Lenovo Thinkpad Ec Pwd Bypass
  • LASTname
    • Apr 2024
    • 10
    • PERU
    #61
    Originally posted by Maxpower3
    This happens to me too,
    change the timing and start earlier just before backlight and stays short for less time.
    Mec16 is difficult
    many many tries
    HELLO SIR, whoever addresses you with the utmost respect is a humble follower of your work...I would like to ask for your help...it can be done on a L14 GEN 1...i5 10th...THANK YOU VERY MUCH​
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1356
      • France
      #62
      Originally posted by azanwaqas771
      hi any one can onlock P15 Gen 1 NM-C651
      try
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1356
        • France
        #63
        Thinkpad L14 GEN 1 - GL40-GL5A0 NM-C631
        try
Name:	Thinkpad L14 GEN 1 - GL40-GL5A0 NM-C631.jpg
        • azanwaqas771
          • Feb 2019
          • 50
          • Pakistan
          #64
          try
          not working with stuck on logo
          • imranromi
            • Jan 2015
            • 1290
            • Pakistan
            #65
            Stuck when you connect EPSI IO3
            In EPSI 101 not stuck i check already.
            • azanwaqas771
              • Feb 2019
              • 50
              • Pakistan
              #66
              i connect with ESPI 101
              bro
              • azanwaqas771
                • Feb 2019
                • 50
                • Pakistan
                #67
                I check with ESPI 101 but same stuck on logo
                • lint4u
                  • Nov 2013
                  • 126
                  • lint4u
                  #68
                  Hello Sir
                  Based on the information from Maxpower3 the timing is very important
                  Tq
                  • LASTname
                    • Apr 2024
                    • 10
                    • PERU
                    #69
                    try
                    I tried to understand the image but it is too advanced for me... when I saw his video on YouTube bypass 2 minutes... where it seems that he uses a jumper by touching 2 points and breaks the bios key... I thought it could be done like this as the video... I don't know how to read schematics, I'm very new to that level...
                    • LASTname
                      • Apr 2024
                      • 10
                      • PERU
                      #70
                      I found that it has 2 bios.. I attach photos.. thinkpad L14 i5 10th bios paswoord
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1356
                        • France
                        #71
                        1 wire to ground on one of the points following 1 or 128/127/126 of your choice
                        at startup as indicated in previous posts
                        EC : NPCE68AP
                        L14/L15 gen1 GL40-GL5A0 NM-C631
                        of course, check that the diagram matches
                        Click image for larger version  Name:	Thinkpad L14 GEN 1 - GL40-GL5A0 NM-C631.jpg Views:	0 Size:	372.8 KB ID:	3259076
Name:	Thinkpad GL40-GL5A0 NM-C631.jpg
Name:	Thinkpad L14 GEN 1  GL40-GL5A0 NM-C631.jpg
                        Who has now used this technique and is satisfied with it here ??
                        just to give some feedback
                        • LASTname
                          • Apr 2024
                          • 10
                          • PERU
                          #72
                          EC : NPCE68AP
                          It took me a while to disassemble because the keyboard is somewhat difficult to remove... before trying anything I preferred to consult and thus have safe advice... am I going to connect the ground jumper to 128? for 3 seconds straight? or how should I do it? thank you master!
                          ​​​​​​I leave images so that someone else can help
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1356
                            • France
                            #73
                            Click image for larger version  Name:	Nouveau Image bitmap.png Views:	0 Size:	6.76 MB ID:	3259195
                            Connect your motherboard to an external screen or with the original LCD, being careful.
                            Uses a USB keyboard to make things easier and avoid communication problems with the KBC(Ec)
                            Prepare a ground wire.
                            When everything is ready.
                            You must put a wire on the ground and make a light contact (1 -2 seconds should be enough).
                            If too long, errors occur : Fan error, Bad data, Thermal sensor etc ... and power off​
                            Wait the Logo or just after the backlight.
                            Short contact with pin 128 or 1, wait and release
                            and press F1 to enter setup
                            After clearing security with blank password
                            and clear security chip.
                            Simply restart with Ctrl Alt Del
                            And test now
                            Warning:
                            Do not short before full startup (backlight), nor during shutdown.
                            Follow this carefully, otherwise there is a risk of bricking or corrupted data.
                            • lint4u
                              • Nov 2013
                              • 126
                              • lint4u
                              #74
                              And test now
                              Warning:
                              Hello Maxpower3,
                              This Tutorial is very Awesome and everyone can used this for unlocking their laptop,
                              Thank you for sharing with us,
                              For me its very clear,
                              • LASTname
                                • Apr 2024
                                • 10
                                • PERU
                                #75
                                I couldn't enter... I touched 1 and 128 and nothing... it stays on the logo and if it is before it stays dark... use the point on the USB side and where the screw goes, which are ground and points 128 and 1 and 127 and 126 I did it many times
                                • AHMED14NET
                                  • Nov 2019
                                  • FRANCE
                                  #76
                                  DOES ANY NEWS ABOUT MEC 1503 FOR NM-D341
                                  • Saad Haider
                                    • Feb 2020
                                    • 16
                                    • Pakistan
                                    #77
                                    Lenovo l14 gen2 nm-d271 bios password unlock??
                                    • reamon
                                      • Aug 2020
                                      • 28
                                      • United Kingdom
                                      #78
                                      Hi
                                      Could someone help with solution for Lenovo t14 Gen1 NM-C931 Rev: 1.0
                                      thank you
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1356
                                        • France
                                        #79
                                        Originally posted by reamon
                                        Hi
                                        Mec16
                                        look for j9301 if you have it
                                        https://www.badcaps.net/forum/troubl...61#post3250061
                                        • Maxpower3
                                          Bad Veteran
                                          • Feb 2018
                                          • 1356
                                          • France
                                          #80
                                          NPCE68BPA0DX Lad Pin 126-127-128 or 1 of EC
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
