P5PE-VM question ?
  • bianchi77
    • Jun 2016
    • 1121
    Re: P5PE-VM question ?
    anyone knows ? or have the schematic of this board ?
    I can't find the datasheet for the chip and the schematic of this board....a challange for fixing it ...
    • bianchi77
      • Jun 2016
      • 1121
      my northbridge temperature is reaching to 70 degree celcius on heatsink, is it the main problem ?
      chip = intel SL99Y
        master hoarder
        • May 2008
        • 12176
        #83
        chip = intel SL99Y
        Yes, 70C is way too much.
        How are you measuring this temperature, though?
        Just as a check to make sure you're not measuring the temperature wrong, try to touch the heatsink. Anything above 50C should feel uncomfortably hot, and 60C or more should be enough to cause a reaction for you to pull your hand away.
        • bianchi77
          • Jun 2016
          • 1121
          I measured it with my DMM temperature meter...
          I let it run few more seconds and it was nearly 100....so I pulled out the power supply just in case this chip will burn....I bought the replacement already and see what happen next...
          Anyway what's the cause of faulty northbridge ?
          • bianchi77
            • Jun 2016
            • 1121
            Does anyone have the schematic of this Asus P5PE-VM ? cheers
            • bianchi77
              • Jun 2016
              • 1121
              Originally posted by diif
              Post #25. The same way you tested that crystal.
              I test mine with one of these. http://www.aliexpress.com/item/DIY-K...413364646.html
              I bought that frequency counter but I can't measure 32KHz crystal..it's showing 0 always....I tried with 20MHz and 4MHz crystal it works....what should I change ? thanks
              • bianchi77
                • Jun 2016
                • 1121
                Is it possible that my northbridge faulty ? It's integrated with VGA
                  Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                  Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                  various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                  Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                  trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                  what is wrong with your PC in just seconds. It saves you time and money.
                  Our new and improved design...
                  11-01-2024, 06:29 AM
                • MisterAIL
                  PS5 digital / No Power / No Beep / Good power supply
                  by MisterAIL
                  Brought a non functionnal PS5. Apparently only a bad PSU...
                  No beep, nothing.
                  After some tests i found this :
                  - PSU is fine (12 volts stable)
                  - 12 volts line is shorted
                  - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                  - By the way, nothing change. No signal, no power, no beep.
                  Mesuring all rails with my workbench psu (12 volts input)
                  - 0.00 amp drawing
                  - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                  03-12-2024, 03:24 PM
                • insomniacno1
                  Thinkpad L540, won't turn on unless I switch ram
                  by insomniacno1
                  This is a very weird problem and super annoying, so if someone who has experience with this, can explain why this is happening, then I will be grateful😁
                  This happen usually when the laptop has been moved. from one room to another OFF charger for some hours, but has also happened when laptop has been shut down and left ON charger over night, and not moved :
                  I turn on the laptop normally by pressing the power button briefly, then power comes on and Power LED and Fn LED turn ON/OFF constantly (no post and no beep codes)
                  If I(and this is my only option at this point),...
                  09-29-2025, 05:58 AM
                • WVUfan
                  PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                  by WVUfan
                  hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                  08-11-2025, 01:12 PM
                • ktmmotocross
                  PS5 Slim - no video, butchered hdmi, after replace still no video, diagnostic said APU was overheating and now not responding
                  by ktmmotocross
                  Have this PS5 Slim with no video, HDMI connector was horribly butchered. but after replace i have no video. diagnostic said APU was overheating and now not responding,
                  checked fuses and all are good
                  any hint?...
                  07-24-2025, 02:12 AM
