MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
  • duwane
    • Mar 2022
    • 55
    • New Zealand
    Hi All.
    I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
    Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
    After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
    Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to around 45mA, then zero for a second or so, then resets and process starts over. Doing the same thing on both USB-C ports.
    Can't seem to find any other shorts.
    Have tried the see if it is stuck in DFU mode, but doesn't show in DFU at all, so doesn't seem to be stuck in DFU mode.
    Measured voltages:
    CD3217 support voltages:
    PP3V3_S2_UPC: pulsing – Unsure of voltage (no scope) – 0.44v diode mode to ground
    PP5V_S2: 0v - 0.264v diode mode to ground
    PP1V25_S2: pulsing – Unsure of voltage (no scope) – 0.252v diode mode to ground
    Other voltages:
    PP3V8_AON_VDDMAIN: 3.79v
    PPBUS_AON: 12.28v
    P5VS2_PWR_EN: 0v
    P5VS2_EN: 0v - 0.348v diode mode to ground
    PPBUS_5V_S2_VIN: 12.28v
    So based on this, my guess is that U8100 is bad (seeing as P5VS2_EN is missing and is produced by U8100) and possibly U7700.
    The only thing worrying me is that the diode mode test for P5VS2_EN still looks fine compared to the readings listed on openboarddata.org for P5VS2_EN and to my working donor board. Also, it seems strange that the initial short was related to a rail that is produced by U7700, but the missing enable is generated by U8100. I am not sure how these 2 chips interact with each other but hopefully someone else may have a better idea.
    I am thinking of swapping out U8100 and possibly U7700 from the donor to see if that sorts out the issue.
    So, based on this plan I have 2 questions:
    1) Does replacing U8100 and/or U7700 sound like the right way to go, or could there be some other reason why U8100 isn't producing the P5VS2_EN enable signal? What else could cause this type of behaviour?
    2) If I replace U8100 and U7700 will data remain intact? As in assuming that replacing U8100/U7700 gets the board working again, would I still be able to recover the client's data, or does replacing U8100/U7700 mean that a DFU is required to get the board running after replacement? As mentioned, the board is here for data recovery, so don't want to attempt anything that could put the data at risk.
    Thanks in advance for the help, and any/all help is appreciated.
  • duwane
    • Mar 2022
    • 55
    • New Zealand
    Re: MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had sh
    Found something else that may or may not be related. When testing resistance to ground between working donor and faulty board, I get some wildly different measurements around U5700.
    For example:
    Resistance to ground, and diode mode to ground at the highlighted test point (PP5907) on both boards:
    Donor Board: 267 Ohm -0.131v diode mode to ground
    Faulty Board: 380k Ohm - 0.324v diode mode to ground
    Resistance to ground and diode mode to ground at the highlighted pad (pin 2 of C5811) on both boards:
    Donor Board: 266 Ohm - 0.131v diode mode
    Faulty Board: 440k Ohm and still dropping after waiting 3 minutes. - 0.324v diode mode
    The remainder of pins around U5700 are fairly close between donor and faulty board.
    Not sure if this could be related to the actual issue.
    U5700 is on the direct opposite side of the board from the underfilled NAND chips, so wouldn't want to do that unless absolutely necessary and a likely culprit.
    Worth swapping out U5700 and could this be causing the main issue?
    • duwane
      • Mar 2022
      • 55
      • New Zealand
      Ok, so I have now replaced U8100, and U5700, as well as both of the CD3217's from the working donor, and no change at all in behaviour.
      Still stuck at 5v, with
      PP3V3_S2_UPC pulsing,
      PP5V_S2: 0v
      PP1V25_S2: pulsing
      P5VS2_EN : 0v
      What else could be causing being stuck at 5v?
      • khj
        a2337 PP5V_S2 missing no short.
        by khj
        I have a a2337 m1 MacBook Air that has no power.
        PP5V_BSTLQ_SPMU is shorted so I fix it by change cap, coil, u7700. now normal voltage.
        when I didn't connect battery , plugged in power, there is only 5V 0.25a.
        so I checked every power rails , I finally founded PP5v_s2 is 0v, but there is no short.
        PPBUS_5VS2_VIN = 12V normal
        P5VS2_EN from U8100 = 0.6V maybe normal
        P5VS2_FB,PGOOD,VC,SS,BIAS,INTVCC = very low voltage maybe abnormal.
        what should I do ?? do I need to change uc300?
        12-06-2023, 07:00 AM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        🛠 Original Issue
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • Adogabriel100
        where to get trusted CD3217. Problem with A2337 Macbook Air
        by Adogabriel100
        Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
        The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
        09-06-2024, 12:06 PM
      • soeren
        A2337 - Camara doesn't work
        by soeren
        I have replaced the display on my A2337 and I believe that during the change the battery connector was re-connected to the logic board and therefore I now have a non-working camera in my A2337 laptop.
        After the problem occurred, the camera was no longer detected and True Tone didn't work. I replaced the eDP flex cable (display connector) and now the camera is detected and True Tone works again.
        The problem is that when I open Facetime, for example, the green camera LED does not light up and the camera image remains black. In the end I get an error message. Does anyone...
        08-23-2024, 09:02 AM
      • sergiobtnrs
        Macbook A2337 820-02016 5.135V 0.275A
        by sergiobtnrs
        Hello!
        New to this forum, I have a 820-02016 board which cannot turn on.
        This one does 5.135V ~275mA for a short time, then goes down to ~100mA before shutting down and starting the cycle anew (USB-C multimeter).
        Measured the mentioned points:
        PP3V8_AON_VDDMAIN - ~3.8v
        PPBUS_AON -12.3V then 12.0V and going down during reset
        PPVDD_SOC_S1 - ~0.67v
        PP1V8_S2 - ~1.8v
        PP2V5_AWAKE_NAND - 2.5v
        PP1V25_S2 - 1.22v
        PP3v3_S2_UPC - 3.28v
        PP5v_S2 - 5.2V
        PP3v3_UPC0_LDO - 3.25v
        PP3v3_UPC1_LDO - 3.25v...
        09-12-2023, 01:35 AM
