IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • peste
    • 13451
    • ROMANIA
    #321
    Originally posted by Dantepg
    Hello Guys.
    Can you help me with my BIos dump.
    The laptop is turning on but have no POST only black screen
    thank U
    Serial : PF2PQK7B
    FACTORY ID: JVHFC1
    MTM: 82C7008EYA
    MB GV451&GV551 NM-D151
    old bios
    post full name and model,
    • Dantepg
      • Jan 2023
      • 10
      • Montenegro
      #322
      V15-ADA Laptop (Lenovo) - Type 82C7
      Machine Type Model
      82C7008EYA​
      • hoaca388
        Badcaps
        • Jan 2022
        • 12280
        #323
        Machine Type Model
        82C7008EYA
        • Dantepg
          • Jan 2023
          • 10
          • Montenegro
          #324
          Thank You but I have same problem. The monitor gives a backlight for a second and than everything goes black.
          Thank you for your efort. Obviosly, there is a problem somewhere else.
          • infoner
            • May 2018
            • 9
            • SPAIN
            #325
            Greetings to all,
            i have my originall bios which is not working, Black Screen and No Fan only white Power Led ON
            BIOS Dump : Lenovo V14-ADA
            SN: PF2J0G92
            MTM: 82C6006CSP
            Model Name: 82C6
            Can please someone help me?
            Thanks in advance​
            • hoaca388
              Badcaps
              • Jan 2022
              • 12280
              #326
              Originally posted by infoner
              Greetings to all,
              SN: PF2J0G92
              MTM: 82C6006CSP
              Model Name: 82C6
              Thanks in advance
              V14-ADA Laptop (Lenovo) - Type 82C6
              • malico
                • Apr 2025
                • Aguaytia
                #327
                Lenovo V15-ADA Laptop
                Model name: 82C7
                SN: PF2BW4BC
                MTM: 82C70041LM
                BIOS FROM LENOVO WEB PAGE: laptops and netbooks :: lenovo v series laptops :: v15 adacontentdetail - Lenovo Support US
                I was updating my laptop's BIOS. In the middle of the process, the screen went black, and unfortunately I restarted the computer. After that, it won't turn on anymore. I've read that it can be recovered if I reflash it. I've tried several methods but haven't been able to get the correct BIOS file. This community (GUIDE-How-to-extract-BIOS-from-Lenovo-BIOS-Update-Package-such-as-ATCN37WW-exe - English Community - LENOVO COMMUNITY) explains how to extract the correct BIOS from the original file on the Lenovo website, but it didn't work for me. Hex files and assembly code aren't my thing.
                Finally, I understand that if I get the basic BIOS file and run it from a USB drive, I have the possibility of recovering my laptop, just as mentioned in this guide (I-need-to-recovery-corrupted-BIOS-for-LENOVO-YOGA-500-15IHV - English Community - LENOVO COMMUNITY). One last question: The BIOS file must have an fd, bin, or some special extension to run correctly. Please help me.
                • lapfix
                  • Mar 2020
                  • 2756
                  • my workshop
                  #328
                  Originally posted by malico
                  Model name: 82C7
                  SN: PF2BW4BC
                  MTM: 82C70041LM
                  AS mention in the guide : .bin
                  if you can't have .bin...than post your old dump and the serial and someone will help you
                  • alphaVII
                    • Jun 2022
                    • France
                    #329
                    Hi All
                    I have an IdeaPad 3-17ADA05 -
                    Serial PF206XN8
                    Model 81W2 -
                    MTM 81W20056FR
                    that presented errors that seeme d to indicate onboard RAM issue.
                    I tried to disable the onboard ram following the instructions here [ solder-desolder resistors] but had no boot
                    I copied the DMI info to a downloaded Bios Bin as per this link
                    https://www.badcaps.net/forum/troubl...pt#post1214739
                    and got a boot ,but the system crashes with ACPI error after 5 minutes every time.
                    Attached is the original Bios Dump and the one that sort of worked
                    Thanks in advance
                    • peste
                      • 13451
                      • ROMANIA
                      #330
                      Originally posted by alphaVII
                      Hi All
                      Serial PF206XN8
                      Model 81W2 -
                      MTM 81W20056FR
                      Thanks in advance
                      you have everything you need at post #29..
                      https://www.badcaps.net/forum/troubl...-15ada05/page3
                      for DMI information..
                      the bios from post # 29 is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
                      select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
                      • alphaVII
                        • Jun 2022
                        • France
                        #331
                        Hi Peste,
                        Thanks a lot for you answer, I will check right away
                        Does anything needs to be changed in the bios if i disable the onboard ram via the resistors ? I could not be sure of it.
                        • peste
                          • 13451
                          • ROMANIA
                          #332
                          Hi Peste,
                          try the bios first. see what happens..you can use post #29 without DMI changes...
                          • DanielDacko
                            • Mar 2015
                            • 326
                            • Macedonia
                            #333
                            Hi All
                            Serial PF206XN8
                            Model 81W2 -
                            MTM 81W20056FR
                            Thanks in advance
                            Here is latest bios with your DMI information, but the problem isn't in the bios, it's in the CPU soldering. Reflow the CPU. This is known issue on those thin Lenovo boards.
                            I don't provide help for people using CH341A and a clip.
                            • Sayidah
                              • Dec 2023
                              • 12
                              • Indonesia
                              #334
                              thank you
                              • pblenov541
                                • May 2025
                                • 5
                                I flashed the bios of my lenovo 15ADA05 with the latest bios available on lenovo. Unfortunately, after the installation procedure with continuous sounds, I had a black screen and tried to restart. Then the computer remained with a black screen on reboot and the fan running normally. Impossible to launch the bios. So I dismantled the computer and tried flashing with cha341. I was able to read the current bios and saved it. I tried to rewrite on it with a bios found on bios archive but it doesn't work.
                                Here is the information to help me get a dmi and a blank bios to remake a bios with a custom dmi:
                                Ideapad 3 15ADA05
                                MODEL name: 81w1
                                SN: PF3NTMCG
                                MTM: 81W1002GFR
                                • peste
                                  • 13451
                                  • ROMANIA
                                  #336
                                  Ideapad 3 15ADA05
                                  MODEL name: 81w1
                                  SN: PF3NTMCG
                                  MTM: 81W1002GFR
                                  you have everything you need at post #1,and12...
                                  • pblenov541
                                    • May 2025
                                    • 5
                                    • antiogu
                                      • Mar 2014
                                      • italy
                                      #338
                                      Hi everyone
                                      i have a lenovo V15-ADA
                                      Model 82C7
                                      Serial PF2CZ1AN
                                      MTM 82C7S00B00
                                      after updating the bios the LEDs light up, the fan spins but nothing else happens, i saved my bios can you help me?​
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12280
                                        #339
                                        Originally posted by antiogu
                                        Hi everyone
                                        Model 82C7
                                        Serial PF2CZ1AN
                                        MTM 82C7S00B00
                                        Here
                                        • peste
                                          • 13451
                                          • ROMANIA
                                          #340
                                          Hi everyone
                                          Model 82C7
                                          Serial PF2CZ1AN
                                          MTM 82C7S00B00
                                          you have everything you need at post #341...
                                            Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 05:00 AM
                                          • Patriarxis
                                            Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                            by Patriarxis
                                            Hello.
                                            I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                            It takes 0.027A and the power button flashing.
                                            All the voltages on the board are ok. 3.3, 5 etc.
                                            Also is charging the buttery .
                                            What else i can check?​
                                            05-26-2025, 01:03 AM
                                          • hotcrossedbuns999
                                            IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                            by hotcrossedbuns999
                                            First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                            Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                            05-21-2025, 05:59 PM
                                          • pcwhiz24
                                            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                            by pcwhiz24
                                            Model: Lenovo IdeaPad 3 14ADA05 81W0
                                            S/N: PF2BZS7D
                                            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                            I already have a CH341A programmer...
                                            04-07-2025, 07:10 PM
                                          • Visual_vt
                                            Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                            by Visual_vt
                                            Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                            SSD and BIOS seems to be OK.
                                            Thank you....
                                            12-30-2024, 09:14 AM
