HP ProBook 650 G8 BIOS Admin Password
  • mazi54
    • Sep 2023
    • 28
    • poland
    #101
    Originally posted by lapfix
    If you ask for
    On BIOS Section i cant find field,where can introduce MAC..
    • Kiki Cares
      • Feb 2022
      • 28
      • Nigeria
      #102
      HI GUYS
      I HAVE HP 650 G8 CONPOTRACE LOCK
      DA0X8QMB8E0
      SN;;;;5CD120VFLZ
      PLS HELP ME WITH THE CLEAR-ME FILE
    • AWENA
      • Sep 2020
      • 28
      • Polska
      #103
      I have a ProBook 650 G8 with a BIOS password, and I used this script:
      https://www.badcaps.net/forum/troubl...y-bios-patcher
      Everything went without errors, and the BIOS dump is "patched" (I compared it with the backup and can clearly see the changes). However, when I turn on the laptop, I get a message saying that the BIOS data has been recovered, and unfortunately, the password remains.
      I tried running the "HP_Factory_Mode_Full_Script" as well as each of the individual scripts from the archive. Unfortunately, I’m getting the same result. The script is 100% working—it changes the HP_MPM status, and it worked on another HP laptop. I just created a backup using HP BCU and then restored the serial numbers back. I'm very grateful for this script! I used to do all of this manually and didn’t even know such tools existed.
      But for some reason, on this ProBook 650 G8, I’m having this issue—the password doesn’t disappear, MPM doesn’t activate, and I only get a message saying the BIOS has been recovered, no matter what I do.
      Please, I’m asking for help—what am I doing wrong?
      Below I’m attaching the patched BIOS and EC dump, with which the laptop turns on and works, but the password still remains.
      • AWENA
        • Sep 2020
        • 28
        • Polska
        #104
        Hi, I managed to solve the password problem! The BIOS version was too "fresh," specifically from late 2024. So, I decided to use dumps from another identical laptop, clean the ME region, and use them on this one. There were some issues and errors in Intel FIT (Error 179: [Fit Actions] Failed to parse CSE region), but I managed to fix those as well, thanks to the WinRAID forum. If something isn't working out, I recommend just using dumps from another laptop; it worked for me.
        I also noticed that the script somehow doesn't change the MPM state. Here's what it should look like in Hex (search for "HpMpm" in the dump): 48 00 70 00 4d 00 70 00 6d 00 00 00 00 23 01 00 02 00 00 00 aa 55 3f
        • lapfix
          • Mar 2020
          • 2724
          • my workshop
          #105
          Nice work..but in the end you didn "t unlock your own dump, you just replaced it with another one, hence the errors.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11738
            #106
            You write too long, where is the serial number ?
            • AWENA
              • Sep 2020
              • 28
              • Polska
              #107
              Good day, dear hoaca388. Before disassembling the laptop, I made a backup using HpBCU "/GetConfig:". In the donor dump, I modified the HpMpm state using a hex editor and then restored the serial numbers using the same HpBCU tool. I'm still learning. I’m not doing this professionally. I just work at a recycling company, and sometimes we receive laptops, but usually it's Zebra printers and Elo monitors. So I don’t have much experience.
              • kurobaxkaito
                • Dec 2019
                • 10
                I have a HP ProBook 650 G8 with a message stating "Devicefreeze-9" and states that it's reported lost/stolen.
                Anyway to remove that? I am attaching EC / SPI ROM in hopes that someone can help me clear it.
                Board: DA0X8QMB8E0 Rev: E
                Serial: 5CD112N2GF
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11738
                  #109
                  Serial: 5CD112N2GF
                  HP ProBook 650 G8 Notebook PC IDS Base Model
                  • kurobaxkaito
                    • Dec 2019
                    • 10
                    Thank you, I flashed my SPI ROM with the file you provided and it went through a BIOS update screen and went back to the same lock screen after it was completed.
                    • shiyab
                      • Sep 2023
                      • 1477
                      • india
                      #111
                      hi try spi
                      • kurobaxkaito
                        • Dec 2019
                        • 10
                        Originally posted by shiyab
                        hi try spi
                        Thank you, I tried and it is the same results. I am attaching pictures of how it looked. It booted into Windows desktop briefly and then showed the lock again.
                        • peste
                          peste commented
                          Editing a comment
                          Don't post pictures unless asked..
                      • intelg
                        HP Elitedesk 800 G6 lost BIOS admin password
                        by intelg
                        Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                        Here is the hardware identification specs:
                        HP EliteDesk 800 G6 Desktop Mini PC
                        Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                        BIOS ver S21 Ver. 02.05.01 01/05/2021
                        Born on date: 07/26/2021
                        SN MXL11841GN
                        SKU 3X8V9UCHABA
                        UUID 8116E79EF6FFE94DB0B98A3188270C5C
                        SYSTEM BOARD ID 8710
                        SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                        11-03-2023, 02:05 AM
                      • Phad
                        Seeking help and advice to remove bios admin password – HP ProBook 4520s
                        by Phad
                        Dear All,
                        Hope that this post is at the right place of the forum.
                        I am seeking help and technical advice to remove bios admin password from HP ProBook 4520s.
                        The laptop is operating normally and, I am not facing any major issue with it except; the bios admin password that I found about by coincidence only few weeks back.
                        As the laptop is operating normally, I am reluctant to take it to a workshop to de-solder the bios chip in order to read it by an external programmer, as I am not an expert in doing such a thing.
                        After...
                        11-10-2021, 12:05 AM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • traxformania
                        TONGFANG "GM7TG7P" Bios Password Problem?
                        by traxformania
                        I tried :
                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                        11-15-2023, 07:32 AM
                      • tlindi
                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                        by tlindi
                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                        Ack
                        Ack
                        01-30-2025, 04:26 AM
