Dell Xps 13 9370 bios
  • WaShErE
    • Aug 2019
    • 14
    • TR
    #101
    Originally posted by WaShErE
    Re: Dell Xps 13 9370 bios
    Hello every1,
    Keyboard light coming on then it shut down itself, i think its a bios issue. May i have a good bios?
    Thank you, appreciate.
    ST:H9GWMQ2
    Help please?
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      #102
      Help please?
      Are you sure the bios you want fix its the same bios posted on 09-29-2023 ?
      • WaShErE
        • Aug 2019
        • 14
        • TR
        #103
        I couldn't tried any bios or any repair attempt after that date because nobody shared any Laptop is still with me, today i just found and wanted to ask one more time. May be today is the right day who knows. Yes its the same bios which i dumped from the laptop.
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          #104
          Try
          • WaShErE
            • Aug 2019
            • 14
            • TR
            #105
            Try
            Thank you qayyum, i just uploaded the new bios and but bios battery is flat its charging, hope it will work. I need a working laptop very badly now. I will let you know.
            • WaShErE
              • Aug 2019
              • 14
              • TR
              #106
              Try
              Hello again, i was able to upload new bios but before bios i couldn't check the machine then i realized that cpu is shorted. This motherboard was liquid damage, it was working fine then it started to shutdown itself after random times. So basically i couldn't archived my goal. Definitely i need a board replacement, i really appreciated for your time and afford. Thank you so much.
              • woorsbrod
                • Oct 2025
                • 6
                Hi there!
                Another dead xps13 (9370, non-vPro) here. I'm quite sure the last thing i saw was a reboot after a Windows Update and since then it won't post.
                I'm hoping Windows Update "only" corrupted the bios but the hardware is ok.
                It still turns on, but aside from a few seconds of keyboard backlight (turns off after a few seconds and back on when a key is pressed) a quick fan spin and a charging battery, nothing else happens. Display test on powerup also works.
                Bios recovery (ctrl-esc + plug in power) fails with "file not found" blink code (tried different names, cases, usb-ports, even different usb-sticks, with different filesystem sizes).
                Can someone have a look and possibly fix this, please?
                ST: G780VN2
                EX: 35265258542
                Thanks in advance!
                • woorsbrod
                  • Oct 2025
                  • 6
                  Originally posted by woorsbrod
                  Hi there!
                  ST: G780VN2
                  EX: 35265258542
                  Thanks in advance!
                  Hello again!
                  Meanwhile I tried rebuilding the bios as described in the ME Firmware Cleaning Guide, but while it took some time, several power cycles and removal of the cmos battery to get it to power on again, in the end, the symptoms did not change at all. I tried flashing my bios backup backup and it seems that I am exactly where I started.
                  Any assistance, please?
                  Thanks and have a great day!
                  • Markus1741
                    • Sep 2020
                    • 994
                    • N/A
                    #109
                    Hello again!
                    Hello you can try this file ....
                    • woorsbrod
                      • Oct 2025
                      • 6
                      That worked on the first try!
                      Thank you very much!
                      Edit: I noticed, that the Service Tag was missing. That's not a problem, but would you mind telling me what you did to fix the issue? Or did you pick a "generic" bios for that model and my backup wasn't used/modified at all?
                      • Markus1741
                        • Sep 2020
                        • 994
                        • N/A
                        #111
                        Hello nicely to hear that it worked it rarely appears at XPS.
                        Based on your service day, I downloaded the last BIOS .exe file from Dell and unpacked the whole thing.
                        With this information and your original file, I then created a new BIOS.
                        Then the ME region cleaned.
                        I deliberately not taken over your DMI I wanted to keep it as easy as possible.
                        The XPS are known for the BIOS programming often do not work.
                        This is actually all.
                        Of course you can insert your DMI again if you want.
                        • woorsbrod
                          • Oct 2025
                          • 6
                          Hey Markus! Great, thanks for letting me know!
                          Any pointers how to rebuild the original DMI data?
                          Can I use FIT to get the old data and move that into the new bios like when I tried to replace the ME Region that way?
                          • Markus1741
                            • Sep 2020
                            • 994
                            • N/A
                            #113
                            Okay try this one with your ServiceTag + Windows Key
                            • woorsbrod
                              • Oct 2025
                              • 6
                              Worked like a charm! Thank you again!
                              • cybernova
                                • May 2015
                                • 35
                                • IRAN
                                #115
                                hi please clear me my file la-e671p rev 1.0 bios password
                                  • 22425
                                  Type the laptop serial number, full name and model, motherboard model, etc.
                                  post the contents of the bios chip
                                  read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                                  • 3mz3t
                                    • Sep 2023
                                    • 18
                                    • Slovakia
                                    #117
                                    Heya
                                    XPS 9370, ST: H911NQ2. The machine turns on, fans spin, keyboard lights up, but no picture and no bios post (it seems).
                                    Attached is the original bios dump. Could anyone help me out with ME clean (or whatever else that's needed here)?
                                    Thank you.
                                    • LBTT1121
                                      • Nov 2024
                                      • 1273
                                      • Việt Nam
                                      #118
                                      Originally posted by 3mz3t
                                      Heya
                                      Thank you.
                                      try and feedback
                                      • Leone22
                                        • Mar 2015
                                        • 14
                                        • Italia
                                        #119
                                        I’m having an issue with a Dell XPS 13 9370. When I power it on, only one of the two fans starts spinning, and the LED flashes twice amber and four times white. If I try to shut it down, the second fan also starts for a moment, then the system powers off.
                                        I’ve checked the main power rails, and all voltages seem to be present, so I’m starting to suspect a corrupted BIOS.
                                        Could someone please share a working BIOS dump or firmware image for this model?
                                        I’ve attached the BIOS file I downloaded along with the notebook specs.
                                        ST: 3CCWMF2
                                        EX: 7277618558
                                        Motherboard model: CAZ60 LA-E671P Rev.1
                                        Thanks in advance for any help!
                                        • Leone22
                                          • Mar 2015
                                          • 14
                                          • Italia
                                          #120
                                          Would someone be so kind as to help me, please?
                                          Thank you.
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
