Short to gnd display board Honeywell Relay Module
  • WHaThEFLuX
    • Feb 2015
    • 277
    Hello All,
    Back at it again with another board issue.......
    I unknowingly plugged a display module that had a shorted diode into this board, the result was a puff of smoke and the crater by the ground plane seen in the picture below. Having another board with the same issue, I began to test and remove components one by one with the hopes of figuring out what the shorted diode destroyed but haven't had any luck.
    It seems that many components are shorted to ground as well after the initial incident, I'm not sure how else to diagnose this issue other than removing every single component until the short disappears.
    As always any ideas or advice would be greatly appreciated!
    "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
    -retiredcaps
    Re: Short to ground on display board, how to find the culprit?
    So you have a board with shorted circuit that you connected to this board and it blew up the inductor L??.
    Are you trying to find out where the shorts are in the display board or you are trying to find out what get damaged on this board when shorted board is connected to this board?
      • 31029
      multi-layer.
      if you want any chance of fixing that, you need a schematic - there is probably damage between the layers.
      • WHaThEFLuX
        • Feb 2015
        • 277
        Thanks for the quick responses guys!
        Bud, I found the shorted diode on the display board, replaced it, and now it's working correctly. I'm trying to determine what is shorting to ground on the board in the picture, and it seems to be everything, literally.
        I'm afraid stj is probably right, and there is most certainly no way of obtaining a schematic for this board. Anything I can try to salvage this thing or is it not worth the effort? As an interesting side note, I've repaired the same model board with the same burn mark, just not as severe, should I assume that on those boards the damage wasn't bad enough to affect the layer under it?
        I'm still trying to wrap my head around single layer boards but multi-layer? That a whole new dimension of unknown to me.......
        -retiredcaps
          It seems to me that that output pin of the JF1 connector that goes to the blown inductor is probably for supplying the Voltage to the display board.
          Please clean up the board so you can easily see the trace to find out how that inductor is connected in the circuit.
          When you are saying shorted to ground, at which point on the board that is show 0 Ohms to GND?
          BTW, so you have more than one of this board?
          • WHaThEFLuX
            • Feb 2015
            • 277
            Your first assumption is absolutely correct.
            When I say shorted to ground, I mean that when I beep test from the ground plane to most other components on the board, it beeps. On a functioning board, all of these components do put out an Ohm reading when tested, but don't beep. When power is connected to the board it just about catches on fire around that black crater by the ground, leading me to believe that there is a direct short to ground there.
            I have many of these boards at my disposal, attached is a picture of a working one. In most cases, the L7 inductor is the only component that is bad, replacing it makes the board function correctly.
            -retiredcaps
              What is the threshold of your meter when set to continuity test mode for it to beep? Most meter will beep with resistance as high as 50 Ohms. Using beeping mode to look for shorts is not valid, you need to check the resistance.
                • 31029
                there is a via in the crater, you need to grind out all the carbon and then link anything that got cut.
                  So it looks like VCC plane supplies Q10 Collector is Voltage the supply for the L7, that VCC plane also goes to the two connectors' pin.
                  Pictures of the bottom side of the board?
                  • WHaThEFLuX
                    • Feb 2015
                    • 277
                    Not sure about the meter as it is a cheap one, I'm at work now but I will take a picture of the other side when I get home!
                    stj, how do you know there's a via in the crater? I've attempted to grind that spot out on other boards, it seems like there was copper there, not sure how I would figure out where it goes?
                    Thanks so much for all your help guys, I was about to give up on this but there might just be a way to repair it, I'm also not opposed to running jumper wires if need be.....
                    -retiredcaps
                    • R_J
                      • 9535
                      Did this board get some water on it? it looks like it (white residue around JF1 pins) That could have started the arcing under the L7 coil, so once the carbon is removed it might be ok???
                        I don't think there is any VIA under that inductor, just remove the inductor and see.
                          • 31029
                          directly right of the upper pad of L12
                          it's tiny, it could be a "hidden via"
                            I thought you are talking about there may be VIA under the L7, the VIA above L12 looks intact to me.
                              • 31029
                              not above, directly to the right in the center of the crater - it may have been linking the upper missing pad.
                              • WHaThEFLuX
                                • Feb 2015
                                • 277
                                Here is the other side of the board.
                                I might be able to take a scrap board and scrape the solder mask away to see what's going on underneath that area, is that worth doing?
                                -retiredcaps
                                • R_J
                                  • 9535
                                  it seems to be double side board, there might be a middle layer but I doubt it.
                                  This looks like the ic and it is connected to the pzt2222at1 transistor.
                                  I flipped the bottom view so it makes it easier to trace
                                    I think the OP need to really verify the so called 'SHORTS' because the meter is beeping in continuity mode, it beeps does not means it is shorted.
                                    • WHaThEFLuX
                                      • Feb 2015
                                      • 277
                                      Bud, I apologize for my naivety, in my experience when damage occurs to that extent it is usually due to a short to ground, especially with the ground plane being right there......
                                      On the working board, many of the components read OL on the meter when tested between them and the ground plane. On this board, literally half of the components show continuity to ground, indicating something is seriously wrong.
                                      My expertise is extremely limited, if you could offer a theory as to why that is happening or what I can do to diagnose what's going on I'm all ears.
                                      -retiredcaps
                                        That board (Voltage supplier) looks to be supplying the Voltage through that inductor to the connector JF1 pin to the display board (the load), so when you have shorted load (shorted Diode on the display board as you had described), that inductor will blow up due to very high current flowing through it; the inductor can only handle current up to the limit of the spec.
                                        Since you do have working set of board why don't you just check the DCV on that pin of the connector.
                                        May be you should up load the pictures showing how all the boards are connected together and how the Power supply is connected to this device which we do not have have the make and model yet.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • duwane
                                          MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                                          by duwane
                                          Hi All.
                                          I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                                          Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                                          After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                                          Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                                          10-17-2023, 07:48 PM
                                        • valvashon
                                          Repair Success! Middle Atlantic UPS2200R-IP
                                          by valvashon
                                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                          02-06-2024, 12:54 PM
                                        • survivalbloke
                                          Need help pinpointing my short on this board (Lenovo) NM-D351
                                          by survivalbloke
                                          This is a Lenovo Thinkpad P15s Gen 2 with a board NM-D351. I'm having trouble finding my dead short to ground. I have the area narrowed down after much probing. You'll see in the boardview, there are two coils involved. I removed those coils and verified that that short is not on the mosfet side of those coils. . You'll see an arrangement on both sides of the board of 5 caps and one smaller one to the side. I have removed ALL 12 of these small caps and still have the short. Prior to that I injected at those caps with 1v5a and the short was only drawing 800ma so I could not see anything on thermal....
                                          03-23-2024, 11:24 AM
