HP 840 G7 password
    Re: HP 840 G7 password
    Help All Master
    Pls.. remove bios password and asset tracker lock to internet
    TIA
      hello gays i have hp 850 g7 with password can you help me ??
        Here's your Unlocked files, try it and let me know.
        all donations are welcome,
          thank you so much bro I'm very grateful
            good afternoon friends help me please unlock bios.thank you very much
              Here
              Become a Badcaps supporter
              Thanks to all supporters.
                good afternoon friends, please unlock bios and swat locked/device freeze-4835
                  HP EliteBook 840 G7 Notebook PC
                    bios locked removed but swat issue still there ..
                      It's difficult ! Try these 2 files again, if it does boot, go into bios settings and disable all security options before adding the serial number again.
                        Hello
                        I have here an Elitebook 840 G7 with BIOS password and managed to read the 16MB chip on the underside of the board.
                        Also I read the 32MB chip which are both uploaded here. Can somebody help me to unlock ?
                        I tried with RCunlocker and it says Unlocked for the 16MB reading but didnt displayed all the infos that it displays normally for other laptops of the older HP series, and I am not sure that RCunlocker works well for this model so I dont want to risk writing that....
                        And I opened the file with HxD but I am not finding the serial of the laptop inside the file, and I suspect that maybe reading was not done well with the RT809H
                        Thanks very much
                          Originally posted by ordinateur View Post
                          Hello
                          Thanks very much
                          Here's your Unlocked files, hope it works fine.
                          Serial Number: 5CG1473V3X
                            Hello
                            Thanks very much
                            Your serial number : 5CG1473V3X ( 35 00 43 00 47 00 31 00 34 00 37 00 33 00 56 00 33 00 58 )
                            Use RC Unlocker for 16MB file.
                              Done thanks
                              At first start there was an error Endpoint Protection but it disappeared now
                                Do two unlock methods done at the same time interfere with each other?
                                  There is only one important point:
                                  Make a good backup ,
                                  afterwards you can try 100 methods and no problem until you find it working
                                    PLEASE HELP ME REMOVE PASSWORD BIOS HP ELIEBOOK 840 G7 10 GEN
                                    camelia-6050a3136201-mb-a01
                                      Here
                                        Here
                                        Thank you, my friend. It works, but the back is a problem system is booting
                                        manfacturing Is there a solution
                                          add orignal dmi data
