Extract bios password from EliteBook 840 G8 Bios dump, possible?
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules.
please help... unlock swat lock problem.
attached lock file.Comment
https://www.badcaps.net/donateComment
Help Please unlock password and disable absolute module? Thank you in advanced.
HP Elitebook 840 G8
SN# 5cg2273kfqAttached FilesComment
Good day pelase help me my HP 840 G8 is swat lock and BIOS might pasword as well. Thank you in advance..
SN# 5CG211466HAttached FilesComment
Help me unblock Absolute. I tried many methods, but it remains active.
ID V86UC#ABA
SN 5CG2131VHW
good day please help swat lock
s# 5CG21144Y1Attached FilesComment
Send to you, tryAttached FilesComment
first boot press f10 Apply factory defaults and exit, second boot reset security defaults and exit. use BCU input your DMI and you can permanently disable absolute there.
Serial Number: 5CG21144Y1
Product Number: 3K0M1UC#UUF
CT Number: PQSNL00WBGE53F
Description: HP EliteBook 840 G8 Notebook
build_id: 21WWCVET601#SUUF#DUUF
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwn7nVngpD.4g
MAC Address: A8-B1-3B-E9-D0-B9Attached FilesComment
I have a computer with administrator and absolute lock, could you help me? I tried to unlock it by comparing it with other files but it has an endpoint error
SN:5CG222503XAttached FilesComment
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by AhariHi all,
I...-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
Channel: BIOS Requests ONLY!
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
