Dell Xps 13 9370 bios
  • WaShErE
    • Aug 2019
    • 14
    • TR
    #101
    Originally posted by WaShErE
    Re: Dell Xps 13 9370 bios
    Hello every1,
    Keyboard light coming on then it shut down itself, i think its a bios issue. May i have a good bios?
    Thank you, appreciate.
    ST:H9GWMQ2
    Help please?
    • qayyum786
      • Aug 2018
      • 1958
      • INDIA
      #102
      Help please?
      Are you sure the bios you want fix its the same bios posted on 09-29-2023 ?
      • WaShErE
        • Aug 2019
        • 14
        • TR
        #103
        I couldn't tried any bios or any repair attempt after that date because nobody shared any Laptop is still with me, today i just found and wanted to ask one more time. May be today is the right day who knows. Yes its the same bios which i dumped from the laptop.
        • qayyum786
          • Aug 2018
          • 1958
          • INDIA
          #104
          Try
          • WaShErE
            • Aug 2019
            • 14
            • TR
            #105
            Try
            Thank you qayyum, i just uploaded the new bios and but bios battery is flat its charging, hope it will work. I need a working laptop very badly now. I will let you know.
            • WaShErE
              • Aug 2019
              • 14
              • TR
              #106
              Try
              Hello again, i was able to upload new bios but before bios i couldn't check the machine then i realized that cpu is shorted. This motherboard was liquid damage, it was working fine then it started to shutdown itself after random times. So basically i couldn't archived my goal. Definitely i need a board replacement, i really appreciated for your time and afford. Thank you so much.
              • woorsbrod
                • Oct 2025
                Hi there!
                Another dead xps13 (9370, non-vPro) here. I'm quite sure the last thing i saw was a reboot after a Windows Update and since then it won't post.
                I'm hoping Windows Update "only" corrupted the bios but the hardware is ok.
                It still turns on, but aside from a few seconds of keyboard backlight (turns off after a few seconds and back on when a key is pressed) a quick fan spin and a charging battery, nothing else happens. Display test on powerup also works.
                Bios recovery (ctrl-esc + plug in power) fails with "file not found" blink code (tried different names, cases, usb-ports, even different usb-sticks, with different filesystem sizes).
                Can someone have a look and possibly fix this, please?
                ST: G780VN2
                EX: 35265258542
                Thanks in advance!
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • jhanra
                  by jhanra
                  in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                  11-02-2024, 04:19 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
