IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • zetz
    ZETZ
    • Jan 2022
    • 7
    • colombia
    #361
    Originally posted by Maxpower3
    Serial number /model type etc .........
    Respect rules please
    I found this in bios update but not sure if it works
    Thanks a lot, my friend. I'll try it and let you know if it works. Sorry about the rules, I'll keep them in mind for future occasions.
    Thanks.​
    • gandz1234
      • Nov 2019
      • 7
      • Poland
      #362
      Originally posted by doivaythoiem
      Try And Feeback
      Thank you but still the same problem, black screen and no fan spin. Also CPU is not getting hot.
      • doivaythoiem
        • Jun 2024
        • 124
        • Việt Nam
        #363
        try
        • gandz1234
          • Nov 2019
          • 7
          • Poland
          #364
          try
          Thank you for another file. I have cutted it and added my DMI but still the same fault.
          • delhadimcs
            • Jun 2025
            • Morocco
            #365
            try
            this one works well and easy trick for me on lenovo v15 ada if you experience black screen issue or facing obstacles loading defualt bios keys heres the only method that works perfectly on semibricked bios not yet tested on bricked bios .
            1. download https://www.badcaps.net/filedata/fetch?id=3647825
            2. extract file
            3. name the extracted bin file E8Crisis.bin
            4. drop the file named E8Crisis.bin on fat32 usb drive formatted mbr or gpt try both for most laptops start with mbr format then try gpt
            5. turn off laptop
            6. unplug charger
            7. insert usb
            8. press and hold Fn+R
            9. plug charger while holding Fn+R a red light should start blinking on the left side of the laptop
            10. while holding Fn+R press power button to turn on the laptop
            11.if everything goes as instructed your screen will go back and a bios flashing process will show up on it
            12. release Fn+R wait a few minutes for the process to end and pc will go back to normal
            13. once done and booted to windows install the latest bios available on lenovo website
            14 load default setting in bios
            thanks to gandz1234​ for bin file im thankful people like you exist for real man
            • totof
              • Feb 2017
              • 168
              • france
              #366
              I have a Lenovo Ideapad 3 14ADA05 with a unknown bios password that a want to remove
              I pulled the bin file off the bios chip but I can't seem to find where the password is located to translate it from a hex editor.
              Any help would be greatly appreciated. Thanks!
              Lenovo 14ADA05
              Model: 81W0
              SN: PF1WYGYW
              Motherboard : UMA AMD Ryzen 3 3250U 5B20S44284 - GS450&GS550&GS750 NM-C821 Rev 1.0
              Bios version : E8CN41WW​
              • totof
                • Feb 2017
                • 168
                • france
                #367
                Lenovo 14ADA05
                Model: 81W0
                SN: PF1WYGYW
                I have found Password string in binary file (offset 0x00310529) and set to 0x00 somme bytes inspired by another patch I found on the site but it didn't change anything. In the example I found there were two Passwords to patch, for me only once.
                • peste
                  • 13439
                  • ROMANIA
                  #368
                  try...
                  • totof
                    • Feb 2017
                    • 168
                    • france
                    #369
                    Originally posted by peste
                    try...
                    Thank you peste but it doesn't work, password is still here.
                    • hardware1
                      • Sep 2021
                      • 2946
                      • N/A
                      #370
                      Lenovo 14ADA05
                      Model: 81W0
                      SN: PF1WYGYW
                      Here is your Unlocked file, try it.
                      all donations are welcome,
                      • totof
                        • Feb 2017
                        • 168
                        • france
                        #371
                        Excellent, it works fine !!! Thank you hardware1.
                        • hardware1
                          • Sep 2021
                          • 2946
                          • N/A
                          #372
                          Great, you're welcome
                          • amitswami
                            Delhi
                            • Aug 2021
                            • 53
                            • rajasthan
                            #373
                            GV451&GV551 NM-D151 REV-1.0
                            MODEL NAME- LENOVO V15-ADA (82C7)
                            S/N - PF2E2LST
                            MTM - 82C7A006IH
                            MO-PF9XB0808007
                            This motherboard bios ic is missing please mack a bios 25Q64fw
                              • 21692
                              S/N - PF2E2LST
                              MTM - 82C7A006IH
                              MO-PF9XB0808007
                              There are many working bios versions in this topic, try some.
                              • bogdan039
                                • Dec 2018
                                • 65
                                #375
                                hello.
                                please fix my bios dump,it start but no video,black screen.
                                thank you.
                                • peste
                                  • 13439
                                  • ROMANIA
                                  #376
                                  Originally posted by bogdan039
                                  hello.
                                  thank you.
                                  post S/N, full name and model, motherboard model, product number,etc.
                                  read the forum rules..
                                  • bogdan039
                                    • Dec 2018
                                    • 65
                                    #377
                                    you have all the details.
                                    thank you.
                                    • volinakis
                                      • Jan 2021
                                      • 2873
                                      • N/A
                                      #378
                                      thank you.
                                      you can read ... but can you write?
                                      hint: read RULES of this forum!
                                      • bogdan039
                                        • Dec 2018
                                        • 65
                                        #379
                                        A picture is better then one thousand words.
                                          • 21692
                                          The rules override what you think is right. We can copy text easily, why should we who are giving help have to look at a picture and type it ourselves. Very often the pictures that are posted are too small, rotated 90 degress left or righ, upside down or blurry. In such cases rather than being worth a thousand words it doesn`t mean anything and wastes our time.
                                          There`s a number of reasons why we ask for the serial number -
                                          We can find the bios/update at the manufacturers support site.
                                          We can check the laptop model type (lenovo) or configuration (Dell)
                                          We can check if the posted serial number which is usually on the sticker matches with the serial number in the bios, or EC.
                                          Asking for the serial number might put off some from posting at all if the machine is stolen.
                                          We can check if the bios has already been posted by someone else, or by the same member using a different account asking for the same bios to try and get help quicker.
                                            Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 05:00 AM
                                          • Patriarxis
                                            Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                            by Patriarxis
                                            Hello.
                                            I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                            It takes 0.027A and the power button flashing.
                                            All the voltages on the board are ok. 3.3, 5 etc.
                                            Also is charging the buttery .
                                            What else i can check?​
                                            05-26-2025, 01:03 AM
                                          • hotcrossedbuns999
                                            IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                            by hotcrossedbuns999
                                            First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                            Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                            05-21-2025, 05:59 PM
                                          • pcwhiz24
                                            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                            by pcwhiz24
                                            Model: Lenovo IdeaPad 3 14ADA05 81W0
                                            S/N: PF2BZS7D
                                            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                            I already have a CH341A programmer...
                                            04-07-2025, 07:10 PM
                                          • Visual_vt
                                            Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                            by Visual_vt
                                            Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                            SSD and BIOS seems to be OK.
                                            Thank you....
                                            12-30-2024, 09:14 AM
