Sony VPCSB (MBX-237) dead after bios flash
Re: Sony VPCSB (MBX-237) dead after bios flash
Here's another reference thread that can help the rest of you.
https://www.badcaps.net/forum/showthread.php?t=29549Comment
He encontrado estas medidas del sn608098 y deberian ser las buenas, los pines que no salen a tierra miden 0v. :
pin 4- 3,29v
pin 5- 3,29v
pin 6- 19,4v
pin 9- 0,4v
pin 10- 0,4v
pin 11- 0,06v
pin 13- 0,05v
pin 14- 2,07v
pin 15- 0,36v
pin 16- 0,4v
pin 17- 0,19v
pin 20- 0,03v
pin 24- 1,82v
pin 25- 0,57v
pin 26- 2,08v
pin 27- 2,08v
pin 30- 0,5v.Comment
On pin 7 there must be +5VALW_LDO, as its name mention, ALW= always. (siempre)
Regards.Comment
Hello.
Thanks for the help.
I can not have the 3.3v or 5v. Only I have 19v on pin 4 and 6 of sn0608098, which surprises me that the measure in dcbatout irfh3707 or in sir460dp is 0v, or the terminals that connect to docking db 0v too. This means that I have a short dcbatout or this later. I already change the capacitor from here that was in short.
Excuse me for my english.
Thank you very much.Comment
http://i42.tinypic.com/2nlg2vb.jpg
Hello.
I have made this scheme sn0608098 of pin 3, 19 and 7.
You could say me if it´s okay?
Thanks.Comment
Hello.
I let this plate stop and now I've started again.
I changed the mec1609, sir460 and a capacitor, they were wrong.
I have already tensions VALW +3, +5 VALW, + EVCC, pwrsw # _db, pwrsw, system_vref3.
In the power button I have 5v in mind 3v, is this normal?
The plate still does not start, it does nothing, it could be that I have the wrong bios or will be another failure?
Thanks, I hope not to be heavy.Comment
Sorry I don't, I didn't have a programmer before. What I did was to download the original BIOS from Sony using the model number (VPC**** or PCG****).Comment
Try this maybe: http://translate.google.com/translat...121GL-%284M%29Comment
hiI don't know, I can't see which connectors they are.
Yes, if you saw a flash or a blink, probably you made a short-circuit and burnt the SN0608098RHBR. you should change it.
Pin 7 is located near PC205, the one in the green rectangle.
Always check voltages in components connected to pins, not in the pin, it is safe.
How did you know the name of the item PC205, which is not located on the main board
THANKSComment
I'm also trying to repair a Sony VPCSB in my own thread, and I noticed you people are also missing CNX-458 schematics.
Big thanks to atsio, who shared this with me.
Njoy!
Galaxy S6 Edge x2 (Gold&White)
Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
Try Harder!Comment
I get a sony MBX-237 motherboard from http://www.buymotherboard.net/sony-m...ard-p-957.html, but i don't know how to assemble it, anyone can help please. URGENT!!!!!!!!!Comment
watch this youtube video, http://www.youtube.com/watch?v=IHmxg7VIx3Y
its not a easy one for a beginner, take extra care with ribbons, they are easily damaged, just go slowly, you will get there in the end
another that may help, http://www.youtube.com/watch?v=HbxFq-m6t40
and another, http://www.youtube.com/watch?v=mMfAzXeHaGU
there is plenty more on thereComment
Thank you! I fixed mine thanks to your schematic, the power IC wasn't receiving any power in pin 6 (VIN) so I checked the power board and a fuse was open, I replaced it with a 0 ohm resistor and it works now.Hi,
Njoy!
by IhandyrepairHI guys
I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
here is the issue
I have Sony and android logo. but then 4 led red flash lights front of the tv
I have 3.3v ref. 12v reg then T con 12v when I press the power on button
but then I get black screen and 4 red flash light at the front LED
but I get 3 led flash on the LED driver board.
I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
so I tried... -
by what_1282105Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
Channel: BIOS Requests ONLY!
by thstuffA) TV initially dead
B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
C) Was able to perform a Reset from Settings menu and completed out of box configuration.
D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical... -
by lap-top123HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
Hp Elitebook 850 G8
ProdID 52W98EC#ABD
SN# 5CG1458XQ7
Mac-address #1: 84:14:4D:2C:4B:5B
UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
Mainboard : 6050A3216701-MB-A01(A1)-
by bohabohaHello to everyone in this wonderful forum.
I have this SONY LCD TV KDL_46R473a
PSU GL5 APS350 :1-888-122- 12
MAINBOARD FY13_EU IP-012C101-4010
black screen ,no STB no life almost death.
on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
Also 3,5,and 12v are on.
nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
don't know what to do next all suggestions and advice are very welcome... - Loading...
