IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • ZixuTech
    • Oct 2017
    • 90
    Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Any suggestions? Does it look like a BIOS issue?
    • lapfix
      • Mar 2020
      • 2765
      • my workshop
      #42
      post your issue here : https://www.badcaps.net/forum/forumdisplay.php?f=23
      • ZixuTech
        • Oct 2017
        • 90
        Originally posted by lapfix
        I did but SMDFlea moved it here. Still not sure if it is a BIOS issue. But lots of people report blinking Power Button light as one.
        • lapfix
          • Mar 2020
          • 2765
          • my workshop
          #44
          serial number !
          • ZixuTech
            • Oct 2017
            • 90
            Not listed on the case, and today is not firing up, just blinking power LED> Any other way i can locate it?
            • lapfix
              • Mar 2020
              • 2765
              • my workshop
              #46
              Re: Blinking Power Button on Lenovo IdeaPad 3 15ADA05 GS450/GS550&GS750 NM-C821 Rev 1
              Completely lost here. Have this Lenovo GS450/GS550&GS750 NM-C821 Rev 1.0, which turns on sometimes and works ok, and I can go to bios, although the power button is flashing.
              Other times it will just won't pull any current above 0.01A from the PSU, ON LED is lit up and the power button flashing.
              I have tried to flash this bios via SPI https://www.badcaps.net/forum/showth...ighlight=GS550 it fired up and informed that needs to reser nVRAM and wont keep TPM settings and just hanged there. After restart no picture as with the original bios.
              I have Reverted the original bios and loaded up at first when I resoldered the BIOS (i went to BIOS and reset to defaults), then on reboot won't turn on or will pull 0.6A but won't show any picture or keyboard response.
              I am attaching the DUMP in case you find issues with it.
              I must add, no liquid damage or corrosion on the board or foul play.
              Try and give feedback
              • ZixuTech
                • Oct 2017
                • 90
                Thanks for this. I have flashed it, seemed to load up with missing SN and windows key. But then every other time it will load with blackscreen and no response from keyboard. Sometimes will start with Fans spinning other times with no fans just black screen.
                Power button flashing seems to happen when the battery is not connected only now.
                • morganest
                  • Feb 2023
                  • Estonia
                  #48
                  I flashed latest E8CN36WW.exe and since then I see only blackscreen and spinning fan with HDD.
                  I know a guy with SPI flash programmer but I need to bring him ROM to flash. Otherwise he will kick me out.
                  Unfortunately I don't have backup of my rom.
                  Please kindly help me to bring laptop back to life.
                  However here is my data:
                  Model : Lenovo V15-ADA (82C7)
                  SN: PF20LM0L
                  MTM: 82C7000YRA
                  BIOS from lenovo: https://download.lenovo.com/consumer...s/e8cn36ww.exe
                  • peste
                    • 13653
                    • ROMANIA
                    #49
                    SN: PF20LM0L
                    MTM: 82C7000YRA
                    first go to the guy with the laptop... tell him to extract the content from your bios chip... post it here... someone will help you make a bios... after that back to guy to write it on your chip...
                    • DanielDacko
                      • Mar 2015
                      • 328
                      • Macedonia
                      #50
                      SN: PF20LM0L
                      MTM: 82C7000YRA
                      here you go buddy.
                      I don't provide help for people using CH341A and a clip.
                      • greewolf
                        • Apr 2018
                        • 9
                        • Ukraine
                        #51
                        Re: Lenovo V15-ADA NM-D151 Rev 1.0
                        Дякую ! Thanks !
                        • Kamertonas
                          • Feb 2022
                          • Lithuania
                          #52
                          Maybe somebody could help fix bios. All info attached.
                          IdeaPad 3 17ada05
                          SN PF263259
                          MTM 81W20017PB
                          • hardware1
                            • Sep 2021
                            • 2948
                            • N/A
                            #53
                            IdeaPad 3 17ada05
                            SN PF263259
                            MTM 81W20017PB
                            Here's your New BIOS file, it's a Virgin BIOS from Lenovo with your DMI.
                            all donations are welcome,
                            • dttamas
                              #54
                              I want to ask for help. The machine turns on, but there is no image. I have attached the original content and the data. I would like to request an improved content, thank you in advance!
                              IdeaPad 3 15ADA05
                              Model:81W1
                              SN:PF296KGM MTM:81W1001DHV
                              Thomas
                              • hardware1
                                • Sep 2021
                                • 2948
                                • N/A
                                #55
                                IdeaPad 3 15ADA05
                                Model:81W1
                                Thomas
                                Here's your New BIOS, it's a Virgin BIOS from Lenovo with your DMI.
                                • dttamas
                                  #56
                                  Thanks for the content, the device is up and running!
                                  • hardware1
                                    • Sep 2021
                                    • 2948
                                    • N/A
                                    #57
                                    It's good to know, You're Welcome.
                                    • felix38
                                      • Apr 2022
                                      • 7
                                      • türkiye
                                      #58
                                      Re: Lenovo V15-ADA NM-D151 BIOS please
                                      Originally posted by digix
                                      Dump from Lenovo V15-ADA , mainboard GV451&GV551 NM-D151 Rev:1.0 and BIOS exctracted from BIOS update.
                                      BIOS exctracted from BIOS update. thank you sooo much . you saved a life )
                                      • riher
                                        • Apr 2017
                                        • 23
                                        • ecuador
                                        #59
                                        Here's your new bios file, it's a virgin Bios from Lenovo with your DMI.
                                        funciona muy bien.. thank you
                                        • dclass-pro
                                          • Dec 2022
                                          • 157
                                          • Italy
                                          #60
                                          hello guys i tried all the bios and also modified the original with my DMI but nothing, it doesn't work i always have a black screen and a 300mA absorption can you help me??? here is my original bios attached.
                                          Thank you
                                            Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 05:00 AM
                                          • Patriarxis
                                            Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                            by Patriarxis
                                            Hello.
                                            I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                            It takes 0.027A and the power button flashing.
                                            All the voltages on the board are ok. 3.3, 5 etc.
                                            Also is charging the buttery .
                                            What else i can check?​
                                            05-26-2025, 01:03 AM
                                          • hotcrossedbuns999
                                            IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                            by hotcrossedbuns999
                                            First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                            Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                            05-21-2025, 05:59 PM
                                          • pcwhiz24
                                            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                            by pcwhiz24
                                            Model: Lenovo IdeaPad 3 14ADA05 81W0
                                            S/N: PF2BZS7D
                                            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                            I already have a CH341A programmer...
                                            04-07-2025, 07:10 PM
                                          • Visual_vt
                                            Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                            by Visual_vt
                                            Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                            SSD and BIOS seems to be OK.
                                            Thank you....
                                            12-30-2024, 09:14 AM
