Sony VPCSB (MBX-237) dead after bios flash
  • derattes
    • Sep 2013
    • 10
    • uk
    #41
    Re: Sony VPCSB (MBX-237) dead after bios flash
    Hey OrientalSniper. Have you got any news ? Did you find the faulty component? I have exactly the same problem here.. Been working on it for 3 days now, Do you have any reading on the r460 next to SN0608098 ? I have zero.
    • orientalsniper
      • Apr 2013
      • 459
      Hello, I've ordered about 3 motherboards, maybe docking board was bad or the motherboards were defective, in the end I gave up and filed it under the X-Files and lost about $175, ending up in the negatives.
      • Francisco.s
        • 686
        • Spain
        #43
        Hi, derrattes, if you have all other voltages in your motherboard, (+3VALW, and +5VALW) could be, we can repair all problems you, both, have.
        As I can see from schematic, (page 43) r460 receives the signal SUS_ON from pin L1 of chip U16. (IC MEC1609-PZP)
        If this signal (3 volts when is active) is not there, could be, U16 is damaged or is not having +ECVCC and +3VALW in its pins C4 and F1---H9 respectively.
        Also check xtal (Y4), and reprogram bios chip, (U6) if needed.
        Post results.
        Good luck
        • Francisco.s
          • 686
          • Spain
          #44
          I thought r460 was a resistance, not a mosfet, so what I have written about, is nothing to take into account.
          • derattes
            • Sep 2013
            • 10
            • uk
            #45
            Is there any way I can test the powerboard cnx458? Also, I have 2v on pin6 of SN0608098 and 0v on pin7 of SN0608098. Any ideas?
            • Francisco.s
              • 686
              • Spain
              #46
              cnx458 is not mention in the schematic we have.
              If you have only 2v on pin6 of SN0608098, then you should check the voltage on pin 1 of PR324. (BQ24725_VCC_R)
              Also check if SN0608098 is getting hot. (also PR324 could be open)
              This voltage came from pin 80 of CN9. This connector came from a board that we haven't the schematic.
              • Francisco.s
                • 686
                • Spain
                #47
                Any advance in this Sony?
                • derattes
                  • Sep 2013
                  • 10
                  • uk
                  #48
                  Hi, Francisco.s , after replacing pr324(which was open) I now have 19v on pin6 of SN0608098 and still 0v on pin7 of SN0608098. Also, SN0608098 is not getting hot... Any suggestions?
                  thank you very much for your help!
                  • Francisco.s
                    • 686
                    • Spain
                    #49
                    If pr324 was open, is due to the pwm IC SN0608098, change it and post results.
                    • derattes
                      • Sep 2013
                      • 10
                      • uk
                      #50
                      Do you think I can replace SN608090 with a SL6236 ?
                      • Francisco.s
                        • 686
                        • Spain
                        #51
                        Yes, if you don´t have the original one, you can replace it with an ISL6236.
                        • derattes
                          • Sep 2013
                          • 10
                          • uk
                          #52
                          I've just replaced SN608098 with a ISL6236 but still have 19v on pin 6 and 0v on pin 7 . I really dont know where to go from here...
                          • Francisco.s
                            • 686
                            • Spain
                            #53
                            Check PC205 for short-circuit or low resistance.
                            If you have 19 volts on pin 6 of SN0608098RHBR, then, there must be +5VALW_LDO on pin 7.
                            • derattes
                              • Sep 2013
                              • 10
                              • uk
                              #54
                              I agree. There should be 5v on pin 7, however for some reason it gives 0v on pin 7 . Perhaps the ISL6236 is not 100% equivalent?
                              The power board connected to motherboard has 0.56v in all pins of the small connector and 0.56v in the first pin of the large connector(I bought this powerboard from ebay) , I wonder if this is the correct reading? Shouldn't it have 5v in each connector?
                              Thank you very much for your help Francisco.S !
                              • Francisco.s
                                • 686
                                • Spain
                                #55
                                I know those chips are equivalent.
                                I haven't any motherboard (mbx-237) to check the connector.
                                Have you check PC205 for short-circuit or low resistance?
                                • derattes
                                  • Sep 2013
                                  • 10
                                  • uk
                                  #56
                                  I replaced pc205 but still same thing ...pin6=19v, pin7=0v .
                                  • Francisco.s
                                    • 686
                                    • Spain
                                    #57
                                    Be sure the solders of the chip are in good contact with pcb, and tell us the resistance between pin 7 and gnd.
                                    • derattes
                                      • Sep 2013
                                      • 10
                                      • uk
                                      #58
                                      Hi Francisco, sorry about the late reply, resistance betw. pin7 and ground is 2.3 ohm. thanks again.
                                      • Francisco.s
                                        • 686
                                        • Spain
                                        #59
                                        Of course, this value is totally wrong and is indicating a leaky component.(probably a capacitor, but anything connected in this node, could be the culprit)
                                        Have a look to PU9.
                                        • silvernadal
                                          • Oct 2013
                                          • 14
                                          • España
                                          #60
                                          Have a look to PU9.
                                          Hello, my name is dani and also I have problems with this board. You speak of pu9 but I can not find it, I know it's the at5208-3.3ker, but I where they locate on the plate?
                                          Thank you very much
                                          • Ihandyrepair
                                            4 red flash led 65X950G boot Sony and android logo but then black
                                            by Ihandyrepair
                                            HI guys
                                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                            here is the issue
                                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                            but then I get black screen and 4 red flash light at the front LED
                                            but I get 3 led flash on the LED driver board.
                                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                            so I tried...
                                            07-11-2024, 01:45 AM
                                          • what_1282105
                                            Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                            by what_1282105
                                            Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                            02-14-2025, 07:27 PM
                                          • thstuff
                                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                            by thstuff
                                            A) TV initially dead
                                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                            12-26-2024, 09:10 PM
                                          • bohaboha
                                            SONY KDL-46R473A ALMOST DEAD NO STB
                                            by bohaboha
                                            Hello to everyone in this wonderful forum.
                                            I have this SONY LCD TV KDL_46R473a
                                            PSU GL5 APS350 :1-888-122- 12
                                            MAINBOARD FY13_EU IP-012C101-4010
                                            black screen ,no STB no life almost death.
                                            on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                                            Also 3,5,and 12v are on.
                                            nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                                            don't know what to do next all suggestions and advice are very welcome​...
                                            04-24-2025, 04:40 PM
                                          • Talyn
                                            Sony 55W905 dead
                                            by Talyn
                                            My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                            I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                            Any advice? Thanks!
                                            04-15-2024, 08:14 AM
