Vaio VPCSB2M9E/PCG-41218M dead after drop
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Re: Vaio VPCSB2M9E/PCG-41218M dead after drop
    I'm having a really hard time reading it, but it seems to say BQ725 only.
    Thanks.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
    • atsio
      • Oct 2013
      • 819
      • Greece
      Give readings of volts on all pins of BQ725.
      • Learn2Day
        • Jun 2013
        • 254
        • Portugal
        Couple things I should say before..
        It's really hard measuring all pins isolated, maybe my multimeter tips are too big.. That say, might be some discrepancies in readings but I did my best.
        Another odd thing I should mention is pins 1, 2 and 3 initially read 19V but it went to 0V for a couple of minutes, and then came back to 19V..
        1-19V
        2-19V
        3-19v
        4-24V
        5-0V
        6-2.6V
        7-1.4V
        8-1.5V
        9-0V
        10-0V
        11-1.6V
        12-1V
        13-1V
        14-0V
        15-0V
        16-6V
        17-5.6V
        18-1V
        19-1V
        20-19V
        Thanks.
        Try Harder!
        • atsio
          • Oct 2013
          • 819
          • Greece
          Pin 5 should be high, although all conditions are met it is not. Try with a charged battery, and check if laptop powers up. If not, measure charger voltage on all pins again.
          • Learn2Day
            • Jun 2013
            • 254
            • Portugal
            Hey,
            I had already tried to power on battery, but nothing.
            Yesterday I also forgot to mention, these measurements were with board disconnected from main board. Do you want measurements with battery and mainboard connected, or with battery only is enough?
            Thanks.
            Try Harder!
            • atsio
              • Oct 2013
              • 819
              • Greece
              #26
              Originally posted by Learn2Day
              Hey,
              Thanks.
              Pin 5 is going High when power supply adapter is detected allowing 19v to the system. You should have 19V on two NPN fets near charger on source and drain pins and 24 volt on gate pins. If it is possible give the markings on those fets. Also 19v at the six pin connector to mainboard . Forgot to mention to retest for voltage on pin 5 with power suypply connected.
              Read the voltages on charger pins with just the battery connected to check if charger is working.
              I do not see any signals that may be needed from the mainboard for the charger to function properly, so do not connect the mainboard.
              • Learn2Day
                • Jun 2013
                • 254
                • Portugal
                #27
                Battery connected, I still get 0V on pin 5. If I guessed right the NPN fets you mentioned are the ones marked green. All pins read 0V!
                I've been searching like crazy for this board schematics but I can't find them anywhere.. I googled V030_MP_Docking_DB, CNX-458, nothing!
                guruji from this forum claims to have the schematics but he hasn't shared them with anyone..
                Originally posted by guruji
                I have the same problem what i understand they have 2 supply dcbatout and the other is vcc charger r for main mosfet to supply the mosfets i have not started with the laptop repair in full swing but will get my hands on it does anyone want the dockin schem ill email it thanks
                Thanks.
                Try Harder!
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  #28
                  Thanks.
                  Pin 5 should be high only when adapter present. Pin 11 should be 6v (roughly) above the voltage on pin 12 when laptop works with battery. I need to see voltages on all pins of charger with only battery connected to determine if charger is working.
                  Which picture of the fets marked in green are you referring to?
                  Have you checked on the connector to mainboard if you have 19V?
                  I'll try to get the schematic for you. I do not like to ask for many favours because I might need them for me sometimes.
                  • Learn2Day
                    • Jun 2013
                    • 254
                    • Portugal
                    #29
                    Sorry, forgot to upload photo.
                    Pin 5 reads 0V with/without adapter/battery present.
                    Pin 11/12 reads 0.2~1.5V, with/without adapter/battery present.
                    I see 19V on several pins to main board with adapter connected, but on battery all read 0V.
                    I'll do a quick read of all pins and post right back.
                    Try Harder!
                    • Learn2Day
                      • Jun 2013
                      • 254
                      • Portugal
                      #30
                      With battery connected, pin voltages match. I did noticed pins 1,2,3 go from 19V to 0V a lot, maybe caused by shorting pins while reading..
                      1-19V
                      2-19V
                      3-19v
                      4-24V
                      5-0V
                      6-2.6V
                      7-1.4V
                      8-1.5V
                      9-0V
                      10-0V
                      11-1.6V
                      12-1V
                      13-1V
                      14-0V
                      15-0V
                      16-6V
                      17-5.6V
                      18-1V
                      19-1V
                      20-19V
                      Thanks.
                      Try Harder!
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        #31
                        I forgot to ask (now that you have a regulated power supply) what are the amps drawn from laptop when you plug the adapter?
                        • Learn2Day
                          • Jun 2013
                          • 254
                          • Portugal
                          #32
                          Unfortunately my regulated power supply isn't as stable as I'd wish.. But I'm guessing it's current isn't higher that my 5A adapter. 19V supply are steady and neither adapter or laptop shut down 19V supply.
                          Try Harder!
                          • Learn2Day
                            • Jun 2013
                            • 254
                            • Portugal
                            #33
                            Ok, my regulated power supply was supplying 0.06A with 19.5V disconnected from main board with battery connected. Same with main board connected.
                            As I guessed it's not draining too much current, which also means it's not charging battery.
                            Try Harder!
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              #34
                              You measure the current drawn from regulated power supply without pressing power button and without battery.
                              • Learn2Day
                                • Jun 2013
                                • 254
                                • Portugal
                                #35
                                Without battery, same thing.
                                Regarding power button.. All these test are being made without 3rd logic board that connects to power button (see pic) and is attached to palm rest.
                                When I want to test power button I always put all boards back in place and connect all cables.
                                Thanks.
                                Try Harder!
                                • atsio
                                  • Oct 2013
                                  • 819
                                  • Greece
                                  #36
                                  Sorry for not answering earlier but I was too busy today. I think you should change your charger.
                                  I am atouching the schematic you are looking for
                                  • Learn2Day
                                    • Jun 2013
                                    • 254
                                    • Portugal
                                    #37
                                    Wow man! Thank you so much for the schematics!! Awesome!
                                    I was getting myself prepared for replacing the charger. I have a BQ25A which according to aliexpress website is compatible.. Can I use BQ25A?
                                    http://www.aliexpress.com/store/prod...550803482.html
                                    Thanks.
                                    Try Harder!
                                    • Learn2Day
                                      • Jun 2013
                                      • 254
                                      • Portugal
                                      #38
                                      I'm having a hard time soldering BQ25A in perfect alignment. Pins 19 and 20 keep shorting with each other, already took it out and placed it 4 times.
                                      Any tips?
                                      Thanks.
                                      Try Harder!
                                      • Learn2Day
                                        • Jun 2013
                                        • 254
                                        • Portugal
                                        #39
                                        I'm having short circuits in the red dots.
                                        I'm starting to be afraid I'm ruining the board all together..
                                        Try Harder!
                                        • orientalsniper
                                          • Apr 2013
                                          • 461
                                          Before you did all of this, did you check if pin1 of CN5 in power board had 19V? In my case I solved one by replacing the fuse in the powerboard near CN5.
                                          • BTubbs200
                                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                            by BTubbs200
                                            Dell Latitude 5420 P137G
                                            Board: LA-K491P REV A01
                                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                            Board seems to have no shorts, all power rails are fine and show high resistance.
                                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                            01-24-2025, 08:15 PM
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                            This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                          • flat-earther
                                            how to prevent a connected charger from draining battery when not charging?
                                            by flat-earther
                                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                            So the battery is backfeeding the charger and being drained.
                                            How can I prevent...
                                            08-07-2025, 01:04 PM
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
