IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • indyga
    • Jul 2020
    • 42
    • Greece
    Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Thank you sir.... I will programm it tommorow and let you know....
    • Donbellozi
      • Dec 2022
      • SU
      I ask for help.
      Unsuccessfully officially updated the bios.
      Lenovo-V14-ADA
      SN: PF2ME3HR
      MTM: 82C6006DRU
      I really hope that I trimmed the file correctly.
      • peste
        • 13436
        • ROMANIA
        Originally posted by Donbellozi
        I ask for help.
        Lenovo-V14-ADA
        SN: PF2ME3HR
        MTM: 82C6006DRU
        try post #12... at post #1 you have DMI...
        • hardware1
          • Sep 2021
          • 2946
          • N/A
          I ask for help.
          Lenovo-V14-ADA
          SN: PF2ME3HR
          MTM: 82C6006DRU
          Your file is identical to the official virgin bios, so it should works fine.
          all donations are welcome,
          • Boris_k77
            • Sep 2018
            • Kazahstan
            Re: Lenovo V15-ADA NM-D151 Rev 1.0
            Dump working Thank you very much
            • andideve
              • Jan 2023
              • Indonesia
              #26
              is this for lenovo v14-ada? can i use eprom programmer to flash?
              • peste
                • 13436
                • ROMANIA
                #27
                if you have the name and model of the laptop as in this thread ... see post #23 ... don't forget before writing the bios chip, to make a copy of the original bios of the laptop..
                • selpa8
                  • Jan 2023
                  Lenovo IdeaPad 3 15ADA05 - W25Q64FW_1.8V
                  If anyone has a working W25Q64FW_1.8V bin for Lenovo IdeaPad 3 15ADA05 (PF2ZBYDY) please share. Attached is the existing one I read.
                  • hardware1
                    • Sep 2021
                    • 2946
                    • N/A
                    #29
                    Re: Lenovo IdeaPad 3 15ADA05 - W25Q64FW_1.8V
                    Originally posted by selpa8
                    If anyone has a working W25Q64FW_1.8V bin for Lenovo IdeaPad 3 15ADA05. Please share. Attached is the existing one I read.
                    Write your Serial Number.
                    • selpa8
                      • Jan 2023
                      Serial: PF2ZBYDY
                      • hardware1
                        • Sep 2021
                        • 2946
                        • N/A
                        #31
                        Here's your New Bios file, it's a Virgin Bios from Lenovo with your DMI.
                        • selpa8
                          • Jan 2023
                          Thanks, but didn't work (no post, no logo, novo button doesn't work).
                          • hardware1
                            • Sep 2021
                            • 2946
                            • N/A
                            #33
                            It's a Virgin Bios it should works fine, maybe you have something else (Hardware Issue).
                            • CatPicture
                              • Jan 2023
                              • Deutschland
                              #34
                              IdeaPad3 15ADA05 bricked after Bios Update
                              Subject: Bricked Lenovo IdeaPad 15ADA05 after BIOS update - SN PF2NSx4y
                              I need help with my bricked Lenovo IdeaPad 15ADA05 (SN: PF2NSx4y). I've tried turning it off and on, disconnecting the CMOS battery, and all the other standard fixes for 5 hours now and nothing is working.
                              I need a solution to this problem, otherwise this laptop is just a paperweight. Can someone help me out here?
                              • peste
                                • 13436
                                • ROMANIA
                                #35
                                Re: IdeaPad3 15ADA05 bricked after Bios Update
                                post the original bios of the laptop..
                                • CatPicture
                                  • Jan 2023
                                  • Deutschland
                                  #36
                                  How can i upload the Bios of my Laptop? i cant even turn it on.Just the Fan is Running and the Power LED is lid.
                                    • 21690
                                    Did you try pressing in the NOVO button ? .If that hasn`t worked besides the other standard fixes then your only option is to program the bios. If you don`t think its something you can do yourself take it to a repair shop
                                    • indyga
                                      • Jul 2020
                                      • 42
                                      • Greece
                                      #38
                                      Here's your new bios file, it's a virgin Bios from Lenovo with your DMI.
                                      Thank you sir it's ok
                                      • hardware1
                                        • Sep 2021
                                        • 2946
                                        • N/A
                                        #39
                                        Good to know, You're Welcome.
                                        • ZixuTech
                                          • Oct 2017
                                          • 90
                                          Blinking Power Button on Lenovo IdeaPad 3 15ADA05 GS450/GS550&GS750 NM-C821 Rev 1.0
                                          Completely lost here. Have this Lenovo GS450/GS550&GS750 NM-C821 Rev 1.0, which turns on sometimes and works ok, and I can go to bios, although the power button is flashing.
                                          Other times it will just won't pull any current above 0.01A from the PSU, ON LED is lit up and the power button flashing.
                                          I have tried to flash this bios via SPI https://www.badcaps.net/forum/showth...ighlight=GS550 it fired up and informed that needs to reser nVRAM and wont keep TPM settings and just hanged there. After restart no picture as with the original bios.
                                          I have Reverted the original bios and loaded up at first when I resoldered the BIOS (i went to BIOS and reset to defaults), then on reboot won't turn on or will pull 0.6A but won't show any picture or keyboard response.
                                          I am attaching the DUMP in case you find issues with it.
                                          I must add, no liquid damage or corrosion on the board or foul play.
                                            Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 05:00 AM
                                          • Patriarxis
                                            Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                            by Patriarxis
                                            Hello.
                                            I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                            It takes 0.027A and the power button flashing.
                                            All the voltages on the board are ok. 3.3, 5 etc.
                                            Also is charging the buttery .
                                            What else i can check?​
                                            05-26-2025, 01:03 AM
                                          • hotcrossedbuns999
                                            IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                            by hotcrossedbuns999
                                            First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                            Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                            05-21-2025, 05:59 PM
                                          • pcwhiz24
                                            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                            by pcwhiz24
                                            Model: Lenovo IdeaPad 3 14ADA05 81W0
                                            S/N: PF2BZS7D
                                            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                            I already have a CH341A programmer...
                                            04-07-2025, 07:10 PM
                                          • Visual_vt
                                            Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                            by Visual_vt
                                            Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                            SSD and BIOS seems to be OK.
                                            Thank you....
                                            12-30-2024, 09:14 AM
