IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • DanielDacko
    • Mar 2015
    • 329
    • Macedonia
    #61
    Re: Blinking Power Button on Lenovo IdeaPad 3 15ADA05 GS450/GS550&GS750 NM-C821 Rev 1
    Originally posted by ZixuTech
    Completely lost here. Have this Lenovo GS450/GS550&GS750 NM-C821 Rev 1.0, which turns on sometimes and works ok, and I can go to bios, although the power button is flashing.
    Other times it will just won't pull any current above 0.01A from the PSU, ON LED is lit up and the power button flashing.
    I have tried to flash this bios via SPI https://www.badcaps.net/forum/showth...ighlight=GS550 it fired up and informed that needs to reser nVRAM and wont keep TPM settings and just hanged there. After restart no picture as with the original bios.
    I have Reverted the original bios and loaded up at first when I resoldered the BIOS (i went to BIOS and reset to defaults), then on reboot won't turn on or will pull 0.6A but won't show any picture or keyboard response.
    I am attaching the DUMP in case you find issues with it.
    I must add, no liquid damage or corrosion on the board or foul play.
    Just note that some Lenovo laptops flash the power button when no battery is detected or battery is below 20%. I can probably create virgin file from official website, but you must provide me serial number, and be prepared to flash main bios and kbc controller as well. If you have the necessary tools for that, quote me with the serial number.
    I don't provide help for people using CH341A and a clip.
    • peste
      • 13915
      • ROMANIA
      #62
      Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
      Originally posted by dclass-pro
      hello guys i tried all the bios and also modified the original with my DMI but nothing, it doesn't work i always have a black screen and a 300mA absorption can you help me??? here is my original bios attached.
      Thank you
      try the bios from post #29
      https://www.badcaps.net/forum/showth...V15-ADA&page=2
      • dclass-pro
        • Dec 2022
        • 157
        • Italy
        #63
        Originally posted by peste
        done, same problem
        • peste
          • 13915
          • ROMANIA
          #64
          done, same problem
          if you wrote it correctly then you have another problem..
          • elopstopher
            • Philippines
            #65
            I want to ask for help. The machine turns on, but there is no image.
            V15-ADA Laptop (Lenovo) - Type 82C7
            Model:82C7
            SN:PF28629V MTM:82C7005RPH
              • 22275
              Model:82C7
              You can use the virgin bios from post #12 .To add your DMI (the serial number etc) from your backup you can find a text file at post #1 with the offsets to enter it manually with a hex editor, or you can use the attached CopyDMI script and some software,there`s a link to a Guide
              "Guide: Copy DMI info easily with Hex editing software and Macro script"
              • elopstopher
                • Philippines
                #67
                Thanks it works like magic :-D
                • maren1
                  • Feb 2022
                  • 20
                  • nigeria
                  #68
                  i need a working bios this lenovo v14 ADA
                  model name 82c6
                  S/N:PF2K4YPA
                  I believe they might have flash the bios before
                  the problem is it will power on but just bepping on the screen
                  here is the copy of bios i found in the system.
                    • 22275
                    model name 82c6
                    S/N:PF2K4YPA
                    Use the bios at post #55 .If it doesn`t work with that youve got a hardware problem.
                    • maren1
                      • Feb 2022
                      • 20
                      • nigeria
                      #70
                      ok sir i will try that
                        • 22275
                        You`re welcome
                        • maren1
                          • Feb 2022
                          • 20
                          • nigeria
                          #72
                          the bios file not work and is no longer bepping as it use to do. and is not a hardware related problem everything intact its just booting issue.
                          • rusovich
                            • Apr 2023
                            • 5
                            • arg
                            #73
                            i have a v15-ADA but show invalid
                            i download from lenovo but i flash it , not restore this data
                            mtm 82c70097sp
                            sn pf1we5w6
                            model 82c7
                            • hardware1
                              • Sep 2021
                              • 2949
                              • N/A
                              #74
                              mtm 82c70097sp
                              sn pf1we5w6
                              model 82c7
                              Upload your Original BIOS here.
                              all donations are welcome,
                              • rusovich
                                • Apr 2023
                                • 5
                                • arg
                                #75
                                https://*********/file/d/1bUqy-aQM8f...usp=share_link
                                Last edited by Vesko356; 04-13-2023, 07:19 AM. Reason: Link to external site removed
                                  • 22275
                                  You can use the bios from post #12 and add your own DMI info (seriel number etc) using the info at post #1 .Its essential though that you make a good backup.If you`re unsure if your original backup is good or not post it here on badcaps in a zip or rar ,don`t post it to an external site.If you didn`t make a backup before flashing another bios then you will have to use lenovo DMI tools, try the U1 tool https://www.badcaps.net/forum/showpo...43&postcount=5
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #77
                                    @rusovich - read forum rules!
                                    Originally posted by piernov
                                    You MUST:
                                    Become a Badcaps supporter
                                    Thanks to all supporters.
                                    • rusovich
                                      • Apr 2023
                                      • 5
                                      • arg
                                      #78
                                      u1 tootl show smi error
                                        • 22275
                                        I don`t know which dmi tool will work then. The bios you posted has no DMI, you could use the dmi from the bios at post #65 at least then you will have a working laptop with windows key
                                        • rusovich
                                          • Apr 2023
                                          • 5
                                          • arg
                                          #80
                                          the laptop show invalid this is the problem, the file is original backup of machine
                                            Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 05:00 AM
                                          • Patriarxis
                                            Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                            by Patriarxis
                                            Hello.
                                            I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                            It takes 0.027A and the power button flashing.
                                            All the voltages on the board are ok. 3.3, 5 etc.
                                            Also is charging the buttery .
                                            What else i can check?​
                                            05-26-2025, 01:03 AM
                                          • hotcrossedbuns999
                                            IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                            by hotcrossedbuns999
                                            First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                            Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                            05-21-2025, 05:59 PM
                                          • pcwhiz24
                                            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                            by pcwhiz24
                                            Model: Lenovo IdeaPad 3 14ADA05 81W0
                                            S/N: PF2BZS7D
                                            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                            I already have a CH341A programmer...
                                            04-07-2025, 07:10 PM
                                          • Visual_vt
                                            Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                            by Visual_vt
                                            Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                            SSD and BIOS seems to be OK.
                                            Thank you....
                                            12-30-2024, 09:14 AM
