* DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
* The unlock scripts given here are for personal use only, ie. you accidentally set a password on your own
* machine,you forgot the password you set a long time ago or you mistyped the password when setting it
* and cannot get in again.
* DISCLAIMER: THIS SCRIPT IS FREE AND IS INTENDED FOR EDUCATIONAL PURPOSES ONLY.
* You CAN download it, use it.I only ask that you DON'T modify it ,sell it or try to make a profit from it,
* and that you please credit the authors for the time and work they put into it.
* I TAKE NO RESPONSIBILITY FOR ANY DAMAGE YOU DO TO YOUR MACHINE.Making these kinds
* of modifications is risky and might leave you with an unusable/broken machine. The script is not perfect
* by any means, and while I haven't bricked any hardware (yet) I can't promise that won't happen to you.
* USE IT AT YOUR OWN RISK.
A macro script to patch a HP bios to factory settings. It just invalidates the serial number,featurebyte etc allowing new DMI to be added.
This will only work with some HP business machines (AMI bios), not cheaper models (Insyde bios).
Thanks to volinakis for testing, and other members who posted and shared which hex to patch.
Make sure you have all the DMI info before flashing the bios back ! Use HP Bios Config utility to save DMI before you start.
This will only work if you have made a good bios backup !!!!!!
1. Install Tiny Hexer hex editor -> https://www.softpedia.com/get/Others...ny-hexer.shtml
2. Make a new folder on your C: drive called DMICOPY .
3. Move or copy the contents of the extracted zip folder to the DMICOPY folder.
4. Move or copy your bios backup to the DMICOPY folder.
5. Rename your backup bios to "locked.bin" (without the quotes "") .
6. Run the full script, if it doesn`t work try the others one by one. After each script has run close Tiny Hexer and when prompted to save, Save ,then go onto the next script.
If there is an error go onto the next script.
If it work, great, if it doesn`t, well you`re out of luck, try another way.
7. Click on the save button or close Tiny Hexer,and when promted to save... save :-)
EDIT: Added script to disable Absolute. It is not in the full script but only as a standalone script . File name HP_Factory_Mode_6.mps
EDIT: If you are using the patcher for G10`s that have a password the patcher will not work if your bios version is newer than February 2024. For G11`s is no solution yet
EDIT: Added script to put into MPM - HP_Factory_Mode_7_MPS
Tested working
450 G9
640 G9
845 G9
Elite Mini 600 G9
Pro One 440 G9
x360 Fortis 11 G9
Zbook Firefly 14 G7
Zbook Firefly 14 G8
HP ZBook Fury 15 G7
Tested working
450 G9
640 G9
845 G9
Elite Mini 600 G9
Pro One 440 G9
x360 Fortis 11 G9
Zbook Firefly 14 G7
Zbook Firefly 14 G8
HP ZBook Fury 15 G7
