IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
  • hotcrossedbuns999
    • Jan 2024
    • 17
    First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
    Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN file from the CAP file.
    (https://www.badcaps.net/forum/troubl...ulty-bios-dump)
    I'd appreciate if someone could tell me what I'm doing wrong or extract the BIN from the good bios so that I could flash with my CH341A Programmer.
    • 21841
    Type the laptop serial number, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    • hotcrossedbuns999
      • Jan 2024
      • 17
      So sorry.
      MODEL: Lenovo Ideapad 1
      14ADA05
      TYPE: 82GW001CUS
      S/N: R912XLMJ
      MOBO: S150ADA MB / 19877-1 / 448.0M302.0011 (I don't know which info you needed.)
      MOBO Lenovo P/N: 5B20Z26469
      • AHSAN TARIQ
        • Jan 2025
        • 73
        • Pakistan
        hello bro this file is ready
        • hotcrossedbuns999
          • Jan 2024
          • 17
          BRO!!! It worked the first time!! I've had this bricked craptop for ages and just found it. I wanted to try one more time to get it running and I failed. You're the GOAT!!! THX
          PS: You don't have to, but I'd really like to know how you did what you did. Thx
          • AHSAN TARIQ
            • Jan 2025
            • 73
            • Pakistan
            i dont understand what do you say please tell me in simple word
            • ManoloSanchez
              Smol Programer
              • Jun 2025
              • Mexico
              Bro, can you send me the file from another link? the one from Ahsan don't work for me it gives me a "Invalid File Specified" page, I have the same problem with my laptop and I need to test this too, maybe upload the file on google drive and share the link? Please.
              • hotcrossedbuns999
                • Jan 2024
                • 17
                The link still works. It might have been offline when you tried. Try again or try another browser. Also, I don't know if you can use the same bios as mine. 🤷‍♂️
                • Sebastian Codrean
                  BIOS file for ASUS F542UN laptop
                  by Sebastian Codrean
                  Hello to all of you! I need help with a BIOS file.
                  The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                  So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                  02-20-2025, 10:25 AM
                • m1ch43lzm
                  by m1ch43lzm
                  Hi everyone
                  09-06-2025, 05:47 PM
                • Jogger9663
                  Flex 5-14ITL05 Laptop (ideapad) - Type 82HS bricked after BIOS update
                  by Jogger9663
                  Hello all! New here, trying to fix a Lenovo Flex 5 14ITL05 laptop.
                  TL;DR: How do you connect a programmer to a "leg-less" SPI Flash chip? Model: Winbond W25R256JVEIQ on a board with part number 5B21B33119.
                  Attached are photographs of the board for context. One is of the SPI chip close-up, the other is of the full board with the chip highlighted.
                  I have a Lenovo Flex 5 14-ITL05 with the following symptoms following a BIOS update:
                  • Black screen / no display
                  • Caps lock indicator stuck ON
                  • Power LED blinking
                  • FN Lock key on at boot, but can be toggled
                  12-14-2022, 02:12 PM
                • Loli Popu
                  DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                  by Loli Popu
                  Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                  12-13-2024, 03:28 AM
                • iZakre
                  HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                  by iZakre
                  Hello everybody!
                  To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                  The thing is that I had installed TeamViewer and could log into the computer...
                  02-19-2023, 02:27 PM
