HP 840 G7 password
    same issue admin password.
    iM using uploaded file here. Its working
    they show end point security
    I reset security settings no luck.
    clean my bios file
    main & ec
    more thanks🙏
      clean my bios file
      main & ec
      more thanks🙏
      are you kidding me? you said clean me!. you didn't mention any bios password or absolute. next time describe your problem.
        Master pls. help me to clean dump file.
        SN:5CG0465ZFL
        ProdID: 24X44UC#UFF
        more thanks master🙏
        only flash this main do not touch the EC.
        First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults and exit.
        Use BCU to fill these DMI info. you can permanently disable absolute in BCU.
        Serial Number: 5CG0465ZFL
        Product Number: 24X44UC#UUF
        CT Number: PJSCQ00WBEGEIO
        Description: HP EliteBook 840 G7 Notebook
        build_id: 20WWCMBT601#SUUF#DUUF
        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mE.ye
        MAC Address: 60-6D-3C-7A-61-10
          late reply master.
          more thanks it's working 👍
            swat lock remove pls
            serial number?
              ELITEBOOK 840 G7 swat lock remove pls.
              sn: 5CG050CDQQ
                sn: 5CG050CDQQ
                AAA
                Become a Badcaps supporter
                Thanks to all supporters.
                  do i need to flash both?
                    Yes
                      Hi, I have a Elitebook 840 G7 laptop. It had a admin password until got rid of it using a bin file in one of the postings.
                      However, on every boot, I am getting "There is a problem with the HP Endpoint Security Controller". Can you help me remove this message from popping up?
                      S/N 5CG1247CPR
                      ProdID 2Z4G6UC#ABA
                      I am also attaching both bin files.
                        S/N 5CG1247CPR
                        ProdID 2Z4G6UC#ABA
                        can u read ur 32mb main again because the file is corrupted
                          Ok, I am attaching original bin files. So, this one has the admin password in it. If you could just remove the password, this should fix my other issue as well.
                            CCC
                              After reflashing the bin files, caps lock is blinking 7 times.
                                try
                                  Yes, these files worked for me. The password was gone and I had to use BCU to get out of the manufacturing mode by filling out empty fields. Otherwise, computer is good to go. Thank you.
                                    HI, CAN YOU PLEASE REMOVE PASSWORD FOR ME. THANKX IN ADVANCE
                                      serial number?
                                        first boot press f10 then go factory default setup
