Alienware 15 r2 error 4 beeps code.ram issue
  • armands0212@gmail.com
    • Oct 2021
    • 28
    • Latvia
    Hi all.i have problem with my alienware 15 r2.basically its keep beeping 4 times at startup-what means there is ram issue.i already tried 10 different ram sticks with different speeds and voltages but nothing helps.tried to flash bios to see if that will help-but no luck.
    Ram sockets looks fine as well,cleaned them and carefully inspected
    So maybe someone had this problem as well with any of dell laptops and have some ideas what else i can do?
  • Simone Vergani
    Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
    by Simone Vergani
    I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
    To assist with troubleshooting, I'm attaching two power circuit schematics:
    • Power
    03-05-2025, 02:25 PM
  • abajor
    Alienware Area-51 R2 Boot Loop issue.
    by abajor
    I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
    It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
    To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
    Right now I'm trying to dig through the PDF schematics and Board...
    03-08-2024, 10:08 PM
  • zwect
    Dell Alienware 17 R1 / M17X R5 / LA-9331P REV 1.0 - 7 beeps
    by zwect
    I have this Alienware 17 laptop with the VAS00 LA-9331P REV 1.0 motherboard that does not turn on anything when power is plugged in and gives the 7 beep sequence, CPU / GPU does not heat up, i tried only with an I5 4200M (the laptop did not come with either the GPU or the CPU, but on the back says that it originally came with the Nvidia 860M and an 4710MQ).
    While i do not know if there is any CPU blacklisting system on the motherboard, i tried reflashing the BIOS (at UH14) and the EC (at U2) accordingly but no changes either.
    PCH doesn't seem to be shorted but i haven't done...
    12-29-2024, 06:57 PM
  • Bupi452
    Alienware m15 r5 Ryzen 9 5900hx RTX 3070 MB-DC in connector issue
    by Bupi452
    Hi, everybody
    Yesterday I was about to re-paste my laptop, when during the disassembly I noticed that the DC cable from DC plug to the mainboard looked discolored​ and after a bit of prying I found out why...
    I am looking for the socket on the mainboard does anyone have an idea where I could get one? I have already looked in the board drawing and found out the manufacturer (ACES_50493-01301-P01) but it does not seem to be available for purchase...
    does anyone an idea where I could get one?
    PS
    The cable has a part number and can be bought on EBAY but I did not find...
    01-08-2025, 11:51 PM
  • Nikan.e
    Alienware 13 R3 repair - power issue or bad super-IO?
    by Nikan.e
    Greetings and Salutations!
    I have BAP00 board in front of me, which does not want to turn on. Nothing except for the AC power is connected.
    +3VLP - present
    RTC power - present // no battery connected
    * +3VALW - present
    * +5VALW - present
    * +LAN_IO - 0.00V
    * +3V_PCH - 0.05V
    * +1VALW - 0.00V
    * +1V_PCH_PRIM - 0.00V // same rail as +1VALW
    Note : ON* means that this power plane is ON only with AC power available, otherwise it is OFF
    +1VALW - 47Ohms
    +3V_PCH - MOhm range
    +LAN_IO - 100KOhm...
    11-07-2024, 03:51 PM
