Help with Motor Control Board - ProForm treadmill
  • selldoor
    Slow Learner
    • 7870
    #41
    Re: Help with Motor Control Board
    Just closing down for tonight and the picture for budm of the top of the board flashed up
    and whilst i had not noticed before is there a hole in the top of one of the BIG caps?
    May be just dust showing up odd in the picture or the hole may only be in the plastic top
    but maybe have a close look?
    • Crrose
      • Dec 2013
      • 165
      • Usa
      #42
      No that hole is the screw hole into the mounting board. I could only find the one 24v 5w diode. Everywhere I went they were out of the smaller 5v 1w diode. I even asked if they had a 2 or 5 watt but no luck so I have to either order one or drive 25 miles to another store.
      I picked up the NTE5137A but couldn't find the NTE5116A.
      • Crrose
        • Dec 2013
        • 165
        • Usa
        #43
        Originally posted by budm
        That will be 15V Zener, if the legs will fit the holes then I would go with higher Wattage.
        I would also mount them with body above the board like 0.100"~0.250" to allow better air flow.
        So the C15PH is a 15v not a 5. Maybe I'll be in luck and they will have that one.
          • 31084
          c15 = 15v usually.
          • Crrose
            • Dec 2013
            • 165
            • Usa
            #45
            Ok thanks, I'll look for a 15v 5w zener then.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              You might also what to check out the wire wound power resistor next to the zener diodes. I do not know the values they should be. It could had burnt out or the value could have changed. There seems to be a black mark by the one.
                • 31084
                btw, if the zeners are getting hot you should mount the new ones a few mm above the board so air can circulate under them.
                • Crrose
                  • Dec 2013
                  • 165
                  • Usa
                  #48
                  Ok I was able to find the smaller 15v zener. These are both larger in size then the ones I removed, would that matter other then the fact it would be a tighter fit in the board? If not I'll get to soldering.
                    • 31084
                    get soldering
                    • Crrose
                      • Dec 2013
                      • 165
                      • Usa
                      #50
                      Getting excited hoping this works. One more question, as you can see in the photo one of the diodes does not have a stripe so the arrow with the line represents negative side correct? Also if I put them both on with the negative on the same side then you can see in the one picture that the DZ4 negative connects up to DZ1 positive correct?
                        "one of the diodes does not have a stripe so the arrow with the line represents negative side correct?" Correct.
                        " you can see in the one picture that the DZ4 negative connects up to DZ1 positive correct?" Cathode of DZ4 is connected to the Anode of DZ1.
                        The BAR on the pointing end of the Triangle is the Cathode.
                        • philliesfan30m
                          • Aug 2013
                          • 542
                          yes that is correct solder them in the same way you have them lined up in pic 1 onto the board the same way
                          • Crrose
                            • Dec 2013
                            • 165
                            • Usa
                            #53
                            Perfect thanks for the quick response.
                            • philliesfan30m
                              • Aug 2013
                              • 542
                              yes that is the way they are connected.
                                BTW, the pads on the board for DZ1 and DZ4 Cathode look damaged, make sure you do have good connection since they run hot.
                                • Crrose
                                  • Dec 2013
                                  • 165
                                  • Usa
                                  #56
                                  I checked the pads and they were ok at least by a continuity check. I installed the diodes but unfortunately it still doesn't work. Removed the board and the diodes still read 530 and 632 so at least I didn't blow them I don't think.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #57
                                    I can hardly wait!! I have one of these (different make/model/ and boards) but similar
                                    symptoms. Main problem is it has a dc motor with a voltage higher than I can test it.
                                    No burning smell though. Collecting info on it at the moment then will be back for help.
                                    Catch 22 - wife says no way is that coming into the house unless it is working and I cant fix it where it is ,so it is -stuck in my sons garage- I will get round and get pictures
                                    and start a new thread. I suspect/hope it is one of the sensors adrift.
                                    oh: started watching tv so posted late - back to the drawing board eh.
                                      • 31084
                                      i had one a while back with a dead encapsulated transformer on it driving (or not driving!) the digital parts.
                                      btw, have you noticed how shity NTE rebaged parts always look!
                                      i would never touch them, people blame the chinese for re-printing onto junk, but NTE did it first!!
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #59
                                        Have you at any time taken a voltage reading on the BIG caps?.
                                        May be of course that if that relay doesnt work it never switches on?
                                        Can you apply 24v externally to the relay and see if it clicks or if the
                                        110 v contacts close (meter on ohms)
                                        • Crrose
                                          • Dec 2013
                                          • 165
                                          • Usa
                                          #60
                                          How would I apply 24v externally to the relay?
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Yanleb
                                            LG 60PK550 Logic Control Board EBR63450301
                                            by Yanleb
                                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                            C57: 3.30V
                                            C61:...
                                            07-20-2023, 12:38 AM
                                          • cyclones
                                            Motor control board repair
                                            by cyclones
                                            I have a motor control board I am trying to repair. I've been told the motor is fine, but the control board will only make the motor go one direction but not the other. Power comes in through a linear transformer and then a rectifier bridge and then filter caps. No schematics for the board. Relays on the board are 24V so I started by setting my bench PSU to 24V and injecting voltage. There are several LEDs. All but one LED lights up. There are test points labelled +15V, 0V and -15V. When checking voltage potential between +15V and 0V, I get a perfect 15V. For -15V to 0V, my meter shows approximately...
                                            10-30-2021, 10:39 PM
                                          • eagleeyez
                                            Treadmill Motor Control Board 032669-IF
                                            by eagleeyez
                                            I am looking for this Treadmill Motor Control Board 032669-IF schematic or how to fix it myself if someone can guide me and let me know what parts to change...
                                            I hope someone can help!
                                            Thanks.
                                            10-11-2020, 04:40 PM
