IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
Every donation made will go towards server fees and maintenance costs. -
good morning I'm new
v15-ada model
gv451&gb551 nm-d151
s/n PF30FQXZ
The notebook turns on but the screen remains black
I extracted the original bios
can someone help me? A thousand thanksComment
Every donation made will go towards server fees and maintenance costs.Comment
Bios extracted from Lenovo website update for IdeaPad 3 14ADA05, IdeaPad 3 15ADA05, IdeaPad 3 17ADA05, V14-ADA, V15-ADA
DMI 1000 - 2FFFAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
the bios you posted has 4MB...it should have 8MB, so you write and read it with errors...and because of this it doesn't work...remove the bios chip from the motherboard before writing or reading. ..if you don't have anything to stick wires between the chip and the programmer..don't use clipsil because it gives errors..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
tested file ok
Attached FilesComment
Hi
My screen went black and I downloaded a bios from this topic. It is working perfectly. >) . However, I do not know now the original serial number and other data as the label from the bottom of the laptop is gone. I hope someone can help me to extract the data from the dead bios and inject it into the working one. I attached both.
 thx
viewHi
 thxAttached FilesComment
Hi, I have a Lenovo V15-ADA laptop that will turn on but nothing else. I have checked around the board all seems ok, so I wanted to try a new bios. If possible could someone have a look at this for me, I have attached a zip file with the original bios and the laptop serial number. Any help would be appreciated. ThanksAttached FilesComment
Everything you need is in this thread,start by reading post 1 .Also the serial number must be typed and posted, please read and familiarise yourself with the rules
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
I have a black screen, power button blinking with my Lenovo 17ADA05.
I have tried to flash a new bios with DMI data but I have the same problem.
Can you provide to me a corrected bios ?
SN: PF2K9A2R
MTM : 81W20059FR
Factory ID : JVHFC1
MP : PF9XB1116193
Thank you !Attached FilesComment
check the virgin bios extracted from lenovo support first if you get image than further dmi will see laterHello,
SN: PF2K9A2R
MTM : 81W20059FR
Factory ID : JVHFC1
MP : PF9XB1116193
Thanks for your reply.
I have flashed that bios but I have the same problem..
EDIT : I have only black screen, power button light on. I have tried with novo button but that is the same problemComment
If you have made a good backup using an SPI programmer then you have everything you need in this thread.
https://www.badcaps.net/forum/troubl...51#post1808151
https://www.badcaps.net/forum/troubl...post3237606
If you`re unsure if your backup is good or not post it and someone will help.
Good morning everyone, I have a problem with my Lenovo, it turns on but the screen remains black and caps lock doesn't work. I tried some loaded bios and also the procedure described in the first post. Could someone help me figure out if I'm doing something wrong? Thanks a lot to everyone
Ideapad V15 ADA
model: 82C7
SN: PC20RVW8
MTM: 82C7007SIX
Motherboard : GV451&GV551 NM-D151
Laptop V15-ADA (Lenovo) - Loại 82C7Good morning everyone, I have a problem with my Lenovo, it turns on but the screen remains black and caps lock doesn't work. I tried some loaded bios and also the procedure described in the first post. Could someone help me figure out if I'm doing something wrong? Thanks a lot to everyone
Ideapad V15 ADA
model: 82C7
SN: PC20RVW8
MTM: 82C7007SIX
Attached Files↵
https://www.badcaps.net/donateComment
			This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 05:00 AM
			by PatriarxisHello.
I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
It takes 0.027A and the power button flashing.
All the voltages on the board are ok. 3.3, 5 etc.
Also is charging the buttery .
What else i can check?05-26-2025, 01:03 AM -
			First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...-
							Channel: BIOS Requests ONLY!
			by pcwhiz24Model: Lenovo IdeaPad 3 14ADA05 81W0
S/N: PF2BZS7D
I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
I already have a CH341A programmer...-
			by Visual_vtLenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
SSD and BIOS seems to be OK.
Thank you.... - Loading...
