bios dump elitebook 840 g3
  • peste
    • Dec 2016
    • 12274
    • ROMANIA
    #761
    Re: bios dump elitebook 840 g3
    Originally posted by krusty09521
    Hi guys , bought a dead 840 g3 and repaired the motherboard but it has a bios password.. and im clueless when it comes to finding the password or transfering serials etc. can anyone have a look at the dump? Thanks
    try..
    • krusty09521
      • May 2021
      • 4
      • ireland
      #762
      Originally posted by peste
      try..
      Worked perfectly , thank you very much!
        • Jun 2022
        • 15
        • Nigeria
        #763
        pls someone help remove lock on my bios bin file, its passworded
        board number is 6050A2892401-MB-A01
        dump attached
        • peste
          • Dec 2016
          • 12274
          • ROMANIA
          #764
          dump attached
          try..
          • zakeric
            • Mar 2014
            • 65
            • Morocco
            #765
            Re: HP 840 G3 bios needed
            Originally posted by imranromi
            Here try and reply.
            I need to unlock this eliteBook 840 G3
            • lapfix
              • Mar 2020
              • 2594
              • my workshop
              #766
              Your file is empty try read again
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3558
                • slovakia
                #767
                HP 840 G3 cannot find working bios
                Hello. Have this HP G3 that have mostly bios problem. every bios that i try not work as should - blinking start button. not even with original bios region from HP. only this one work as expected - restart, BL start. But still no video because of CPU rail not work. I cleaned ME region, replace BIOS region, but still no video. power rail and cpu resistance is ok
                Any hint on it
                • kamkooltech
                  kamkooltech
                  • Jun 2019
                  • 98
                  • nigeria
                  #768
                  can some one help me treat this file, 840 g3
                  • rachidell
                    • Aug 2016
                    • 132
                    • algeria
                    #769
                    please clean my dump.
                    thanx
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11254
                      • Viet Nam
                      #770
                      Originally posted by rachidell
                      hello,
                      Thanx
                      rc unlocker
                      • rachidell
                        • Aug 2016
                        • 132
                        • algeria
                        #771
                        thanx
                        • arber1232
                          • Dec 2019
                          • 367
                          • Albania
                          #772
                          hi everyone i need repair this bios 840 g3 this is backup bios
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11254
                            • Viet Nam
                            #773
                            HP EliteBook 840 G3 Notebook PC
                            • hussaka
                              • Jan 2015
                              • 151
                              • italy
                              #774
                              thank you peste
                              • kudo623
                                • Aug 2022
                                • 53
                                Hi all, 840 G3 BIOS locked, ran rcunlocker and programmed it into the chip but it did not work
                                Here is the file Thanks for your help!
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #776
                                  Unlocked:
                                  Become a Badcaps supporter
                                  Thanks to all supporters.
                                  • kudo623
                                    • Aug 2022
                                    • 53
                                    Originally posted by Vesko356
                                    Unlocked:
                                    HI Thanks Vesko for the file, but it didn't work. CAPS blinked and restarted once or twice but no video, fan runs I don't think it POSTed? (CAPS lock didn't illuminate when CAPS lock key depressed.)
                                    I tried the file on another machine but same thing.
                                    I got another file off the 2nd machine in case the 1st one was corrupted somehow? Thanks.
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #778
                                      N-o w-a-y! Now, not that it's impossible for me to make a mistake once in a while, but to be honest I'm a pretty big perfectionist, and making a mistake is a very rare occurrence. The file is 101% unlocked OK, just double checked it, so you are doing some mistake somewhere in the process - compare the content of the chip against the file, check the soldering, check the orientation of the chip at the board, check the surrounding area for blew up components and so on...
                                      • kudo623
                                        • Aug 2022
                                        • 53
                                        I agree, it's most likely something on my end, I never was able to get one of these unlocked and working, maybe 5 or 6 tries now. I'll keep at it and get back to you. Thanks!
                                        Update: "Broke the ice"
                                        I got one to work, I melted some more solder on the belly and gave it a little more heat and it fired up Thanks!
                                        • Vesko356
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #780
                                          Excellent.
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
                                          • grimacelord
                                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                            by grimacelord
                                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                            Motherboard model number: DA0PAMB46A1 REV: A
                                            Secondary motherboard model number: 0PAB
                                            SKU: 685K4UA
                                            Serial number is: 5CD3223BJP
                                            Recently reflashed this laptop with latest BIOS and once...
                                            05-07-2024, 08:06 AM
                                          • DynaxSC
                                            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                            by DynaxSC
                                            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                            11-06-2022, 05:22 PM
