IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
Hello. There is a device with a motherboard code NM-D151 REV1.0. After updating the bios it stays on the black screen. It draws 0.6a. the fan spins and stops. Unfortunately, there is no label on the bottom of the computer with the serial number
I have no chance to reach the serial number and mtm code. I made the DMI section between 1000 and 2FFF mentioned in the forum, but the situation did not change. Please help me...
Attached FilesComment
Try the bios in post #12, transfer "DMI section between 1000 and 2FFF" from your bios backup.Hello. There is a device with a motherboard code NM-D151 REV1.0. After updating the bios it stays on the black screen. It draws 0.6a. the fan spins and stops. Unfortunately, there is no label on the bottom of the computer with the serial number
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
I had a problem after windows 11 bios update. I tried multiple bios but the problem was always the same. It was drawing a constant 0.6A current. Bios chip is broken. I changed it and the problem was solved. good work everyone
Same problem here, Lenovo 14-ADA PCB:NM-D151
Dumped Bios an EC , followed directions on post #1 with latest update from web (e8cn39ww),
added DMI data from dump = No POST/ black screen
Erased EC with IO programmer, reboot = No POST / black screen
reboot again and dump again EC to check data CRC of EC firmware.
EC ROM image copied from BIOS address 0x2C8000 len 0x20000 to EC exactly.
Will check with old versions posted in this thread (36 and 38) but it seems HW issue.Comment
Greetings to all,
I have my original BIOS that doesn't work
BIOS dump: Lenovo V15-ADA
SN: PF3JT6ZD
MTM: 82C7S03N00
Can anybody help me please?
Thanks in advanceAttached FilesComment
Factory image.Attached FilesI don't provide help for people using CH341A and a clip.Comment
Use the bios from post #129 ,before you flash it transfer your serial number (DMI) from your backup to the new one,you can use the CopyDMI script at post #1 to do that, see the README text file.
.Comment
I have already transferred my serial number (DMI) from my backup to the new one... manually with Tiny Hexer, the script didn't work for me... even so, I still don't have video.. not if any procedure of mine is wrong made..Comment
Good morning. I have a small problem laptop Lenovo ideapad 3 15ADA05 Model 81w1 NS PF2B06SQ MTM 81W1006YTPB. Black screen after bios update. the laptop came to me after another service and I do not know if it is the original bios from him in the connector. sorry for mistakes but i don't know english i use tlanslatorAttached FilesComment
try post #12, #31... DMI is at post #1...Good morning. I have a small problem laptop Lenovo ideapad 3 15ADA05 Model 81w1 NS PF2B06SQ MTM 81W1006YTPB. Black screen after bios update. the laptop came to me after another service and I do not know if it is the original bios from him in the connector. sorry for mistakes but i don't know english i use tlanslatorDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
I make it in another way... Extracted BIOS.bin file from executable bios upgrade file simple with 7z, renaming extension to zip...
Then I make LENOVO bios dump from chip with all data on it. I made diff and see many differences in that files... I didn't know where which block in rom are... When I read DMI map file where are SERIAL NUMBERS and etc I just simple manualy made new bios.bin file and flashed it.
Flash I made from 5th or 6th try as bios chip verification was failed. (When I make bios update with executable file from Windows I see that there was errors too, but it was too late to stop it anyhow.
Now I have seems everything in its places, but not understand something...
Watched your photo... From address 0x20h to address 0x598h I have some variables or something, what I don't have in new bios chip... Can it be some SLIC info or something (I don't remember was there a SLIC or not)?
Maybe someone know more about bios map address of that machine?Comment
Hi guys.
I have this Lenovo NM-D151 it updated the bios and bricked not showing a picture. I tried a few from this forum but none worked. The board is GV451&GV551 Rev:1.0.
Any advice would be appreciated
Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
Provide a BIOS/EC dump if possible
.Comment
Greetings to all members! I need help with the repair. It's a Lenovo IdeaPad3 V15-ADA laptop and its problem is the same that it works but there's nothing on the screen, caps and numlock keys also don't light up. I've programmed the eeprom with multiple bios files but nothing changes... The board was inspected and I found nothing, there is no short circuit on transistors or etc... Can anyone check this original bios of his if it is damaged in some way or etc... Thank you all for your help.
No itegraded RAM.
IdeaPad3 V15-ADA
Model Name - 82C7
S/N PF2ARM2M
MTM82C7008ESCAttached FilesComment
Get from Lenovo home pageGreetings to all members! I need help with the repair. It's a Lenovo IdeaPad3 V15-ADA laptop and its problem is the same that it works but there's nothing on the screen, caps and numlock keys also don't light up. I've programmed the eeprom with multiple bios files but nothing changes... The board was inspected and I found nothing, there is no short circuit on transistors or etc... Can anyone check this original bios of his if it is damaged in some way or etc... Thank you all for your help.
No itegraded RAM.
IdeaPad3 V15-ADA
Model Name - 82C7
S/N PF2ARM2M
MTM82C7008ESCAttached Files↵
https://www.badcaps.net/donateComment
Thanks! Now the laptop is up and running but after 5 seconds the screen start flickering and loosing picture, only white screen, any advice...?Attached FilesComment
Hi everyone.
My laptop problem is solved for now. What I'm writing now is my experience with the mentioned motherboard, which does not mean that it might help someone else, and whoever does it will do so at their own risk.
After I programmed the bios, the laptop worked for about 5 seconds, but then the image on the screen started flickering and then went to a completely white screen, which made me suspect a bad solder connection when the processor was heating up. The motherboard ended up in the oven and after baking the motherboard working perfectly...Comment
This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 05:00 AM
by PatriarxisHello.
I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
It takes 0.027A and the power button flashing.
All the voltages on the board are ok. 3.3, 5 etc.
Also is charging the buttery .
What else i can check?05-26-2025, 01:03 AM -
First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...-
Channel: BIOS Requests ONLY!
by pcwhiz24Model: Lenovo IdeaPad 3 14ADA05 81W0
S/N: PF2BZS7D
I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
I already have a CH341A programmer...-
by Visual_vtLenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
SSD and BIOS seems to be OK.
Thank you.... - Loading...
