Dell Xps 13 9370 bios
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Dell XPS 9370 BIOS fix needed.
    Originally posted by U_pasta
    could you explain how you extracted the BIOS files from the dell .exe file?
    I apologize for the English.
    grateful for the attention
    Decompress Dell UEFI BIOS
    Become a Badcaps supporter
    Thanks to all supporters.​
    • cherif 16
      • Aug 2021
      • 9
      • algeria
      Re: Dell Xps 13 9370 bios
      Originally posted by peste
      try..
      THENKSSSS FRENDS Peste
      • PCRider
        • May 2022
        • 8
        • Iran
        I have a Dead Dell XPS13 9370 With Corrupted Bios
        here is the report of ME Analyzer v1.148.4 r209
        Code:
        ║     CorruptedDELL9370LA-E671P.bin (1/1)      ║
        ║        Family        │   CSE ME   ║
        ║        Version        │  11.8.90.3987  ║
        ║        Release        │  Production  ║
        ║         Type        │  Extracted   ║
        ║         SKU         │  Corporate LP  ║
        ║        Chipset        │  SPT/KBP-LP C  ║
        ║   TCB Security Version Number   │    3     ║
        ║    Version Control Number    │    320    ║
        ║      Production Ready     │    Yes    ║
        ║    Power Down Mitigation    │    No    ║
        ║    Lewisburg PCH Support    │    No    ║
        ║     OEM Configuration     │    No    ║
        ║         Date        │  2021-06-03  ║
        ║     File System State     │  Initialized  ║
        ║         Size        │   0x603000   ║
        ║      Flash Image Tool     │  11.6.0.3307  ║
        ║        Latest        │    Yes    ║
        Note: This CSE ME firmware was not found at the database, please report it!
        I couldn't find proper version of tools and firmware to fix it, can anyone do it for me please?
        • hoaca388
          Badcaps
          • Jan 2022
          • 12534
          It's Cor LP C.
          ​https://www.badcaps.net/donate
          • PCRider
            • May 2022
            • 8
            • Iran
            Originally posted by hoaca388
            It's Cor LP C.
            So? Can i fix it?
            Where should i report this?
            "Note: This CSE ME firmware was not found at the database, please report it!"
            • PCRider
              • May 2022
              • 8
              • Iran
              #26
              There is no more error on ME Analyzer, I compiled new version of it by pyinstaller and attached it to this post
              well, well, i have checked all voltages based on compal schematic and everything was OK, MEC5105 has no sign of life with the current bios but when i program other bios files which i collected from internet it will start by power button and shows 3 times white LED and 3 times orange LED blinking on and on, i cleaned ME and EC image region but nothing changed, still no sign of life with my own bios even when i cleaned ME and EC region of it, anyone has any idea? what is wrong?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12534
                #27
                Try
                • PCRider
                  • May 2022
                  • 8
                  • Iran
                  #28
                  Try
                  Thanks for replay, i flashed and checked it, nothing happened, no change, still power key do nothing, it is dead with this flash content and with others just blinking LED
                  • sunbabu369
                    • Oct 2021
                    • 42
                    • india
                    #29
                    this bios flash it reply me
                    • PCRider
                      • May 2022
                      • 8
                      • Iran
                      #30
                      Thanks everyone, I have fixed my bios and laptop is working again, without your bios samples was hardly possible to do this, i figure it out ec region is for an arm based processor and you can't fix it by FIT even if you extract ec program from executable bios updates, i easily fixed it with IDA pro, I share my fixed bios here for others to use if they need, you can use hex compare to see how two bytes can stop a healthy hardware to work
                      • sect-sin
                        • May 2022
                        • 104
                        • Hungary
                        #31
                        I have a Dell 9370 (board version CAZ60 LA-E671P), the symptoms are: it turns on, keyboard lights up, fans spin, but no post, and it turns off after 20 sec or so. I checked the board, visual check OK, no shorts, MOSFET's measure fine, memory + CPU resistances OK, there is correct voltage on all rails. So I guess it is a BIOS issue.
                        I am not good with ME cleaning/BIOS repairing, could someone help me with fixing this? I prefer the newest BIOS version with DMI info transferred. I have attached a BIOS dump.
                        I thank you very much in advance for your help!
                        Cheers,
                        sect-sin
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12534
                          #32
                          Cheers,
                          sect-sin
                          Your XPS 13 9370
                          • hardware1
                            • Sep 2021
                            • 2951
                            • N/A
                            #33
                            Cheers,
                            sect-sin
                            I see two strings in your dump looks like service tag (SVCTGG1-DGKXNQ2), but non of them give me result in dell site.
                            Anyway try this and let me know.
                            all donations are welcome,
                            • sect-sin
                              • May 2022
                              • 104
                              • Hungary
                              #34
                              I tried hoaca388's BIOS first, and it worked marvelously!!! Just so other people know, first it dropped a blink error code for low CMOS battery (which is already a very good sign, as with the corrupted BIOS there were no error codes at all). After changing the CMOS battery, it dropped a blink error code for wrong memory installed, which was weird, as it comes with soldered-on memory. After a power down-power up sequence it POST'ed and works like a charm though, so I guess it was only adjusting memory timings.
                              I thank you very much both for the fixed BIOSes, you are both very great!
                              Cheers,
                              sect-sin
                              • sect-sin
                                • May 2022
                                • 104
                                • Hungary
                                #35
                                Hoaca,
                                I have a small problem with your BIOS file though. There should be a Windows 10 key in the BIOS, I am missing that, and the Dell site does not automatically identify my notebook for driver download based on the service tag (this is not such a big problem).
                                Could you tell me whether there is a Windows key in the DMI of my old BIOS? Is it possible that your fixed BIOS does not have DMI information?
                                I thank you very much in advance for your reply.
                                Cheers,
                                sect-sin
                                • volinakis
                                  • Jan 2021
                                  • 2888
                                  • N/A
                                  #36
                                  hoaca,
                                  i have a small problem with your bios file though. There should be a windows 10 key in the bios, i am missing that, and the dell site does not automatically identify my notebook for driver download based on the service tag (this is not such a big problem).
                                  Could you tell me whether there is a windows key in the dmi of my old bios? Is it possible that your fixed bios does not have dmi information?
                                  Cheers,
                                  sect-sin
                                  jmqdx-xn****************
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12534
                                    #37
                                    Hoaca,
                                    Cheers,
                                    sect-sin
                                    DMI and windows key are already in that file.
                                    • sect-sin
                                      • May 2022
                                      • 104
                                      • Hungary
                                      #38
                                      This is strange, Windows should detect the integrated key, but it doesn't. And I am not getting any kind of Message from BIOS that manufacture mode is active. Thank you anyway for the info, I will add the key manually.
                                      Cheers,
                                      sect-sin
                                      • ALUCARD5050
                                        • Dec 2022
                                        • 5
                                        • Tunisie
                                        #39
                                        try..
                                        Very Nice Thank you
                                        • brontobyte
                                          • Jul 2021
                                          • 85
                                          • Romania
                                          #40
                                          Hello friends,
                                          I have this dell xps 9370
                                          CAZ61 LA-E671P Motherboard with some issues.
                                          2 amber and 5 white.
                                          May be this a bios issue?
                                          there's the original bios file.
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
