playstation 5 digital firmware dump
+ More Options
Posts
    • 31183
    Re: playstation 5 digital firmware dump
    no encryption, just look at address 001c:7200 for the version info
    • Mario875
      • Jun 2023
      • 15
      • Far Away
      Thanks! I can see the info at 001C7230, but on 001C7200 & 001C7210 there appears to be some kind of string, is that the disc drive key?
      Or if not, can you confirm the location of the disc drive key?
      EDIT: Looks like the .bins I have are as follows:
      1. CFI-1015A
      2. CFI-1016A
      3. CFI-1016A (2nd one)
      4. CFI-1016A (3rd one)
      5. CFI-1016A (4th one!!)
      6. CFI-1016B
      7. CFI-1116B
      So that's 5x disc edition ones and 2x digital edition ones.
      Just need to figure out where the keys are stored now.
      • crasher381
        crasher381 commented
        Editing a comment
        Could you share the 1116B file, I want to see if it will work with the 1115A I have. Thank you
      • 31183
      001c:7270-7281 may be drivekey.
      i deduced that from the fact that every disc dump is different, but every digital dump is just "FF"
      • pahblo
        • Jun 2023
        does anyone have a cfi-1015b bios bin file or know where i can find one
          • 31183
          try using 1015A and filling in the drivekey bytes with FF
          • omegen
            • Apr 2023
            • israel
            #26
            Hello
            have 2 ps5 with different problems:
            first - pressing power, there is one beep, no image and no cooler;
            if press each second, have beep each 7-9 seconds. Checked ssd voltages -.9, 1.2,2.1 one each ssd chip after beep for few seconds, then 0.
            Cpu V not initiating, no shorts.
            Second - turns on, gets red screen and shuts off randomly - can be 1 minute or 15 minutes, on game or just paused. Did software restore latest - same.
            tnx
            • Tiago199988
              • Jan 2020
              • 4
              • Portugal
              #27
              Originally posted by Mario875
              So, I have some BIOS files, but how can you confirm which console they are from? I assume these are encrypted and need to be reversed some kind of XOR value and possibly byte swapping, but I have no idea where in the hex to start looking.
              Anyone got any info on this?
              you can use this tool https://www.consolefix.shop/blogs/la...0-0-0-released just load the file and it will tell you
              • ZOrd_Z
                • Jul 2013
                • 80
                • Portugal
                #28
                Hi.
                Does anyone have a dump for CFI-1016A. I used CFI-1015 provided here, it got better, now makes 3 beeps... Used ps5NORmodifier.
                Thanks....
                  • 31183
                  • ChocoboGS
                    • Aug 2023
                    • 7
                    • Indonesia
                    #30
                    Does anyone have nor dump ps4 cfi-1100? My ps5 pulsing blue light, all voltage normal, no short component. Thanks ^_^
                    • ChocoboGS
                      • Aug 2023
                      • 7
                      • Indonesia
                      #31
                      sorry ps5 CFI-1100
                        • 31183
                        thats a japanese 110. you could try a european 110 (1106) but i dont have any 110 dumps
                        • ChocoboGS
                          • Aug 2023
                          • 7
                          • Indonesia
                          #33
                          same, I don't have a back up nor CFI 11xxx
                          • lilkobe
                            • Nov 2015
                            • new york
                            #34
                            Hi Mario,
                            I need a firmware dump for the cfi-1116B.
                            Can you help me out?
                            Thanks in advance
                            lil-kobe
                              • 31183
                              tell me if it works
                              • pRoZz1ni
                                • Sep 2023
                                • Portugal
                                #36
                                Hi! I have the CFI-1016a version and the light failed when I was playing. Now the console won't turn on. From what I saw the problem is with the firmware. I've already flashed the various versions that were posted here on the forum and the best I got were the 3 beeps when the power cable was connected. Any other dumps you can post?
                                *I changed the serial number with PS5 NOR Modifier 1.0.
                                • ZOrd_Z
                                  • Jul 2013
                                  • 80
                                  • Portugal
                                  #37
                                  Corrupted CFI-1016A, PS5 does nothing. If some one can restore this one, thank's....
                                  • jacobtc
                                    • Apr 2016
                                    • 274
                                    • Denmark
                                    #38
                                    Does anyone have a clean 1016B bios? I've attached the one from my PS5 Digital.
                                    • ChocoboGS
                                      • Aug 2023
                                      • 7
                                      • Indonesia
                                      #39
                                      Anyone have a bios for CFI-1100A?
                                      To check the bios detail, just use PS5 NOR Modifier from TheCod3r
                                      • Mistreics
                                        • Sep 2023
                                        • Italia
                                        #40
                                        Hi, I have a problem. I have a PS5 digital with 3 beeps that won't turn on. I read the firmware and verified that it is a CFI-1016B. Thanks to you, I also recovered a working firmware but I don't know how to overwrite the original serial number of the PS5 because NOR MODIFIER does not have the 1016B in its "board version". Can anyone explain or help me?
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Tamo Neko
                                          Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                          by Tamo Neko
                                          I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                          What Happened:
                                          I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                          • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                          • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                          What I Need:
                                          • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                          02-12-2025, 11:29 PM
                                        • Mephysis
                                          DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                          by Mephysis
                                          Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                          I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                          03-27-2025, 02:34 AM
                                        • gun4as
                                          Need firmware dump for LG 23MP48HQ-P
                                          by gun4as
                                          Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
                                          08-25-2025, 04:28 AM
                                        • eurocomputerland
                                          Canon iSensys MF264DW II, firmware memory dump
                                          by eurocomputerland
                                          Hi, i have canon mf264 printer which is stuck in download firmware mode and I'm after a firmware memory dump for this model, so I can try to rewrite. Thanks for your kind help!
                                          07-22-2025, 04:48 AM
