IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Originally posted by greyn View Post
    I apologize. I received a photo, indeed one digit is extra. sn: PF22W3AK.
    V14-ADA Laptop (Lenovo) - Type 82C6
    Become a Badcaps supporter
    Thanks to all supporters.
      Thanks for the help, but it's not working yet. Without changes. I found another backup bios saved by the update program, even before the damage.
      Lenovo V14-ADA 82C6 SN PF22W3AK
        Originally posted by hoaca388 View Post
        IdeaPad 3 15ADA05 Laptop - Type 81W1
        Hi hoaca388 I tried this bios for lenovo 15ada05 but it doesn't work...or at least, the pc tries to start, enters windows but then freezes..the fan doesn't spin and if I connect the battery the pc doesn't start at all, it remains a black screen..I noticed that on the bios settings it tells me:
        MTM invalid
        Lenovo SN invalid
        UUID Invalid
        I also tried to enter windows and reflash the bios from the leonovo site, but it reports an error and doesn't let me proceed..
        I have a photo of the previous bios, could you possibly send me a bios with these characteristics?
        MTM 81W10033SP
        LENOVO SN PF25PH6P
        UUID 4DD69701-11EA-80DB-F875A4FDD4D5
        thanks a lot in advance
          MTM invalid
          Lenovo SN invalid
          UUID Invalid
          MTM 81W10033SP
          LENOVO SN PF25PH6P
          post the contents of the bios chip even if it is corrupted..
            i'dont have the original bios,i flash the bios with .bin posted by hoaca388
              Use the U1 gold key to fill in DMI info https://www.badcaps.net/forum/troubl...r-bootable-usb
                Hello, i got Lenovo V14-ADA with black screen . Lenovo V14-ADA Model: 82C6 S/N: PF2F7JFS MTM: 82C600DSCK Attaching original bios from notebook. Thanks for help in advance.
                  Everything you need is at post 1 and 12.
                    Hi guys, can you please repair or rebuild this bios? It is corrupted. I used one of bioses posted here to see if laptop will work. It does but SN and stuff sais INVALID.
                    Can someone use SN and stuff from old corrupted bios and create new?
                    Thank you
                      Thank you
                      Please read the updated rules sticky thread, the serial number must be posted with every bios request.
                      You can add your DMI using a script at post #1
                        SMDFlea sorry, I will read it.
                        SN: PF20RSXD , MTM: #2C70065CK
                        Laptop is Lenovo V15-ADA
                        Can you help, please? I am not really good at software side of things, I do not want to ruin something.
                          V15-ADA Laptop (Lenovo) - Type 82C7
                            Thank you so much
                              deaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
                              Hello ,
                              Please Clean BIOS key :
                              Lenovo V14-ADA
                              SN: PF20K206
                              MTM: 82C6005DRA
                              Please clear the BIOS key:
                                Hello ,
                                Lenovo V14-ADA
                                SN: PF20K206
                                MTM: 82C6005DRA
                                Flash from post #301
                                  not work
                                    not work
                                    what is your actual issue in laptop ?
                                      bios password
                                        bios password
                                        try,,
                                          Hello Guys.
                                          Can you help me with my BIos dump.
                                          The laptop is turning on but have no POST only black screen
                                          thank U
                                          Serial : PF2PQK7B
                                          FACTORY ID: JVHFC1
                                          MTM: 82C7008EYA
                                          MB GV451&GV551 NM-D151
                                          old bios
