SVOD4 NPCX997
    Ah, okay. Thank you volinakis . I'm assuming like this? Or is this the wrong header on the mobo?
      nope, that's connector for trackpad. you have to put the ribbon into keyboard connector, align with 1st pin. You have tutorials on youtube
        Hello again everyone! I wanted to thank everyone for their help. I was able to successfully erase the SVP from my laptop and change the settings to allow me to boot into Linux. I really appreciate the time/effort/experience that goes into helping newbies like myself.
        Everything works as expected, so it is not critical, but I get a message about "invalid RFID serialization area" which tells me there is something slightly off with the binary I flashed. I will post the original and modified binaries later if anyone cares to look.
          Hello arestlessknight,
          It would be great if you could give us some information and the binaries. I have the exact same laptop:
          Model: Lenovo ThinkPad T14 Gen3 AMD
          Type: 21CG-S1D600
          Serial No.: PF-4AFKP5
          Mainboard Type: NM-E441 Rev: 1.0
          BIOS Chip 1?: 25LR256EYIG
          BIOS Chip 2?: 25LB128ESIG
          Chip: GigaDevice
          Do you also have both installed BIOS chips? Or which of the two is the correct one? See image.
Name:	WhatsApp Image 2025-05-04 at 12.36.41.jpg
          I've already ordered the SVOD4 programmer and am still waiting for delivery. As soon as it arrives, I want to get started.​​
            Originally posted by Maxpower3 View Post
            a BIG BIG Thanks to the SVOD team who activated my tool.
            I now notice a new box in the software and now reading is done perfectly
Name:	Nouveau Image bitmap (2).png
            Hello Maxpower3, I need software for svod4 version 0.0.5.5 if you have, I am having same issue trying to read NPCX997 and I can only get software version 0.0.5.9 and I have tried everything on the forums without success. For the past 3 days I have sent messages, pics to svod support but no one is coming forth to help. Thanks
              I have exactly the same problem, does anyone have version 0.0.5.5?
                Hello 👋 need some help after i flash the bios from other website using svod 4 to remove passcode but it came to no display even the back up files not working too
                i just notice after that when i power on the laptop the indicator light blink 3 times and stop to stable light but no display. Here the model and other information.
                serial no. PF-4EX3CK
                Type no. 21CG-SOVT3V
                NM-E441 Rev:1.0
                  Here is version 0.0.5.5 hope it helps but as for me its not working. I have tried different windows on different computers but I cant read NPCX997 on Lenovo T14 G4 NM-F261
                    Thank you Kodza.
                    OK, it doesn't work for me even with version 0.0.5.5.
                    According to SVOD support, software 0.0.5.9 should work with NPCX997K without any problems.
                    Maybe I need to connect the programmer directly to the chip and not via the keyboard input.
                    I hope someone can help us here.
                      Thank you Kodza.
                      i'm not using this programmer, but the ufpi (best on the market in my opinion). timing is important. in this case you need to read the chip id just BEFORE plugging in the power cord (bat disconnected)! maybe it helps...
                        Thank you Kodza.
                        it should work, few days ago I unlocked a T14 gen3 AMD. I think I have an older software version from March, I didn't update it to last version but I will try also with new version. Set voltage (power) to 1.8V, sometimes it helps even NPC isn't powered by SVOD4. I also let the CMOS battery plugged in so the motherboard doesn't start up. Oh, one last thing: I always remove motherboard from chassis or remove all connectors entering in motherboard.
                          Thank you for the reply but I am starting to believe that my SVOD 4 is defective. 5 days I am trying to read this ic. The response from SVOD support is poor they don't give anything to work with. If you plug charger on the motherboard without cmos battery and main battery does your board power on because I see you mention CMOS battery. When I plug charger on my board it does not power on by its self so could that contribute
                            there is a facebook group for svod4, users are sharing their experiences there. Some are saying they let the main battery plugged in.
                              Great, thanks for all the tips. Reading the bin file worked. Can someone tell me how to proceed?
                                fill with 00 Click image for larger version
Name:	Screen Shot 2025-05-20 at 20.39.07.png
                                  Thank you so much, Volinakis.
                                  - I filled in the area with 00.
                                  - Then I wrote it back to the chip.
                                  - When I restarted, the ThinkPad created a self-healing backup.
                                  - F1 > Supervisor Password Blank
                                  - I can now access the BIOS, but I can't make any changes.
                                  What do I have to do now?
ID:	3641592 Click image for larger version
ID:	3641590 Click image for larger version
ID:	3641589 Click image for larger version
                                    Hi how did you do it, me I am stuck on Armcore Detected, error 20, Ready Faulty
                                      extract Ec from update, is the .fl2 file or ask help from Maxpower3. I filled that area with 00 and it worked for me.
                                        Hello volinakis, could you describe in more detail what I should do? Where can I get the .fl2 file? Sorry, this is my first time.
                                          1. Remove the battery
                                          2. Remove the CMOS battery
                                          3. Connect the ribbon cable EXACTLY to pin 1 on the left (see photo)
                                          Click image for larger version  Name:	Pins.jpg Views:	0 Size:	118.9 KB ID:	3642180
                                          4. Connect the SVOD4 USB GND cable to the laptop
                                          Click image for larger version  Name:	Connect.jpg Views:	0 Size:	165.1 KB ID:	3642182
                                          5. Start the SVOD Pragrammer v4
                                          6. Select the programmer mode (NUVOTON)
                                          7. Select 1.8 V
                                          8. Select config NUVOTON (256K and NPCE38/48/58/68)
                                          9. Connect the power supply to the laptop
                                          10. Read the ID
                                          11. Read
                                          12. Save the .bin file
                                          Click image for larger version  Name:	SVOD.png Views:	0 Size:	44.1 KB ID:	3642179
                                          13. Open the file with a HEX editor
                                          Click image for larger version  Name:	HEX1.png Views:	0 Size:	119.2 KB ID:	3642181
                                          14. Fill the displayed area with 00
                                          Click image for larger version  Name:	HEX2.png Views:	0 Size:	16.8 KB ID:	3642178
                                          15. Save
                                          16. Then use SVOD4 (Write)
                                          17. Reinstall everything: battery, CMOS battery, and keyboard
                                          18. Start the laptop. Sometimes you have to try 2-3 times.
                                          19. Then it should start.
                                          20. When I restarted, my ThinkPad created a self-healing backup.
                                          21. Then you'll see a message asking you to enter your supervisor password. Just leave it blank and click Continue.
                                          22. Then you'll enter the BIOS.
                                          That was my approach. Unfortunately, I can't get any further here because I can't make any changes in the BIOS.
                                          @volinakis
                                          23. Extract Ec from the update, which is the .fl2 file. Then fill the area with 00.
                                          Unfortunately, I don't fully understand step 23. Perhaps you can explain it in more detail. Thank you in advance.
                                          Perhaps this guide will help someone who's just starting out.
