Hi, I have an M14x R2 with 7 beeps error, when I boot it I get the 7 beeps and the speaker sounds like it doesn't have much power, only some of the keyboard lights light up, and change colours as well as dim each time a beep sounds, would there be some kind of power issue? Thanks
					Alienware M14x R2 with 7 beeps error
Re: Alienware M14x R2 with 7 beeps error
Thanks for your reply, I don't have another CPU to try but it is unlikely to be the CPU as 7 beeps also means another issue with the motherboard.Comment
One thing I've missed is it is missing the LCD ribbon cable as the previous owner sent it to a repair shop and they must have broken it, it doesn't display via VGA nor HDMI, does it require the LCD to be connented to complete post, I've used other laptops without a display connected before via VGA.Comment
My board is "LA-8381P", is this the correct one:https://cdn.badcaps-static.com/pdfs/...509ff903a8.pdfComment
PL202 - 3.325V
PL303 - 0.5mV
PL403 - 0.3mV
PL504 - 0V
PL604 - 0VComment
			Hi all.i have problem with my alienware 15 r2.basically its keep beeping 4 times at startup-what means there is ram issue.i already tried 10 different ram sticks with different speeds and voltages but nothing helps.tried to flash bios to see if that will help-but no luck.
Ram sockets looks fine as well,cleaned them and carefully inspected
So maybe someone had this problem as well with any of dell laptops and have some ideas what else i can do?
Thanks05-23-2023, 12:48 PM -
			by Sus256Hi all!
HISENSE 65E7KQ PRO
RSAG7.820.13512 - chassis
MT9618BAATAB - cpu
RSAG7.820.12059 - power
HD650Y3U77 - panel
KLM8G1GETF - emmc
Replaced emmc.
Terminal log
UART
AC_ON
E-B
FDE enabled
layout pattern onebin by SAR7,0... -
			one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
We replaced the SCR with new device,, but the device is not power on as expected.
Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....09-26-2025, 09:00 AM -
			by tech_guruHello.
I am having a disappointing motherboard repair with this laptop and I need your help.
This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
-UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
-PQ102 MDV1525URH
-U17 AOZ1331
-UE1 C8051F383-GQ
-PU800 SY8032ABC
-UI2 SY6288D20AAC
-PU508 RT6220AHGQUF 7P=
-PU100 TPS51225CRUKR
-PU300 TPS51212DSCR
Now, I get all the standby voltages, it turns... -
			by zwectI have this Alienware 17 laptop with the VAS00 LA-9331P REV 1.0 motherboard that does not turn on anything when power is plugged in and gives the 7 beep sequence, CPU / GPU does not heat up, i tried only with an I5 4200M (the laptop did not come with either the GPU or the CPU, but on the back says that it originally came with the Nvidia 860M and an 4710MQ).
While i do not know if there is any CPU blacklisting system on the motherboard, i tried reflashing the BIOS (at UH14) and the EC (at U2) accordingly but no changes either.
PCH doesn't seem to be shorted but i haven't done... - Loading...
