Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • minhdigital
    • Nov 2022
    • 751
    • Vietnam
    #581
    Originally posted by izaak94
    I have a computer with administrator and absolute lock, could you help me? I tried to unlock it by comparing it with other files but it has an endpoint error
    SN:5CG222503X
    Send to you, try
    • rex98
      • Feb 2023
      • 1278
      • Mandaue CEBU, Philippines
      #582
      SN:5CG222503X
      do not touch the EC.
      First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults
      Use BCU here's your DMI info:
      Serial Number: 5CG222503X
      Product Number: 46L32UC#ACH
      CT Number: PQSMT00WBGP6LL
      Description: HP EliteBook 840 G8 Notebook
      build_id: 21WWCVDZ602#SABA#DACH
      Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfPguhKhkjhk8mEmwn7nVngpDpnpqpr.78
      MAC Address: 3C-18-A0-C2-BA-A0​
      • ganesh babu
        • Mar 2024
        • india
        #583
        i need tpm reset tool for reset my hp elite i5 laptop bitlocker unlock purpose.
        thanks with regards,
        Ganesh babu
        • izaak94
          • Mar 2019
          • 126
          • mexico
          #584
          thanks files worked 100%
          • vsc
            • Oct 2007
            • 3
            #585
            Hello all! I have just bought Elitebook 840 G8 i7 11th gen. It has a Bios Admin password as far as I was able to see trying to F10. For the rest is OK, boots to windows, acts normally.
            Yet I want to be able to change the OS installed (win11) with Linux but can't access the BIOS....
            Have allready desoldered and read the Bios and EC chips.
            I need the help of some knowledgeable folks for unlocking the BIOS!
            Thanks in advance!!!
            SN: 5CG2390NZ6
            ProID: 6A3P3AV
            build_id: 21WWCVET601#SABZ#DABZ
            • vsc
              • Oct 2007
              • 3
              #586
              Here we are..
              • rex98
                • Feb 2023
                • 1278
                #587
                Originally posted by vsc
                Here we are..
                Serial Number: 5CG2390NZ6
                Product Number: 6A3P3AV
                CT Number: PQSNP00WBH51X1
                Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdpdqeMfPgSguhKj4jhk8mEmVmwn7nVngpDpq.ef
                MAC Address: 38-CA-84-56-38-E7
                • vsc
                  • Oct 2007
                  • 3
                  #588
                  Thanks, let you know how is going to end..
                  By the way, what "BCU" stands for?
                  • rex98
                    • Feb 2023
                    • 1278
                    #589
                    bios config utility. just search here in forum it has so many topics about it.
                    • sundarkanini
                      • Aug 2017
                      • 155
                      • india
                      #590
                      Hi can you please unlock my hp elitebook 840 g8
                      it has a bios password and Bit locker password
                      mbd id: 6050A3217501-mb-a01
                      sn - 5cg1473pcb
                      prodid - 4S1H8PA
                      this is my backup
                      Thank You in Advance
                      • rex98
                        • Feb 2023
                        • 1278
                        #591
                        sn - 5cg1473pcb
                        prodid - 4S1H8PA
                        this is my backup
                        do not touch the EC
                        First boot press F10 reset bios to factory defaults & Restart, 2nd boot reset security settings to defaults.
                        search here bios config utility in forum in case you don' know.
                        Use BCU to fill these DMI INFO
                        Serial Number: 5CG1473PCB
                        Product Number: 4S1H8PA#ACJ
                        CT Number: PKUHC00WBFYBT9
                        build_id: 21WWCVCT602#SACJ#DACJ
                        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUbhcAdUdpdqfPguhKhkjhk8mEmwnVngpD.3n
                        MAC Address: C8-5A-CF-E4-88-F6
                        • sundarkanini
                          • Aug 2017
                          • 155
                          • india
                          #592
                          Originally posted by rex98
                          do not touch the EC
                          its worked thank u
                          • k3k5
                            • Mar 2024
                            • 6
                            can you unlock my hp elitebook 840 g8, please?
                            ProdID:16X35AV
                            • basalisco
                              • Mar 2024
                              • 17
                              • Italia
                              #594
                              Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
                              Flash this both main and EC its password and absolute unlocked. at first boot be patient. after identity recovered go-to bios reset security to defaults.
                              give feedback please..
                              Hi but can these files be flashed to any 840 g8?
                              I think I'm talking rubbish...but while I'm waiting for an 840 G8 to arrive with a bios password to unlock, I'll try to do my best! Sorry if I asked a stupid question. If I understand, do you need a dump of both the BIOS and the EC?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11733
                                #595
                                No and just need Bios or Ec.
                                • basalisco
                                  • Mar 2024
                                  • 17
                                  • Italia
                                  #596
                                  Thanks for your kind reply. I read the discussion from the beginning, especially post #9, and studied the original files with the patched ones. Furthermore, I also tried to patch some BIOS present here and make a comparison. I must say that I achieved an excellent result by comparing my patched files and yours do not present any difference. It still remains unclear to me why other values are also moved, while there is one that is not touched as in post #9. For me it's a professional deformation, I like to understand why, it's not enough for me to have someone do it for me. Thank you all for the valuable information on this forum and sorry for my bad English.
                                  • k3k5
                                    • Mar 2024
                                    • 6
                                    Can I find out the build_id and feature byte or recreate it?
                                    I no longer have this after a BIOS defect​
                                    • skylinekiller
                                      • Mar 2024
                                      • 3
                                      @hoaca388
                                      I have read through the posts, and unfortunately, it's still a little unclear. Do I need to purchase a programmer to remove/reveal the bios password, or are there files you provide to help identify or remove the password? I see people posting files, but how are they getting them if the BIOS are locked. If I do need to purchase a programmer, is there one you recommend where I don't have to remove the bios chip?
                                      • basalisco
                                        • Mar 2024
                                        • 17
                                        • Italia
                                        #599
                                        Originally posted by skylinekiller
                                        @hoaca388
                                        hi, not only do you need a programmer but the most important part is the disassembly of the PC and the IC that contains the BIOS inside, perhaps you should try to read up and do a better job of understanding what it means.
                                        • k3k5
                                          • Mar 2024
                                          • 6
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
