IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • peste
    • 13915
    • ROMANIA
    #161
    Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Originally posted by bouny56
    Thanks for your help, same problem screen stay black
    at post #12 you have the bios from the Lenovo support page, at post #13 someone confirms that the bios works, so either you write the bios with errors, or the laptop has another problem..
    • esperanze84
      • Oct 2023
      • turkey
      #162
      hello
      lenovo v15-ada
      model name 82c7
      serino:pf20al1z
      updated version :BIOS Update for Windows 10 (64-bit) and Windows 11 (64-bit) - IdeaPad 3 14ADA05, IdeaPad 3 15ADA05, IdeaPad 3 17ADA05, V14-ADA, V15-ADA
      17.087 MB
      E8CN39WW
      My computer won't turn on after updating. power light is on , fan is working
      but there is no image on the screen
      help please
        • 22275
        Originally posted by esperanze84
        hello
        lenovo v15-ada
        model name 82c7
        serino:pf20al1z
        17.087 MB
        E8CN39WW
        help please
        Post your bios backup,you will need an SPI bios programmer to do that.
        https://www.badcaps.net/forum/showthread.php?t=103526
        • Tomy992
          • Sep 2019
          • 12
          • Bosnia and Hercegovina
          #164
          Hello guys,
          Can anyone help me, I tried to flash the bios, and make backup, but not one of these bin files didn't help me, and when I tried to write down the old bios it said buffer data doesn't mach SPI chip.
            • 22275
            Originally posted by Tomy992
            Hello guys,
            You must post the laptop serial number.Please read the updated rules.
            • Tomy992
              • Sep 2019
              • 12
              #166
              Sorry I didn't use the forum for long time ago
              SN: PF1AF93L
              MODEL: 82C7
              MTM: 82C7008ESC
              • peste
                • 13915
                • ROMANIA
                #167
                SN: PF1AF93L
                MODEL: 82C7
                MTM: 82C7008ESC
                you have everything you need for post #29
                https://www.badcaps.net/forum/showth...V15-ADA&page=2
                • sejid99412
                  • Oct 2023
                  • vitez
                  #168
                  Hello I have problem on laptop Lenovo serial motherboard
                  gv451&gv551 nm-d151 rev 1.0 after flashing, the ignition light on the keyboard does not respond?
                  • Techfixindia
                    • Jun 2020
                    • india
                    #169
                    Lenovo - v15-ada
                    s/n - pf22cd8l
                    ​gv451&gv551 nm-d151 rev 1.0 need bios pls help i dont have old bios
                    • onlyseries
                      • Mar 2016
                      • 14
                      • Italy
                      #170
                      https://download.lenovo.com/consumer...s/e8cn27ww.exe Version 27 has been removed by lenovo
                      Oldest version available now is 34 https://download.lenovo.com/consumer...s/e8cn34ww.exe
                      Guide: How to extract and edit a Lenovo Phoenix TDK Bios - https://www.badcaps.net/forum/showthread.php?t=80861
                      Add your own DMI from your backup using software and the attached CopyDMI script. Follow the Easy Guide
                      Guide: Copy DMI info easily with Hex editing software and Macro script - https://www.badcaps.net/forum/showthread.php?p=1214739
                      I'm a newbie with bios and I initially flashed the bios from post #14 and then I wanted to try to restore the serial number and model number which were invalid so I followed the guide but I'm not sure of the result.
                      I'm also not sure because if I try to flash the newbios.bin file I get the following error: "ERROR 233 - Only secured capsule is allowed on a SecureFlash system!"
                      Could someone more knowledgeable take a look at the files?
                      Thanks in advance
                      Lenovo V15-ADA
                      Model Name: 82C7
                      SN: PC20RX5T
                      MTM: 82C7007SIX
                      Mfg Dates: 2021/06/19
                      Factory ID: T
                      *I changed the extension to txt to be able to upload them
                        • 22275
                        The newbios you posted looks ok,the DMI is the same as your backup. You must flash newbios.bin with an SPI programmer .
                        • onlyseries
                          • Mar 2016
                          • 14
                          • Italy
                          #172
                          Thanks so much for checking, ok perfect I thought that by doing this I could flash the file directly with the WinFlash64 program.
                          I flashed the file with the programmer and it worked.
                          Thanks for your help and guides!
                            SMDFlea commented
                            Editing a comment
                            You`re welcome,happy to help
                        • Technosoft
                          Absolute Noob
                          • Jul 2023
                          • 7
                          • The worlds backyard
                          #173
                          Hello. I am having a black screen of death with my notebook.
                          Whenever I try to turn the thing on, it turns a really dim black light on the monitor but nothing shows up & all peripherals dont work. (Keyboard/HDMI Output ect.)
                          I figured it can definitely be a bad BIOS & I am certain Lenovo did efff my notebook by itself.
                          & I was right in my presumption. I read through the different posts in here and I found my solution from post #29.
                          I have backed up my faulty BIOS & applied the posted BIOS and until now everything is working pretty much faultlessly.
                          Was wandering, if I wanted to insert every other unique features to the laptop, can someone help me on getting all the SN & other unqie stuff?
                          I have used a cheap CH341A USB Programmer but with the modified version so it read 3.3V (from the Youtube video).
                          Lenovo V15-ADA
                          Model Name: 82C7
                          S/N: PF2S1A0L
                          MTM:82C70097IX
                          Wish you all the best!! You are doing splendid work!
                            SMDFlea commented
                            Editing a comment
                            Read posts 1,3 and 6 .Use the bios from 3 or 6 and add the SN etc using the CopyDMI script at post 1 .
                        • Zickko10
                          • Sep 2021
                          • 85
                          • Nigeria
                          #174
                          the lenovo laptop is not displaying
                          here is the info, board no and old bin
                          S/N:PF324X4
                          BOARD NO:GV451 GV551 NM-D151
                            SMDFlea commented
                            Editing a comment
                            Thread merged.
                            Next time please make sure there's no existing thread for your request before making a new one please.
                            You MUST:
                            Use search function in case someone already answered your request
                            Post under a related thread if it exists
                          • 22275
                          S/N:PF324X4
                          Read post 183.1 ,everything you need is right here in this thread.
                          • Zickko10
                            • Sep 2021
                            • 85
                            • Nigeria
                            #176
                            I didn't see any post 183.1 in this thread
                              SMDFlea commented
                              Editing a comment
                              Its just above your post number 184 .
                              "Read posts 1,3 and 6 .Use the bios from 3 or 6 and add the SN etc using the CopyDMI script at post 1 ."
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12438
                            #177
                            S/N:PF324X4
                            Check serial number again .
                            • Zickko10
                              • Sep 2021
                              • 85
                              • Nigeria
                              #178
                              here is the correct serial number
                              S/N:PF324X4X
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12438
                                #179
                                S/N:PF324X4X
                                You already have the new file, but where is the original bios file ?
                                • Zickko10
                                  • Sep 2021
                                  • 85
                                  • Nigeria
                                  #180
                                  Initially I observed the bios have been program by another repairer before
                                    Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                    09-07-2024, 05:00 AM
                                  • Patriarxis
                                    Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                    by Patriarxis
                                    Hello.
                                    I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                    It takes 0.027A and the power button flashing.
                                    All the voltages on the board are ok. 3.3, 5 etc.
                                    Also is charging the buttery .
                                    What else i can check?​
                                    05-26-2025, 01:03 AM
                                  • hotcrossedbuns999
                                    IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                    by hotcrossedbuns999
                                    First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                    Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                    05-21-2025, 05:59 PM
                                  • pcwhiz24
                                    Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                    by pcwhiz24
                                    Model: Lenovo IdeaPad 3 14ADA05 81W0
                                    S/N: PF2BZS7D
                                    I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                    I already have a CH341A programmer...
                                    04-07-2025, 07:10 PM
                                  • Visual_vt
                                    Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                    by Visual_vt
                                    Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                    SSD and BIOS seems to be OK.
                                    Thank you....
                                    12-30-2024, 09:14 AM
