Will someone have the BIOS Files available for the PS5 CFI-1015B EDM-010 since it has been impossible for me to find them anywhere
playstation 5 digital firmware dump
You can try this one:
Attached FilesComment
(New Member), Greetings Everyone, looking for some PS5 wisdom, I have a CFi-1116A (EDM-020) that someone (not me) has got it stuck in IDU mode and it's updated to firmware 9.20, would flashing the bios with a clean working dump get it out of IDU mode? any help would be very welcome.Comment
You can turn off the IDU mode by reading the NOR data by a programmer, edit adress 0x001C9604 = 00 (IDU off) / 01 (IDU on) and write the NOR data back to the ic.(New Member), Greetings Everyone, looking for some PS5 wisdom, I have a CFi-1116A (EDM-020) that someone (not me) has got it stuck in IDU mode and it's updated to firmware 9.20, would flashing the bios with a clean working dump get it out of IDU mode? any help would be very welcome.Comment
Thank you Cobbes, it worked perfect and I've now been able to restore the PS5 to factory settings, I really appreciate your help & wisdom.Comment
Need further help, I've got a PS5 disc edition EDM-020 that had the NOR IC missing when I got it, I got it back up and running by using a bios/NOR IC & matched disc drive from a scrap console, however although the disc drive works fine and I can install & run games from it, if I download a game from PSN when I try to run it a error comes up saying "can't connect to server to verify license", I'm guessing that because the NOR is not matched to the APU/serial number, if this is correct then how do I change the serial number on the NORComment
You can use PS5 Nor Modifier...search on Google, its free...Need further help, I've got a PS5 disc edition EDM-020 that had the NOR IC missing when I got it, I got it back up and running by using a bios/NOR IC & matched disc drive from a scrap console, however although the disc drive works fine and I can install & run games from it, if I download a game from PSN when I try to run it a error comes up saying "can't connect to server to verify license", I'm guessing that because the NOR is not matched to the APU/serial number, if this is correct then how do I change the serial number on the NORComment
Thank you rui4892, I have downloaded the Nor modifier so will give it a try, I'm not sure if changing the serial number will work or not seeing as the NOR & matched disc drive were from another console, only one way to find out, I will let you know how it goes, many thanks for the info.Comment
cfi-2016 3 beeps NO POWERComment
Still having problems with a PS5 "can't connect to server to verify licenses", tried restoring licences via system menu but it throws up an error code two thirds through (error code CE-105628-2) anyone have any ideas to a solution? tried resetting console, reinstalling systems software via USB etc, the console will install and play games via disk with no problems, it's only games downloaded from PSN that throws up the error & won't start the games, the console updates fine.Comment
Need help with, edm-040, cfi-2015.
Getting:80801F12 Known Unknown 80801F12 (Kernel) - Report Findings - 1 sec blue light
any leads would be appreciated with the fix.
Ps5 draws: .2 - .3 and lowers to .07 Amps.
During this stage,
1. cxd90069gg ( southbridge ) heats up to 35c
2. RT5126 heats up to 30c
3. Da9081 heats up to 30c
No shorts found on the main board.
Any idea or leads ?Comment
by AhariHi all,
I...-
by Tamo NekoHello everyone,
I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
What Happened:
I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.- I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
- My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
- A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
1 Photo-
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? -
by gun4asHello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
08-25-2025, 04:28 AM -
- Loading...
