P5PE-VM question ?
  • bianchi77
    • Jun 2016
    • 1121
    P5PE-VM question ?
    Guys,
    I got P5PE-VM....I put the CPU and memory in it,
    I can turn it on but nothing is happened, no beep at all and
    POST code on diagnostic = 00, I have replaced the CPU with another CPU which is working on another board, still the same issue...
    How do you reckon ?
  • bianchi77
    • Jun 2016
    • 1121
    Re: P5PE-VM question ?
    I have a strange voltage value on some FETs ...3.2V...any opinions ?
    • bianchi77
      • Jun 2016
      • 1121
      could it be a corrupted bios ? can I write *.rom straight away with flash programmer without utility...since I can't boot to DOS ?
      • diif
        • Feb 2014
        • 6978
        • England
        Is the cpu compatible with the motherboard ?
        • bianchi77
          • Jun 2016
          • 1121
          yes I'm using Celeron D which is working on another board ...
          • bianchi77
            • Jun 2016
            • 1121
            I got only 00 on POST diagnostic and fan spinning..
            • bianchi77
              • Jun 2016
              • 1121
              I'm thinking uploading :
              http://dlcdnet.asus.com/pub/ASUS/mb/...316.1472338911
              Straight to the BIOS chip...
              I have G540 flash programmer...
              • bianchi77
                • Jun 2016
                • 1121
                *.rom is equal to *.bin or *.hex ? or I must use a special software from asus ?
                AFUDOS.exe
                Because I can't even access FDD or CDROM
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Try renaming the .ROM to .BIN
                  • bianchi77
                    • Jun 2016
                    • 1121
                    the chip :
                    W39V040FCPZ
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Ready to burn but not sure if the file is right
                      • selldoor
                        Slow Learner
                        • 7870
                        Have you checked the Cmos battery is ok.
                        Can I assume you have the attached?
                        Section2.1.2 suggests that the file should perhaps be renamed P5PEVM.ROM
                        Can you make a bootable floppy in another PC and add the rom to it then try it in the machine with the new board from a cold start. (maybe disconnect the hard drive and CD so it doesnt try to boot from them?
                        Was the board supposed to be working, when you got it?
                        Have you tried starting without any ram - any beeps then?
                        • bianchi77
                          • Jun 2016
                          • 1121
                          There was no beep, it was not working when it came, *.rom file = *.bin file ?
                          POST CODE = 00.....PLED is not on....
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Can I assume you have the attached?...Do you mean battery attached ?
                            • bianchi77
                              • Jun 2016
                              • 1121
                              Drain to Source = 0 ohm on 3 FETs ...9T15GH, 5503 x2
                              • bianchi77
                                • Jun 2016
                                • 1121
                                Does anyone know the buck controller for P5PE-VM ??
                                  master hoarder
                                  • May 2008
                                  • 12176
                                  • Bulgaria
                                  I guess you don't really care to fully try to read my posts about this issue in your other threads, but I will try again here...
                                  It is OKAY *most of the time* if MOSFETs show 0-10 Ohms resistance between Drain <-> Source leads if they are near the CPU. The CPU VRM has "lower" and "upper" MOSFETs. The lower MOSFETs have their Sources tied to ground and Drain tied to the inductors that output the V_core rail to the CPU. Because most CPUs (and GPUs too, FYI) have a low static resistance, the V_core rail will also show the same low resistance to ground. This means that the lower MOSFETs mentioned above will *appear* to have a short-circuit (0 to 10 Ohms) between Source and Drain as well.
                                  If those MOSFETs were truly shorted, you motherboard would not *stay* turned ON. At most, you will get a brief fan spin and then the motherboard would turn OFF - that's a tell-tale sign of something being shorted.
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    I got that case on Asus A7S333, what's shorted in this case ? one of CPU VRM FET, or the the whole lot, there are 4 FETs near the CPU, if I release the CPU, fan keep spinning.....
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      Here are some photos....I can see CLK LED on POST diagnostic very dim....does it mean that this board has a CLK problem ?
                                      • bianchi77
                                        • Jun 2016
                                        • 1121
                                        The video when I turned it on :
                                        https://youtu.be/_AS9uQU6XS8
                                          Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                                          Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                                          various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                                          Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                                          trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                                          what is wrong with your PC in just seconds. It saves you time and money.
                                          Our new and improved design...
                                          11-01-2024, 06:29 AM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                        • insomniacno1
                                          Thinkpad L540, won't turn on unless I switch ram
                                          by insomniacno1
                                          This is a very weird problem and super annoying, so if someone who has experience with this, can explain why this is happening, then I will be grateful😁
                                          This happen usually when the laptop has been moved. from one room to another OFF charger for some hours, but has also happened when laptop has been shut down and left ON charger over night, and not moved :
                                          I turn on the laptop normally by pressing the power button briefly, then power comes on and Power LED and Fn LED turn ON/OFF constantly (no post and no beep codes)
                                          If I(and this is my only option at this point),...
                                          09-29-2025, 05:58 AM
                                        • WVUfan
                                          PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                                          by WVUfan
                                          hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                                          08-11-2025, 01:12 PM
                                        • ktmmotocross
                                          PS5 Slim - no video, butchered hdmi, after replace still no video, diagnostic said APU was overheating and now not responding
                                          by ktmmotocross
                                          Have this PS5 Slim with no video, HDMI connector was horribly butchered. but after replace i have no video. diagnostic said APU was overheating and now not responding,
                                          checked fuses and all are good
                                          any hint?...
                                          07-24-2025, 02:12 AM
