mec 16xx dump with info block
SYSTEM BORD SERIAL NUMBER:L1HFC9300MT
SYSTEM-UNIT SERIAL BORD NUMBER:PF216ZHFComment
https://www.badcaps.net/donateComment
TryAttached Files↵
SORRY I HAVE errer
sorry i have errer withe file this fil withe machin working good
Attached FilesComment
hello i got thinkpad t14 gen1 20s0 with burn mec1663 i replaced it with a new one i got the jtag connection with my vertyanove programmer try to cut ec when i write it i got blinking white led 3 times only can some one help me to fined the file flash+epperom
nm-c931 rev 1.0 my s/n PF2A58EN
thank all for helpComment
[QUOTE=hoaca388;n3615433]
lenovo p52
type 20ma-s6hh00
sn pf-1ns7hl
mec1653
can unlockComment
I have a Dell e7440 la-9591p motherboard, no matter what I did on the device, I couldn't start it. It uses MEC5075. On the first page, someone shared the jtag paths for tx390, I searched from the schematic and found the same legs. Can I make this read by soldering it in the same way as SWOD? or with rt809f? or what are its legs? Also, I think the place where it says rp1 is for jtag, but there is a resistor with 103 written on it. Can I remove it, solder the 5 paths and 3 gnds and read it?Comment
Thanks to everyone for the help.
My case was a ThinkPad X1 Carbon Gen 7 with motherboard NM-C661. I used an SVOD3 and the pinout from the picture I’m attaching. The reset is not needed when using the pull-down resistor.
In the SVOD software I selected EEPROM, and once the dump was read I changed the data from 0x300–0x34F to FF. After reprogramming, the password issue was solved.
Many thanks again to all, and I hope this can help anyone else who has the same model.
Hi Badcaps Team,
T15 Gen1 with bios lock.
SN: PF2RVTMS
I have checked the dump but I cant find the location of the passAttached FilesComment
			by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
			by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? -
			by CityminHi all,
S/N : 5RNK9FFT70...-
			by hyperwoodHi everyone,
I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
✅ What I need:- A working 2MB BIOS dump
 - Matching NM-E471 Rev. 2.0, e.g. JY575
 - Loading...
