Dell Xps 13 9370 bios
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Dell XPS 9370 BIOS fix needed.
    Originally posted by U_pasta
    could you explain how you extracted the BIOS files from the dell .exe file?
    I apologize for the English.
    grateful for the attention
    Decompress Dell UEFI BIOS
    Become a Badcaps supporter
    Thanks to all supporters.
    • cherif 16
      • Aug 2021
      • 9
      • algeria
      Re: Dell Xps 13 9370 bios
      Originally posted by peste
      try..
      THENKSSSS FRENDS Peste
      • PCRider
        • May 2022
        • 8
        • Iran
        I have a Dead Dell XPS13 9370 With Corrupted Bios
        here is the report of ME Analyzer v1.148.4 r209
        Code:
        ║     CorruptedDELL9370LA-E671P.bin (1/1)      ║
        ║        Family        │   CSE ME   ║
        ║        Version        │  11.8.90.3987  ║
        ║        Release        │  Production  ║
        ║         Type        │  Extracted   ║
        ║         SKU         │  Corporate LP  ║
        ║        Chipset        │  SPT/KBP-LP C  ║
        ║   TCB Security Version Number   │    3     ║
        ║    Version Control Number    │    320    ║
        ║      Production Ready     │    Yes    ║
        ║    Power Down Mitigation    │    No    ║
        ║    Lewisburg PCH Support    │    No    ║
        ║     OEM Configuration     │    No    ║
        ║         Date        │  2021-06-03  ║
        ║     File System State     │  Initialized  ║
        ║         Size        │   0x603000   ║
        ║      Flash Image Tool     │  11.6.0.3307  ║
        ║        Latest        │    Yes    ║
        Note: This CSE ME firmware was not found at the database, please report it!
        I couldn't find proper version of tools and firmware to fix it, can anyone do it for me please?
        • hoaca388
          Badcaps
          • Jan 2022
          • 11882
          It's Cor LP C.
          • PCRider
            • May 2022
            • 8
            • Iran
            Originally posted by hoaca388
            It's Cor LP C.
            So? Can i fix it?
            Where should i report this?
            "Note: This CSE ME firmware was not found at the database, please report it!"
            • PCRider
              • May 2022
              • 8
              • Iran
              #26
              There is no more error on ME Analyzer, I compiled new version of it by pyinstaller and attached it to this post
              well, well, i have checked all voltages based on compal schematic and everything was OK, MEC5105 has no sign of life with the current bios but when i program other bios files which i collected from internet it will start by power button and shows 3 times white LED and 3 times orange LED blinking on and on, i cleaned ME and EC image region but nothing changed, still no sign of life with my own bios even when i cleaned ME and EC region of it, anyone has any idea? what is wrong?
              • hoaca388
                Badcaps
                • Jan 2022
                • 11882
                #27
                Try
                • PCRider
                  • May 2022
                  • 8
                  • Iran
                  #28
                  Try
                  Thanks for replay, i flashed and checked it, nothing happened, no change, still power key do nothing, it is dead with this flash content and with others just blinking LED
                  • sunbabu369
                    • Oct 2021
                    • 42
                    • india
                    #29
                    this bios flash it reply me
                    • PCRider
                      • May 2022
                      • 8
                      • Iran
                      #30
                      Thanks everyone, I have fixed my bios and laptop is working again, without your bios samples was hardly possible to do this, i figure it out ec region is for an arm based processor and you can't fix it by FIT even if you extract ec program from executable bios updates, i easily fixed it with IDA pro, I share my fixed bios here for others to use if they need, you can use hex compare to see how two bytes can stop a healthy hardware to work
                      • sect-sin
                        • May 2022
                        • 101
                        • Hungary
                        #31
                        I have a Dell 9370 (board version CAZ60 LA-E671P), the symptoms are: it turns on, keyboard lights up, fans spin, but no post, and it turns off after 20 sec or so. I checked the board, visual check OK, no shorts, MOSFET's measure fine, memory + CPU resistances OK, there is correct voltage on all rails. So I guess it is a BIOS issue.
                        I am not good with ME cleaning/BIOS repairing, could someone help me with fixing this? I prefer the newest BIOS version with DMI info transferred. I have attached a BIOS dump.
                        I thank you very much in advance for your help!
                        Cheers,
                        sect-sin
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11882
                          #32
                          Cheers,
                          sect-sin
                          Your XPS 13 9370
                          • hardware1
                            • Sep 2021
                            • 2939
                            • N/A
                            #33
                            Cheers,
                            sect-sin
                            I see two strings in your dump looks like service tag (SVCTGG1-DGKXNQ2), but non of them give me result in dell site.
                            Anyway try this and let me know.
                            all donations are welcome,
                            • sect-sin
                              • May 2022
                              • 101
                              • Hungary
                              #34
                              I tried hoaca388's BIOS first, and it worked marvelously!!! Just so other people know, first it dropped a blink error code for low CMOS battery (which is already a very good sign, as with the corrupted BIOS there were no error codes at all). After changing the CMOS battery, it dropped a blink error code for wrong memory installed, which was weird, as it comes with soldered-on memory. After a power down-power up sequence it POST'ed and works like a charm though, so I guess it was only adjusting memory timings.
                              I thank you very much both for the fixed BIOSes, you are both very great!
                              Cheers,
                              sect-sin
                              • sect-sin
                                • May 2022
                                • 101
                                • Hungary
                                #35
                                Hoaca,
                                I have a small problem with your BIOS file though. There should be a Windows 10 key in the BIOS, I am missing that, and the Dell site does not automatically identify my notebook for driver download based on the service tag (this is not such a big problem).
                                Could you tell me whether there is a Windows key in the DMI of my old BIOS? Is it possible that your fixed BIOS does not have DMI information?
                                I thank you very much in advance for your reply.
                                Cheers,
                                sect-sin
                                • volinakis
                                  • Jan 2021
                                  • 2744
                                  • N/A
                                  #36
                                  hoaca,
                                  i have a small problem with your bios file though. There should be a windows 10 key in the bios, i am missing that, and the dell site does not automatically identify my notebook for driver download based on the service tag (this is not such a big problem).
                                  Could you tell me whether there is a windows key in the dmi of my old bios? Is it possible that your fixed bios does not have dmi information?
                                  Cheers,
                                  sect-sin
                                  jmqdx-xn****************
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11882
                                    #37
                                    Hoaca,
                                    Cheers,
                                    sect-sin
                                    DMI and windows key are already in that file.
                                    • sect-sin
                                      • May 2022
                                      • 101
                                      • Hungary
                                      #38
                                      This is strange, Windows should detect the integrated key, but it doesn't. And I am not getting any kind of Message from BIOS that manufacture mode is active. Thank you anyway for the info, I will add the key manually.
                                      Cheers,
                                      sect-sin
                                      • ALUCARD5050
                                        • Dec 2022
                                        • 5
                                        • Tunisie
                                        #39
                                        try..
                                        Very Nice Thank you
                                        • brontobyte
                                          • Jul 2021
                                          • 85
                                          • Romania
                                          #40
                                          Hello friends,
                                          I have this dell xps 9370
                                          CAZ61 LA-E671P Motherboard with some issues.
                                          2 amber and 5 white.
                                          May be this a bios issue?
                                          there's the original bios file.
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
