Alienware M14x R2 with 7 beeps error
  • Johndill
    • Aug 2015
    • 314
    Re: Alienware M14x R2 with 7 beeps error
    Originally posted by caspian
    fix the CPU_VCore circuit.
    What voltage should PL703, PL704, and PL705 be showing?
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      #62
      they should be about 1 volt.
      • Johndill
        • Aug 2015
        • 314
        Seeing my original readings where 0.9mV for those three should they be right? Or should they be on the higher side around 1.2V? I haven't had time yet to do any new testing with the LCD cable on.
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          #64
          was it 0.9mV or 0.9V?
          if 0.9mV, it is considered as no voltage.
          • Johndill
            • Aug 2015
            • 314
            Ah ok, I'm sure it was 0.9mV, I'll have to confirm in a few days when I get some free time :-)
            • Johndill
              • Aug 2015
              • 314
              I'm getting 0.0mV across PL703, PL704, PL705 with and without the LCD connected, so I'm not sure how I got the last readings, what should I test next?
              • Johndill
                • Aug 2015
                • 314
                PC733, PC734, and PC766 are 25V 100U caps that had around 10V in them each when turned on then over roughly 30secs they rose to 17V each before I powered down, does that sound right?
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  #68
                  there is no PL705 and PC766 on this board.
                  first measure voltage on all pins of PQ700 after turning on.
                  then, measure voltage on all pins of PU700 if you got time.
                  • Johndill
                    • Aug 2015
                    • 314
                    What do you mean, PL705 and PC766 are both on page 59, are you useing the schematics I posted in post #9? My schematics don't have PQ700 and PU700.
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      #70
                      I found them.
                      yes 17v is normal for that point.
                      remove the battery from your laptop until you fix it.
                      now measure voltage on all pins of PU701 after turning on.
                      avoid shorting neighbor pins together.
                      • Johndill
                        • Aug 2015
                        • 314
                        The Cmos battery?
                        • caspian
                          • Oct 2015
                          • 1591
                          • Laptop
                          #72
                          no, remove the main battery.
                          if you remove the cmos battery, it would be safe too.
                          • Johndill
                            • Aug 2015
                            • 314
                            The board is out of the casing as the components being tested are on the bottom of the board.
                            • Johndill
                              • Aug 2015
                              • 314
                              I'm still testing but I get slight fluctuations each time the 7 beeps start
                              • caspian
                                • Oct 2015
                                • 1591
                                • Laptop
                                #75
                                to make sure, measure voltage on all the 3 pins of PQ1.
                                and read the voltage written on the AC adapter brick.
                                also measure voltage on PL302 after turning on.
                                • Johndill
                                  • Aug 2015
                                  • 314
                                  PU701
                                  1 - 0.6mV
                                  2 - 0.6mV
                                  3 - 0.6mV
                                  4 - 0.1mV
                                  5 - 0.844V
                                  6 - 1.060V
                                  7 - 0.978V
                                  8 - 1.060V
                                  9 - 3.290V
                                  10 - 0.2mV
                                  11 - 0.9mV
                                  12 - 0.9mV
                                  13 - 0.9mV
                                  14 - 0.9mV
                                  15 - 0.9mV
                                  16 - 0.9mV
                                  17 - 0.9mV
                                  18 - 0.2mV
                                  19 - 19.5mV when not beeping, 19.9mV when 7 beeps are sounding
                                  20 - 2.256V when not beeping, flashes between 2.256V and around 2.201V when 7 beeps are sounding
                                  21 - 0.9mV
                                  22 - 0.9mV
                                  23 - 0.1mV
                                  24 - 1.350V when not beeping, flashes between 1.350V and around 1.310V when 7 beeps are sounding
                                  25 - 2.575V when not beeping, flashes between 2.575V and around 2.490V when 7 beeps are sounding
                                  26 - 2.576V when not beeping, flashes between 2.576V and around 2.490V when 7 beeps are sounding
                                  27 - 0.9mV
                                  28 - 0.9mV
                                  29 - 0.9mV
                                  30 - 2.264V when not beeping, flashes between 2.264V and around 2.220V when 7 beeps are sounding
                                  31 - 2.267V when not beeping, flashes between 2.267V and around 2.213V when 7 beeps are sounding
                                  32 - 0.5mV
                                  33 - 0.5mV
                                  34 - 0.1mV
                                  35 - 1.344V when not beeping, flashes between 1.344V and around 2.220V when 7 beeps are sounding
                                  36 - 0.5mV
                                  37 - 0.1mV
                                  38 - 0.5mV
                                  39 - 0.5mV
                                  40 - 0.5mV
                                  • Johndill
                                    • Aug 2015
                                    • 314
                                    PQ1 has no component from factory, what do I do with it?
                                    • Johndill
                                      • Aug 2015
                                      • 314
                                      PL302 was around 0.2mV to 0.0mV, not sure if those readings are wright, will have dinner and come back :-)
                                      • caspian
                                        • Oct 2015
                                        • 1591
                                        • Laptop
                                        #79
                                        instead, measure voltage on PL102.
                                        • caspian
                                          • Oct 2015
                                          • 1591
                                          • Laptop
                                          #80
                                          now measure voltage on PL205 and PL202.
                                          • armands0212@gmail.com
                                            Alienware 15 r2 error 4 beeps code.ram issue
                                            by armands0212@gmail.com
                                            Hi all.i have problem with my alienware 15 r2.basically its keep beeping 4 times at startup-what means there is ram issue.i already tried 10 different ram sticks with different speeds and voltages but nothing helps.tried to flash bios to see if that will help-but no luck.
                                            Ram sockets looks fine as well,cleaned them and carefully inspected
                                            So maybe someone had this problem as well with any of dell laptops and have some ideas what else i can do?
                                            05-23-2023, 12:48 PM
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            The TV does not turn on, the standby indicator is on. All voltages are present.
                                            Emms is dead. Not readable, not detected.
                                            Replaced emmc.
                                            But with another dump there is no launch
                                            Terminal log
                                            UART
                                            AC_ON
                                            RPMB key is not yet programmed
                                            HASH1_VERSION=0x00000000 64bit
                                            E-B
                                            FDE enabled
                                            layout pattern onebin by SAR7,0...
                                            06-01-2025, 02:11 AM
                                          • sushilachuthan
                                            APC UPS error P13
                                            by sushilachuthan
                                            one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                                            the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                                            The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                                            We replaced the SCR with new device,, but the device is not power on as expected.
                                            Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                                            09-26-2025, 09:00 AM
                                          • tech_guru
                                            Dell Alienware 17 R3 - LA-C912P Motherboard repair - 7 Beeps
                                            by tech_guru
                                            Hello.
                                            I am having a disappointing motherboard repair with this laptop and I need your help.
                                            This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
                                            -UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
                                            -PQ102 MDV1525URH
                                            -U17 AOZ1331
                                            -UE1 C8051F383-GQ
                                            -PU800 SY8032ABC
                                            -UI2 SY6288D20AAC
                                            -PU508 RT6220AHGQUF 7P=
                                            -PU100 TPS51225CRUKR
                                            -PU300 TPS51212DSCR
                                            Now, I get all the standby voltages, it turns...
                                            02-16-2024, 09:40 AM
                                          • zwect
                                            Dell Alienware 17 R1 / M17X R5 / LA-9331P REV 1.0 - 7 beeps
                                            by zwect
                                            I have this Alienware 17 laptop with the VAS00 LA-9331P REV 1.0 motherboard that does not turn on anything when power is plugged in and gives the 7 beep sequence, CPU / GPU does not heat up, i tried only with an I5 4200M (the laptop did not come with either the GPU or the CPU, but on the back says that it originally came with the Nvidia 860M and an 4710MQ).
                                            While i do not know if there is any CPU blacklisting system on the motherboard, i tried reflashing the BIOS (at UH14) and the EC (at U2) accordingly but no changes either.
                                            PCH doesn't seem to be shorted but i haven't done...
                                            12-29-2024, 06:57 PM
