Sony 55W905 dead
  • Talyn
    • Apr 2024
    Sony 55W905 dead
    My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
    I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
    Any advice? Thanks!
  • Diah
    • Feb 2013
    • 6498
    sony W series are known with BGA issue under the Soc.
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • piposarcade
      Samsung UN50KU6300 dead no standby led
      by piposarcade
      01-04-2024, 01:33 PM
      Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
      05-22-2024, 02:07 PM
    • brithepi2k
      Sony KD-65XE8596 no standby light
      by brithepi2k
      I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
      cheers...
      09-06-2025, 02:22 PM
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
    • rabbituk
      Sony HCD BX7700dbi CMT flashing standby
      by rabbituk
      I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
      So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
      02-11-2025, 05:05 PM
