  • mikeybass
    • Aug 2024
    • 8
    Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run normally.
    Now for the advice request: Both computers have BIOS version A13. I would like to upgrade the BIOS in both computers to a higher version. I downloaded all of the BIOS versions from A13 – A30 in their .exe packages from Dell. I tried A14 first which failed from the .exe install. I got a message saying a driver file (DBUtil_2_3.sys) cannot load. I downloaded a utility from Dell that is supposed to detect and delete that file. It ran its search but found no instances of the file. A manual search found no instance of that file. So, then I made a bootable DOS USB drive and loaded the .exe files on to it. From all indications the upgrade install ran like it should. When the computer shut down after the upgrade (that's normal), the upgrade was supposed to install itself. It did not. The BIOS version remains at A13. I tried most of the other .exe BIOS installer packages via .exe install and DOS with no luck. The BIOS version remains at A13. I don't think the BIOS ICs could be locked because I successfully dumped the working computer BIOS files and successfully flashed the other computer's BIOS. I have visited numerous forums and have tried dozens of suggestions over many weeks, but none of them would upgrade the BIOS version. Since both computers are running normally with A13, I suppose I could leave them both alone. What am I doing wrong? Any ideas? Thanks!
  • Darksands
    Need clean BIOS dump: Dell Pro 14 Plus PB14250 (CMF34 Rev: A00) - Freezes on Dell logo
    by Darksands
    [SOLVED]
    Laptop: Dell Pro 14 Plus, PB14250
    Motherboard: PWB CMF34, Rev (A00).
    Service Tag: 3YLQ8F4.
    CPU: Intel® Core™ Ultra 5 processor 238V (8M Cache, up to 4.70 GHz) FCBGAEXX, Tray. Ordering Code: QQ8076606106. Spec Code: SRPN5.
    BIOS Flash Chip: Winbond 25R512NWEQ.
    BIOS version (via ME Analyzer by TechNoDev): 20.0.11.1815_COR, FITC 20.0.0.1329, SKU Corporate.
    Symptoms & History: Initially, a black screen appeared, then the laptop rebooted, entered BIOS Recovery, and the flashing process started. After the flash and a reboot, it freezes...
    09-13-2026, 03:15 AM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • TopPop
    Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
    by TopPop
    Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
    I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
    12-14-2025, 09:40 PM
  • capoplays
    Help with BIOS update on Dell G15 5515 after chip replacement
    by capoplays
    Hey everyone,
    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
    When I check the BIOS using the F12 menu Flash...
    10-24-2025, 06:53 AM
  • Sathsul
    Dell Latitude 5431 issues with dumping bios
    by Sathsul
    So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
    The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
    However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
    10-28-2025, 07:49 AM
