared it with the backup and can clearly see the changes). However, when I turn on the laptop, I get a message saying that the BIOS data has been recovered, and unfortunately, the password remains.
      I tried running the "HP_Factory_Mode_Full_Script" as well as each of the individual scripts from the archive. Unfortunately, I’m getting the same result. The script is 100% working—it changes the HP_MPM status, and it worked on another HP laptop. I just created a backup using HP BCU and then restored the serial numbers back. I'm very grateful for this script! I used to do all of this manually and didn’t even know such tools existed.
      But for some reason, on this ProBook 650 G8, I’m having this issue—the password doesn’t disappear, MPM doesn’t activate, and I only get a message saying the BIOS has been recovered, no matter what I do.
      Please, I’m asking for help—what am I doing wrong?
      Below I’m attaching the patched BIOS and EC dump, with which the laptop turns on and works, but the password still remains.
      • AWENA
        • Sep 2020
        • 39
        • Polska
        #104
        Hi, I managed to solve the password problem! The BIOS version was too "fresh," specifically from late 2024. So, I decided to use dumps from another identical laptop, clean the ME region, and use them on this one. There were some issues and errors in Intel FIT (Error 179: [Fit Actions] Failed to parse CSE region), but I managed to fix those as well, thanks to the WinRAID forum. If something isn't working out, I recommend just using dumps from another laptop; it worked for me.
        I also noticed that the script somehow doesn't change the MPM state. Here's what it should look like in Hex (search for "HpMpm" in the dump): 48 00 70 00 4d 00 70 00 6d 00 00 00 00 23 01 00 02 00 00 00 aa 55 3f
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          #105
          Nice work..but in the end you didn "t unlock your own dump, you just replaced it with another one, hence the errors.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12441
            #106
            You write too long, where is the serial number ?
            • AWENA
              • Sep 2020
              • 39
              • Polska
              #107
              Good day, dear hoaca388. Before disassembling the laptop, I made a backup using HpBCU "/GetConfig:". In the donor dump, I modified the HpMpm state using a hex editor and then restored the serial numbers using the same HpBCU tool. I'm still learning. I’m not doing this professionally. I just work at a recycling company, and sometimes we receive laptops, but usually it's Zebra printers and Elo monitors. So I don’t have much experience.
              • kurobaxkaito
                • Dec 2019
                • 10
                I have a HP ProBook 650 G8 with a message stating "Devicefreeze-9" and states that it's reported lost/stolen.
                Anyway to remove that? I am attaching EC / SPI ROM in hopes that someone can help me clear it.
                Board: DA0X8QMB8E0 Rev: E
                Serial: 5CD112N2GF
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12441
                  #109
                  Serial: 5CD112N2GF
                  HP ProBook 650 G8 Notebook PC IDS Base Model
                  • kurobaxkaito
                    • Dec 2019
                    • 10
                    Thank you, I flashed my SPI ROM with the file you provided and it went through a BIOS update screen and went back to the same lock screen after it was completed.
                    • shiyab
                      • Sep 2023
                      • 1695
                      • india
                      #111
                      hi try spi
                      • kurobaxkaito
                        • Dec 2019
                        • 10
                        Originally posted by shiyab
                        hi try spi
                        Thank you, I tried and it is the same results. I am attaching pictures of how it looked. It booted into Windows desktop briefly and then showed the lock again.
                        • peste
                          peste commented
                          Editing a comment
                          Don't post pictures unless asked..
                      • Ray-G
                        • Sep 2023
                        • 30
                        • Netherlands
                        #113
                        Hello
                        could you unlock mine? Thanks in advance.
                        ProBook 650g8
                        prodid: 2Q122AV
                        sn: 5CD116Q5N6
                        • Ray-G
                          • Sep 2023
                          • 30
                          • Netherlands
                          #114
                          Hello, forget previous post (because laptop did not startup after reading bios chip
                          But could you unlock this one? Thanks in advance.
                          ProBook 650g8
                          prodid: 2Q122AV
                          sn: 5CD116Q587
                          • Ray-G
                            • Sep 2023
                            • 30
                            • Netherlands
                            #115
                            Somebody please?
                            • Andromedus_81
                              • Aug 2023
                              • 67
                              • United Kingdom
                              #116
                              Hello
                              While desoldering the EC ROM chip, I damaged it and can't read it. Is it possible to upload new firmware to a new chip? Right now I have a laptop that won't turn on, and I'm wondering if it's possible to replace the firmware.
                              S/N 5CD048HJWG
                              hP pROBOOK 650 g8
                              • LBTT1121
                                • Nov 2024
                                • 1239
                                • Việt Nam
                                #117
                                try https://www.badcaps.net/forum/troubl...61#post1864861
                                • Andromedus_81
                                  • Aug 2023
                                  • 67
                                  • United Kingdom
                                  #118
                                  I flashed two firmware files — main and EC — but the same problem persists: Caps Lock and Num Lock blink 7 times. Can anyone help me find the correct main and EC firmware for this model?
                                  • gunsmoke
                                    • Nov 2025
                                    • 4
                                    • United Kingdom
                                    #119
                                    I am trying to remove bios password for HP ProBook 650 G8.
                                    I've looked at one video on youtube and i replaced nvramactiveregn with FF saved the file write it back and it didn't work as the password was still there
                                    Then i found out multiple 2 more nvram so i replaced the second one with FF. wrote it back and now the laptop doesn;t turn on. tried to put the original backup file.. still doesn;t work.
                                    Tried to use the rcunlocker but its asking for 16mb but mine is 32 which one user said you have to split it 2 use the rcunlocker and combine it back but i don;t know to to split in two(maybe someone can eli5 this step)
                                    Details:
                                    HP ProBook 650 G8
                                    ProdID 2Q122AV
                                    SN 5CD130D5GL
                                    EC BIOS CHIP MODEL GIGADEVICE GD25Q256
                                      SMDFlea commented
                                      Editing a comment
                                      Thread merged.
                                  • gunsmoke
                                    • Nov 2025
                                    • 4
                                    • United Kingdom
                                    #120
                                    Details:
                                    HP ProBook 650 G8
                                    ProdID 2Q122AV
                                    SN 5CD130D5GL
                                    Motherboard DAOX80MB8E0 REV E
                                    • intelg
                                      HP Elitedesk 800 G6 lost BIOS admin password
                                      by intelg
                                      Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                      Here is the hardware identification specs:
                                      HP EliteDesk 800 G6 Desktop Mini PC
                                      Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                      BIOS ver S21 Ver. 02.05.01 01/05/2021
                                      Born on date: 07/26/2021
                                      SN MXL11841GN
                                      SKU 3X8V9UCHABA
                                      UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                      SYSTEM BOARD ID 8710
                                      SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                      11-03-2023, 02:05 AM
                                    • Phad
                                      Seeking help and advice to remove bios admin password – HP ProBook 4520s
                                      by Phad
                                      Dear All,
                                      Hope that this post is at the right place of the forum.
                                      I am seeking help and technical advice to remove bios admin password from HP ProBook 4520s.
                                      The laptop is operating normally and, I am not facing any major issue with it except; the bios admin password that I found about by coincidence only few weeks back.
                                      As the laptop is operating normally, I am reluctant to take it to a workshop to de-solder the bios chip in order to read it by an external programmer, as I am not an expert in doing such a thing.
                                      After...
                                      11-10-2021, 12:05 AM
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
                                    • traxformania
                                      TONGFANG "GM7TG7P" Bios Password Problem?
                                      by traxformania
                                      I tried :
                                      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                      11-15-2023, 07:32 AM
                                    • tlindi
                                      Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                      by tlindi
                                      Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                      Ack
                                      Ack
                                      01-30-2025, 04:26 AM
