IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • gabry120
    • Nov 2019
    • 38
    • italia
    #221
    Originally posted by hoaca388
    Laptop V15-ADA (Lenovo) - Loại 82C7
    Thanks, but unfortunately it doesn't work
    • hoaca388
      Badcaps
      • Jan 2022
      • 11711
      #222
      Check hardware, this is an origin bios.
      • notrespond
        • Apr 2024
        • 63
        • ID
        #223
        hello
        I have problem my old bios no display, i flashing with other bios display but always beep every second time.
        can rebuild my old bios attached.
        Lenovo Ideapad 3 14ADA05 81W0
        Board GS540/GS550/GS750 NM-C821 Rev 1.0
        SN : PF3FEG4N
        • hoaca388
          Badcaps
          • Jan 2022
          • 11711
          #224
          Originally posted by notrespond
          hello
          SN : PF3FEG4N
          IdeaPad 3-14ADA05 Laptop - Type 81W0
          • by_mex
            • Feb 2014
            • 57
            • turkey
            #225
            Originally posted by Atiq
            Re: Lenovo V15-ADA NM-D151 Rev 1.0
            Thank you it's working 100%
            thank you %100 Work
            • A1yn88
              • Mar 2014
              • 112
              • Romania
              #226
              Hello.
              Can you help me with this bios? Black screen problem.
              Ideapad 3 17ADA05 , Model 81W2
              SN: PF2LJHRH
              MTM: 81W20074RM
              Thank you.
                SMDFlea commented
                Editing a comment
                Post moved. See post 1 you can try to fix it yourself.
            • didoee
              • Apr 2019
              • 21
              • Bulgaria
              #227
              try
              Thank you very much, the laptop works correctly.
              • Pedro Ramírez
                • Jul 2024
                • 18
                • Chile
                #228
                Hola me podrían ayudar mi computador Lenovo Ideapad 315ada05 quedo en pantalla negra, queda encendado el disco duro, se enciende el fan cooler por el calor del cpu y el botón de encendido queda parpadeando. He investigado y veo que es la Bios corrupta.
                Si alguien me podría ayudar, lo agradecería mucho. Dejó aquí los datos del Notebook
                Ideapad 3 15ada05
                N/S: PF2BWHQ3
                MODELO: 81W1
                MTM: 81E11008CL
                Hello, could you help me? My Lenovo Ideapad 315ada05 computer has a black screen, the hard drive remains on, the fan cooler turns on due to the heat of the CPU and the power button keeps flashing. I have investigated and I see that the BIOS is corrupt.
                If someone could help me, I would really appreciate it. I left the Notebook data here​
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11711
                  #229
                  Ideapad 3 15ada05
                  N/S: PF2BWHQ3
                  MODELO: 81W1
                  MTM: 81E11008CL
                  English ,please.
                  • peste
                    • Dec 2016
                    • 12748
                    • ROMANIA
                    #230
                    Ideapad 3 15ada05
                    N/S: PF2BWHQ3
                    MODELO: 81W1
                    MTM: 81E11008CL
                    you have everything you need at #217.post..
                    • lhandzm
                      • Aug 2020
                      • 5
                      • philippines
                      #231
                      please help me model V15-ADA no display after bios upadate
                      S/N PF283EBN
                      MTM 82C7005RPH
                      FACTORY ID JVHFC1​
                      • peste
                        • Dec 2016
                        • 12748
                        • ROMANIA
                        #232
                        S/N PF283EBN
                        MTM 82C7005RPH
                        FACTORY ID JVHFC1​
                        post the original bios of the laptop even if it is corrupted.
                        • lhandzm
                          • Aug 2020
                          • 5
                          • philippines
                          #233
                          S/N PF283EBN
                          MTM 82C7005RPH
                          FACTORY ID JVHFC1
                          • lhandzm
                            • Aug 2020
                            • 5
                            • philippines
                            #234
                            THANKS
                            • peste
                              • Dec 2016
                              • 12748
                              • ROMANIA
                              #235
                              THANKS
                              you have everything you need at post 217
                              • lhandzm
                                • Aug 2020
                                • 5
                                • philippines
                                #236
                                S/N PF283EBN
                                MTM 82C7005RPH
                                FACTORY ID JVHFC1
                                heres my backup bin​
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11711
                                  #237
                                  S/N PF283EBN
                                  MTM 82C7005RPH
                                  FACTORY ID JVHFC1
                                  heres my backup bin
                                  V15-ADA Laptop (Lenovo) - Type 82C7
                                  • lhandzm
                                    • Aug 2020
                                    • 5
                                    • philippines
                                    #238
                                    thank you so much
                                    doesnt work still no display
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11711
                                      #239
                                      thank you so much
                                      Check hardware
                                      • biber
                                        • Feb 2015
                                        • 104
                                        • macedonia
                                        #240
                                        Hello ,
                                        i have tried methods from post #1 but obviously i cant fix it by myself. i will appreciate if someone can fix it for me. Symptoms are black screen after bios update....TNX
                                        Lenovo V14-ADA
                                        MODEL NAME: 82C6
                                        SN: PF23EAJW
                                        MTM: 82C600ERM​
                                          Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 05:00 AM
                                        • Patriarxis
                                          Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                          by Patriarxis
                                          Hello.
                                          I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                          It takes 0.027A and the power button flashing.
                                          All the voltages on the board are ok. 3.3, 5 etc.
                                          Also is charging the buttery .
                                          What else i can check?​
                                          05-26-2025, 01:03 AM
                                        • hotcrossedbuns999
                                          IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                          by hotcrossedbuns999
                                          First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                          Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                          05-21-2025, 05:59 PM
                                        • pcwhiz24
                                          Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                          by pcwhiz24
                                          Model: Lenovo IdeaPad 3 14ADA05 81W0
                                          S/N: PF2BZS7D
                                          I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                          I already have a CH341A programmer...
                                          04-07-2025, 07:10 PM
                                        • Visual_vt
                                          Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                          by Visual_vt
                                          Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                          SSD and BIOS seems to be OK.
                                          Thank you....
                                          12-30-2024, 09:14 AM
