bios dump elitebook 840 g3
Every donation made will go towards server fees and maintenance costs. -
Re: HP Elitebook 840 G3 BIOS dump
Post your corrupt bios here.↵
https://www.badcaps.net/donateComment
Please read the bios posting rules.You must post under a related thread if there is one.
Use the forum search,you can often find a related post that way,then you don`t have to start a new thread.Comment
OK sorryPlease read the bios posting rules.You must post under a related thread if there is one.
Search through this thread for a bios with clean ME firmware such as post #442. If a bios is titled outimage,ME Clean,clean ME they most likely have cleaned firmware.Use HP bios config utility to add missing DMI infoComment
Unfortunately I don't know much about it...Comment
Re: bios dump elitebook 840 g3
Can you explain the difference between my unlocked file and the file unlocked by RCUnlocker? Not trolling, just interested, since I am not very good with hex editors. Seems that RCUnlocker leaves some data behind, while my software doesn't.Attached Filesif you find these attachements useful please consider making a small donation to the site
I don't provide help for people using CH341A and a clip.Comment
There is a difference, but this bios file only needs to intervene in the "U.s.e.r.C.r.e.d" area.↵
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
